EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 136 - AVS Forum
 3Likes
post #4051 of 4058 Old 11-02-2014, 01:02 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
Maybe the (S/PDIF?) connection from the Xbox to the HTPC does not accept multichannel (is this your connection?).
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #4052 of 4058 Old 11-03-2014, 04:47 PM
xstefanx42's Avatar
Htpc->hdmi->xbox one passthrough->hdmi->tv->optical->receiver.
The only thing currently not playing in 5.1 is the htpc. The tv itself does and any other app from the Xbox does except for the tv app.
xstefanx42 is offline
post #4053 of 4058 Old 11-03-2014, 05:03 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
Should work then. Perhaps the htpc video application is decoding the AC3 audio stream to PCM (or sending a PCM audio stream not encoded as AC3). In that case you'd certainly only get 2 channels.
Tulli is offline
post #4054 of 4058 Old 11-04-2014, 09:15 PM
xstefanx42's Avatar
I've gone through the settings and read through their wiki and it should be working. That being said, I wouldn't be shocked if it ended up being that.
Here is how the HTPC application is set up. I don't expect you to go digging or anything, just wanted to post this as a reference.
Now the part that is throwing me is this. It says there's no support for compressed formats. Shouldn't there be if you said it had AC3 Support?
post #4055 of 4058 Old 11-05-2014, 03:09 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
Weird. Try overriding the EDID with the captured monitor driver. It has the 6AC3 descriptor.
Tulli is offline
post #4056 of 4058 Old 11-05-2014, 05:38 PM
xstefanx42's Avatar
I just gave that a try and the supported formats still says the same thing. Attaching the file I used rather than copy and paste this time in case I messed something up before. Renamed to .txt is all.
post #4057 of 4058 Old 11-05-2014, 07:16 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 37 Post(s)
Liked: 84
File is fine. Double-check the installation procedure (a reboot is necessary). Check 1st. post for more info.
Tulli is offline
post #4058 of 4058 Old 11-05-2014, 08:45 PM
xstefanx42's Avatar
Just double checked the first post and that's definitely how I installed it. =\
Reply Home Theater Computers
