EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 139 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #4141 of 4156 Old 04-10-2015, 03:04 PM
Liked: 0
Hi,
kindly can you help me to get 5.1 Channels, i only have 2 Channels after I prepare below devices :
TV: Sony KDL-46HX855
Home Theater: LG BH 5720 TW
Display Adapters: NVIDIA GeForce GTX 650 Ti Boost
OS: Windows 7 64 bit
Thank you
Ibrahim.s.ali is offline
post #4142 of 4156 Old 04-10-2015, 05:14 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
The attached mod will work.
Ibrahim.s.ali likes this.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #4143 of 4156 Old 04-11-2015, 03:56 AM
Liked: 0
thank you for your quick replay.
I tried , but still 2 Channeles
post #4144 of 4156 Old 04-11-2015, 08:19 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
Check the thread. It's been thoroughly discussed. But basically, bandwidth of the HDMI-in of the HTS is not enough for 6 or 8-LPCM (only 2-LPCM).
Tulli is offline
post #4145 of 4156 Old 04-11-2015, 10:53 AM
Liked: 0
Hi , I bought new gold HDMI cable but still same problem
With do you suggest ?
Do you need any more information from me ?
Thank you
post #4146 of 4156 Old 04-11-2015, 01:13 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
Again, please check the thread for more info. The problem is the bandwidth limitation of the HDMI links of the HTS (it's typical of these devices). Just make sure that the audio stream is in DD or DTS format and multichannel will work.
Tulli is offline
post #4147 of 4156 Old 04-11-2015, 02:27 PM
Liked: 0
Thanks for your concern
Please look at the attached
And advise the appropriate options
Name:	TV Sony 2.jpg
ID:	660986   Click image for larger version
Name:	Home Thread.jpg
ID:	660994   Click image for larger version
Name:	TV Sony 1.jpg
post #4148 of 4156 Old 04-11-2015, 06:26 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
The DTS or DD audio stream should be either passed through or encoded in the HTPC. There's a hack for live encoding on Realtek audio devices (I've posted links in the thread). But if you're only watching movies make sure to select a DD or DTS audio track and set the video player to passthrough (NOT decode it).
Tulli is offline
post #4149 of 4156 Old 04-15-2015, 07:09 AM
Liked: 0
Hi Tulli ,
Still I have same problem, I try to change all stings but still 2 channels only.
if you can give a driver for the home theater (LG BH 5720 TW) so I can connect the PC direct to the home theater ?
Thank you.
post #4150 of 4156 Old 04-15-2015, 09:53 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
No, you'll never get more than 2-LPCM either through the TV or connecting to the Home Theater System. BANDWIDTH is the problem! The connection is exactly equivalent to S/PDIF.
Tulli is offline
post #4151 of 4156 Old 06-15-2015, 09:55 AM
Liked: 1
Hi Tulli,
I can't seem to get my HTPC to output 5.1 even after an EDID override.
Here is my setup:
Toshiba Satellite --> HDMI --> Vizio sv320xvt --> SPDIF --> Denon AVR 3300
The Denon is old (1999) and doesn't have HDMI input
The toshiba has Windows 8 and a NVIDEA geforce GPU that the audio is going through.
I realize that SPDIF has bandwidth limitations, but I would like to pass AC-3 5.1 to the Denon, which SPDIF should have the capability to do. I used moninfo to capture the live EDID information and create an INF file. There was only 1 SAD for AC-3 2-channel Left and Right, so I changed that to AC-3 6-channel Front Left/Right, Center, Rear Left/Right, LFE, and I updated the checksum. The problem is after installing the driver, it looks like only the first 128 bytes are stored in the registry, and it is getting the second 128 bytes (which contain the SAD) from the EEPROM. I attached both the original EDID capture and the modified version that I made.
Is there anything I can do? Please help.
dfkimbro likes this.
S1erraII7 is offline
post #4152 of 4156 Old 06-15-2015, 10:17 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
Perhaps it's a parsing problem due to the modded SAD having just the AC3 descriptor. Try the attached mod.
Tulli is offline
post #4153 of 4156 Old 06-15-2015, 10:38 AM
Liked: 1
I'm not sure that makes sense, because the original only had the single AC3 descriptor. I'll give it a try when I get home. Thanks for the help
post #4154 of 4156 Old 06-15-2015, 10:52 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
OK, I took the single AC3 descriptor as your mod. Anyway, the problem is therefore not EDID related. Is the application (which?) sending an AC3 (undecoded to PCM) stream? That's all that needs to be done. If the application is a game a live-encoding to AC3 is required. Has been discussed a lot in the thread.
Tulli is offline
post #4155 of 4156 Old 06-15-2015, 05:16 PM
Liked: 1
So, it doesn't look like your mod worked either. See my screen shot. The windows 8 speaker configuration doesn't allow for anything other than stereo output. You can also see the registry info through moninfo doesn't have the second half of the EDID. I am playing an test AVI with AC-3 5.1 using xbmc (kodi) set to output 5.1, and it is getting down muxed.
post #4156 of 4156 Old 06-15-2015, 08:11 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 73 Post(s)
Liked: 95
Should work. If that's an x64 version you need to disable signature enforcement before installing.
Tulli is offline
Reply Home Theater Computers
