EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 143 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #4261 of 4297 Old 11-24-2015, 12:04 AM
Quoted: 66 Post(s)
Originally Posted by Tulli View Post
AFAIK full audio will work only with the built-in Bluray player, not over the HDMI-in connection (hence the lack of support for HD audio formats in the native EDID detected on the PC).
Attached is the table of the LG LHB755W HDMI spec.
I think if the Source on the left column here refer strictly to the built-in Bluray player, then you're probably right.
I was interpreting this "Source" to be either one of its 2 HDMI inputs, but maybe I'm wrong. If the native EDID detected on the PC doesn't show any of these options as seen on the spec, then you're probably right that the "Source" here is just the Bluray player.
Name:	LG LHB755W HDMI spec.JPG
Volusiano is offline
post #4262 of 4297 Old 11-24-2015, 03:36 AM
Liked: 0
Originally Posted by Volusiano View Post
The spec for the LG LHB755W manual shows support for 5.1 and 7.1 LPCM (page 70 of the Appendix), so I wouldn't discount it yet.
I think you should tinker around with the PC's audio settings some more to make sure that you have 5.1 LPCM set in your Sound Control Panel's configuration setting, and that your video app is outputting 5.1 and not stereo, and that your content indeed does have 5.1 audio for sure.
I discovered that through the optical output of the PC and a patch for realtek HD, I get a Dolby digital live 5.1, however in certain applications that support it. My LG LHB755W shows the display "DD3:2/0.1" when the input is optical TOSLINK: it is something good to get around the limit. As far as the uncompressed PCM 5.1 surround sound it is only output mode. It is a limitation of the device driver LG
The suggestion to use an AVR professional is not so bad.
sfoneloki is offline
post #4263 of 4297 Old 12-08-2015, 05:34 AM
Liked: 0
Newby to Override
I have a vizio E60-C3 LED tv, just got it and I'm having the trouble with the override. I tried using the MOD below.
Vizio SV420m - DENON 590Vizio LCD + DENON AVR.
When installed, the video looses sync, TV says resolution not supported. Trying the Samsung LN-S4095D - DENON AVR988 next. Below is the Monoinf report. If a custom override is not needed, can someone point me in the right direction?
Monoinfo report attached.
mtboyd is offline
post #4264 of 4297 Old 12-08-2015, 01:14 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Why the connection through the TV? No HDMI on the Denon?
What is your graphic adapter and OS? (An Intel adapter won't accept EDID overrides)
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #4265 of 4297 Old 12-08-2015, 01:39 PM
Liked: 0
Let me explain my setup. It's not a denon, just tried that driver beacuse it was listed to work with most brands. I have a Vizio TV with a Vizio 5.1 sound bar setup. HDMI from a Geforce 210 to the TV. Optical audio out of the tv to the bar system. Windows audio control says 2 channel only when detecting my Tv. So my tv is the switch for the sound system.
I did get the override to work with the Vizio inf in the list sometimes, but the video still goes out randomly, then will come back.
Geforce 210, Win 7 64bit
mtboyd is offline
post #4266 of 4297 Old 12-08-2015, 02:01 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
According to the real-time EDID of the Vizio there's already the capability of multichannel AC3 enabled. No need of overriding the EDID.
2 channels LPCM is the maximun bandwidth over the TV for uncompressed audio. Nothing to do about it.
Tulli is offline
post #4267 of 4297 Old 12-08-2015, 05:43 PM
Quoted: 66 Post(s)
When you said you got the override to work with the Vizio sometimes, are you saying that your Geforce can see 5.1 channel options in the Windows audio control panel? And you're able to get DD or DTS through the TV to the Vizio sound bar? Only that your video goes in and out randomly?
post #4268 of 4297 Old 12-30-2015, 02:36 PM
icstm's Avatar
Question
Hi,
Thank for this thread. Throughout my Win7 time it helped get the right digital output from my PC.
Now upgraded to Win10, the same inf files do not work, as Device manager says they need to be signed. Is there a solution?
icstm is offline
post #4269 of 4297 Old 12-30-2015, 03:43 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Disable digital signature verification and then install the EDID override.
Tulli is offline
post #4270 of 4297 Old 01-02-2016, 06:28 AM
Liked: 0
Happy new year...
Recently I finally changed the LG home theater with a decent AVR, the Yamaha rx v479.
Now when I connect HDMI directly to the AVR, the PC operates in PCM 5.1.
Unfortunately, however, if I connect to the PC to HDMI TV to the AVR via HDMI ARC, the PC returns to work only in 2.0.
The TV is a Panasonic 2011, TX-P50ST30.
Thanks a lot.
post #4271 of 4297 Old 01-09-2016, 10:41 PM
GregoryRB's Avatar
EDID Override
HI Tulli about 7 years ago you provided me with EDID override filefor a Denon AVR 3808/ Pioneer Kuro plasma system. which has worked fantastically ever since.
My Denon has failed, and is not repairable, and I am about to commit to an Integra DTR 30.7 ( Pioneers Plasma still going strong). Do you have any experience with Integra models? I could not see Integra in your list of prior solutions so maybe thisd infers Integra AVR's do not require EDID overrides??
Please let me know your thoughts.
I would like to know a solution ( if needed), can be provided before I commit to buying the Integra
Greg
GregoryRB is offline
post #4272 of 4297 Old 01-10-2016, 03:29 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
You can use the same EDID override if needed. It will work with the Integra or any other AVR as the video part is the same for EDID detection.
Tulli is offline
post #4273 of 4297 Old 03-25-2016, 07:26 PM
TheBigRoberto's Avatar
Hi Tulli, can you please help me out with a Edid override again? Many thanks
File Type: zip LG - 50PZ570T.zip (757 Bytes, 20 views)
TheBigRoberto is offline
post #4274 of 4297 Old 03-26-2016, 04:06 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Tulli is offline
post #4275 of 4297 Old 03-26-2016, 05:15 AM
Thank you
post #4276 of 4297 Old 04-10-2016, 04:36 PM
dnoonie's Avatar
Quoted: 317 Post(s)
Liked: 271
Anyone need an EDID editor?
Understanding EDID wasn't as necessary before devices tried to do too much for you, what a pain.
http://www.analogway.com/en/products...-editor/#dl#dl
Click on the Download tab, there's a White Paper that is helpful. And actually even through you might not want or need to program your own EDID running and understanding the EDID editor gave me a better understanding of EDID. The EDID editor is not product specific and can be used to edit and create EDID for any device.
Cheers,
OPPO BDP-93, Pioneer Kuro Pro-150FD, Dynaudio 2x BM-12a Mk III Mains, 2x BM 6a Mk II surround, 2x BM 14s Subs, Allan and Heath MixWizard, room is 11'7"x 16'6"x 8" dedicated and treated.
dnoonie is offline
post #4277 of 4297 Old 04-18-2016, 11:29 AM
Jedi's Avatar
Quoted: 43 Post(s)
Liked: 30
I solved a problem of my legacy Sony Blu-ray megachanger (BDP-CX7000ES) not passing DTS-HD Master Audio as bitstream to my Marantz pre-pro (AV-7702Mkii). The problem popped up immediately after a new DTS:X firmware update was installed on the Marantz. Using a Dr HDMI device, I sampled the EDID data on the Marantz, and changed the SAD byte 3 value of the CEA 861 Extension block for the DTS-HD codec, from its current value 03, to the new value 01, together with revising the affected checksum value. The Blu-ray player now bitstreams DTS-HD Master Audio as well as the new DTS:X codec. Pure joy.
Since doing so, I have been trying to determine exactly what SAD byte 3 data code for the DTS-HD codec actually governs or represents. All I have been able to learn thus far, is that SAD byte 3 represents for the basic codecs (Dolby Digital, DTS, etc.) the maximum bitrate divided by 8Kbps. But for the more advanced codecs, DTS-HD included, it represents "Audio Code Dependent Format", which I took to mean some coded variable, unique to each advanced codec.
I am posting this little mystery to the community of this thread, looking for someone who may be knowledgeable and maybe can shed some light. I posed the same question separately to Marantz and to DTS technical support, but neither have answered.
Are Eleven Channels Really Enough?
Jedi is offline
post #4278 of 4297 Old 05-10-2016, 06:52 PM
cadking000's Avatar
Liked: 0
I did this a few years back and worked flawlessly. Recently I upgraded to Windows10 and I don't have any surround sound problems but, no GUI display from the AVR (volume bar). My setup is as follows: Samsung Plasma - pn58a550s1f, Denon 4310 and Windows 10 64bit with ATI 5970.
I'm still reading through the thread hoping to find a clue as to what I'm doing wrong.
I downloaded MonInfo. Then I hooked up my ATI 5970 directly to my Samsung Plasma. Then I created a INF file of the monitor. Did the same thing with the Denon 4310 in between. Then opened the monitor INF file and merged it with the Denon file, saved as. Then I updated the monitor driver from device manager, restarted and it's the same as before.
I even tried a file from the first page from someone else that had a Samsung Plasma and Denon 4810. Same thing, no GUI display. UGH!
Appreciate any help!!!!!
Samsung PLASMA -
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,EA,03,00,00,00,00,02 ,12,01,03,80,10,09,78,0A,22,ED,A5,54,47,99,24,
0F,47,4A,20,00,00,01,01,01,01,01,01,01,01,01,01,01 ,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20,6E ,28,55,00,A0,5A,00,00,00,1E,00,00,00,FD,00,17,
3D,1A,44,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00 ,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,7F,
02,03,36,71,48,90,04,05,03,20,22,0F,24,38,0F,7F,07 ,3D,1E,C0,15,07,50,5F,7E,01,57,06,00,65,7E,00,
67,1E,00,4D,02,00,83,5F,00,00,E3,05,03,01,67,03,0C ,00,11,00,B8,2D,01,1D,80,18,71,1C,16,20,58,2C,
25,00,A0,5A,00,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10 ,3E,96,00,A0,5A,00,00,00,18,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00,00,00,00,00,00,00,00,00,00,00,00,00,9E
Denon 4310
Raw data
00,FF,FF,FF,FF,FF,FF,00,11,EE,18,00,01,01,01,01,00 ,13,01,03,80,10,09,78,0A,22,ED,A5,54,47,99,24,
3D,1A,44,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00 ,44,45,4E,4F,4E,2D,41,56,41,4D,50,0A,20,01,53,
cadking000 is offline
post #4279 of 4297 Old 07-10-2016, 08:05 AM
Liked: 0
Samsung PLASMA -
Raw data
Denon 4310
Raw data
I have a Samsung JS9000 and a Onkyo NR-608. what file edid file should i use?
Andres Garcia is offline
post #4280 of 4297 Old 07-13-2016, 07:30 PM
Liked: 0
Question
Hello
I have an Onkyo HT-R380 receiver, connected via hdmi to the pc.
This receiver can decode DTS-HD MA and trueHD, but sadly it reports itself as 6 channels in windows.
I want it to have it 8 channels, otherwise windows won't let me bitstream DTS-HD MA.
I extracted the edid with moninfo and edited it with an edid editor so that it has the RLC/RRC.
Exported it to bin, opened it with moninfo created inf there.
That schould be it or not ?
But i will not work, i installed the inf via manual driver installation as per thread start described.
It is installed but i still have only 6 channels in windows audio settings, and yes i rebooted.
OS is windows 7 ultimate x64, graphiccard amd r270x with latest crimson driver.
Why won't it work ? any help is appreciated !
Thanks a lot.
sharonna is offline
post #4281 of 4297 Old 08-10-2016, 02:21 PM
mooshooorson's Avatar
Liked: 0
Hello,
I have an HTPC with a Radeon R9-270x video card and intel hd4600 integrated with the i7-4790k.
I just got the new Dolby Atmos Samsung Soundbar surround system (Hw-K950) which purports to support Dolby TrueHD and Dolby Atmos.
My display is a Sharp LC80-lc632u.
I've connected via DVI --> SHARP HDTV & via HDMI - Samsung Atmos Soundbar.
Like many here, I cannot get Windows 10 to show more than 2 channels via the hdmi output. It shows Dolby TrueHD under supported formats, but still only 2 channels.
Appreciate any thoughts or insights.
mooshooorson is offline
post #4282 of 4297 Old 10-15-2016, 09:25 AM
Liked: 0
Ati dolby digital live + dts interactive for gaming
I have read the first post and from my understanding i can do an edid override to get dolby digital live 5.1 and dts interactive 5.1 for gaming. I just wanted to ask if i get this right?
My setup is ati graphics card - - > hdmi - - > tv - - > avr optical
My avr supports only the following formats :
Dolby digital 5.1 (ac3)
DTS 5.1
PCM only stereo upto 4800hz
And that is why i have to use dts or dolby digital for gaming because my avr only supports pcm 2 channel.
For now im stuck with the Realtek driver hack with optical out to my avr to play games with dts interactive 5.1.
But i have to switch everytime the optical cabel if i want to watch anything on my tv besides gaming.
If i can override my edid i can use only one setup and dont have to switch everytime my optical cable.
Thanks in advance.
TheGame1594 is offline
post #4283 of 4297 Old 10-17-2016, 05:45 AM
dado7777's Avatar
Seems we finally got EDID overrides approved by Intel.
I don't know if it works though, I have to wait for a new driver for I7-3612QM, 3rd generation processor.
dado7777 is offline
post #4284 of 4297 Old 10-25-2016, 09:29 AM
S2G-Unit's Avatar
Quoted: 16 Post(s)
Are you guys still making EDID .inf files.
I can't for the life of me to get bitstreaming working on AVR 2112ci with Benq SH910 PJ & ATI 5850.
I've been trying ATI drivers/ Realtek drivers. Picture works but no sound at all.
Please PM me.
S2G-Unit is offline
post #4285 of 4297 Old 11-22-2016, 08:35 AM
ludespeedny's Avatar
Quoted: 28 Post(s)
Can anyone help me with an inf file for the edid override? I just need the inf file to contain the audio info for my receiver, ex 5.1 formats etc...
ludespeedny is offline
post #4286 of 4297 Old 12-01-2016, 04:53 AM
Liked: 0
Hi people,
So I upgraded to the AVR Marantz 6010 (Dolby Atmos/DTS-X).
So my sound configuration is now 5.1.4
PC gtx1080->HDMI->AVR Marantz->HDMI->TV 4k 3d.
It's awesome and works perfect in movies with PowerDVD owerDVD's audio option to non decoded High Definnition Audio to external hardware (AVR)
But soon I enter any game, I saw that in windows panel audio device it switches everytime the Marantz HDMI audio (Atmos DTS etc capable) to PhilipsTv HDMI Audio (only stereo!) as device. The HDMI Marantz AVR audio device disappear and is replaced everytime by PhilipsTV stereo device...
So ingame The marantz only see a stereo signal (which is upmixing by the Marantz but it stills stereo)...
In Marantz settings I configured HDMI to AVR only (and not Tv audio)
I try everything, does anyone have any idea?
chtiblue is offline
post #4287 of 4297 Old 12-03-2016, 10:26 PM
_X_
Liked: 0
Im not quite following how to do all this, so here is my story.
Have Onkyo NR616 receiver, doesnt pass through proper 3D @ 1080p from HTPC, and when I skip the receiver and goto the TV I get the 3D, but no surround sound. My thoughts were to get a splitter to send video to TV directly, and audio to the receiver.
Problem is, the splitter says its only a stereo audio. I thought perhaps to use the EDID override to tell the PC that the connected device is capable of doing HD audio, and send the signals through to the receiver.
Tell me if im going down the wrong path. Note the second one has 2 channel LPCM.
Im not quite sure what to merge into another INI file, I have done a bunch of attempts and replaced the generic PNP monitor with an INF that I thought I had overridden.
Normal receiver:
Monitor
Model name............... TX-NR616
Manufacturer............. Onkyo
Plug and Play ID......... ONK0C61
Serial number............ n/a
Manufacture date......... 2012, ISO week 0
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.595
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-126kHz
Vertical scan range...... 23-240Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
640 x 480p at 60Hz - Default (4:3, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 8-channel, 640k max. bit rate at 32/44/48 kHz
DTS 8-channel, 1536k max. bit rate at 44/48 kHz
SACD 6-channel at 44 kHz
DD+ 8-channel at 44/48 kHz
DTS-HD 8-channel, 16-bit at 44/48/88/96/176/192 kHz
DVD-A 8-channel at 48/96/192 kHz
CE speaker allocation data
Channel configuration.... 7.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. No
Front left/right center.. No
Rear left/right center... Yes
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.5.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 04/12/2016
Software revision........ 2.90.0.1020
Data source.............. Real-time 0x0071
Operating system......... 10.0.14393.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,3D,CB,61,0C,00,00,00,00,00 ,16,01,03,80,00,00,78,0A,0D,C9,A0,57,47,98,27,
12,48,4C,00,00,00,01,01,01,01,01,01,01,01,01,01,01 ,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10 ,2C,25,80,C4,8E,21,00,00,9E,00,00,00,FC,00,54,
58,2D,4E,52,36,31,36,0A,20,20,20,20,00,00,00,FD,00 ,17,F0,0F,7E,11,00,0A,20,20,20,20,20,20,01,8C,
02,03,36,72,4D,85,04,03,02,07,10,94,13,12,11,16,01 ,1F,38,09,7F,07,0F,7F,07,17,07,50,3F,06,C0,4D,
02,00,57,06,00,5F,7E,01,67,54,00,83,4F,00,00,66,03 ,0C,00,15,00,80,8C,0A,D0,8A,20,E0,2D,10,10,3E,
96,00,C4,8E,21,00,00,18,8C,0A,D0,90,20,40,31,20,0C ,40,55,00,C4,8E,21,00,00,18,01,1D,00,72,51,D0,
1E,20,6E,28,55,00,C4,8E,21,00,00,1E,01,1D,00,BC,52 ,D0,1E,20,B8,28,55,40,C4,8E,21,00,00,1E,00,57
Splitter
Monitor
Native formats........... 1
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Detailed timing #2....... 1280x720p at 60Hz (16:9)
Detailed timing #3....... 720x480p at 60Hz (16:9)
Detailed timing #4....... 720x480p at 60Hz (4:3)
Detailed timing #5....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
LPCM 2-channel, 16-bit at 32/44/48 kHz
Channel configuration.... 2.0
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear left/right center... No
Report information
Raw data
02,03,21,71,4D,85,04,03,02,07,10,94,13,12,11,16,01 ,1F,23,09,07,01,83,01,00,00,66,03,0C,00,15,00,
80,01,1D,80,18,71,1C,16,20,58,2C,25,00,10,09,00,00 ,00,9E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,10,
09,00,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00 ,10,09,00,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,
3E,96,00,04,03,00,00,00,18,8C,0A,A0,14,51,F0,16,00 ,26,7C,43,00,10,09,00,00,00,98,00,00,00,00,22
_X_ is offline
post #4288 of 4297 Old 12-03-2016, 10:29 PM
_X_
Liked: 0
And here is the INI files for the above. Help would be appreciated
_X_ is offline
post #4289 of 4297 Old 12-09-2016, 11:07 AM
Liked: 0
Hey, are you still doing EDID overrides? I have a vizio M420SL TV and a Yamaha HTR-6230 AV Receiver. Please help, my computer will only recognize the TV as stereo. I'm connected with HDMI to the TV, which forwards audio to the receiver via optical cable. I know my HDMI port supports 5.1 audio.
HoboRabies is offline
post #4290 of 4297 Old 12-17-2016, 12:11 PM
paknik's Avatar
Hello all
Can someone please help me and suggest which already created edid override (1st page) will work with a Benq 1070+ and a Denon 2309?
I want to pass 3d and HD audio from the avr and i think this can be done through edid override.
Or someone help me to create an override file and what i need.
Thanks a lot
paknik is offline
Reply Home Theater Computers
