EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 144 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #4291 of 4297 Old 12-21-2016, 05:36 PM
Liked: 0
Originally Posted by Tulli View Post
Hi Tulli,
Apologies for disturbing you but from my limited understanding as I'm trying to connect my PC to my TV and then output DD 5.1 to my Sonos playbar (by SPDIF) I think I need to override the EDID because my laptop sees the TV as only accepting PCM. So in my AMD driver I can only see a 2 channel option and that means that within Powerdvd 10 I also only see PCM. I think I just need to add the AC3 SAD info into my EDID (below) but don't know how. Is there any chance you could help please?
Daniel
Monitor
Model name............... SAMSUNG
Manufacturer............. Samsung
Plug and Play ID......... SAM0A7D
Serial number............ 1
Manufacture date......... 2012, ISO week 46
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 890 x 500 mm (40.2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-81kHz
Vertical scan range...... 24-75Hz
Video bandwidth.......... 230MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1366x768p at 60Hz
Modeline............... "1366x768" 85.500 1366 1436 1579 1792 768 771 774 798 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080i at 50Hz
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1280x720p at 50Hz
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1280x720p at 60Hz
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Supports overscan and underscan
PT scan behavior......... Not supported
RGB quantization range... Not supported
YCC quantization range... Not supported
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 3.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. Yes
EDID screen size......... Rounded to nearest cm
3D structures supported.. Top-and-bottom, Side-by-side w. horizontal sub-sampling
3D formats supported..... Mandatory formats plus some primary VICs
Data payload............. 030C003000B82D21D0080140073F405090A0
Report information
Date generated........... 12/22/2016
Software revision........ 2.90.0.1020
Data source.............. Real-time 0x0100 - NB: improperly installed
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,7D,0A,01,00,00,00,2E ,16,01,03,80,59,32,78,0A,EE,91,A3,54,4C,99,26,
0F,50,54,BD,EF,80,71,4F,81,C0,81,00,81,80,95,00,A9 ,C0,B3,00,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,24,72,42,00,00,1E,66,21,56,AA,51,00,1E,30,46 ,8F,33,00,24,72,42,00,00,1E,00,00,00,FD,00,18,
4B,0F,51,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00 ,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,67,
02,03,30,F1,4D,90,1F,04,13,05,14,03,12,20,21,22,07 ,16,23,09,07,07,83,01,00,00,E2,00,0F,72,03,0C,
00,30,00,B8,2D,21,D0,08,01,40,07,3F,40,50,90,A0,01 ,1D,80,D0,72,1C,16,20,10,2C,25,80,24,72,42,00,
00,9E,01,1D,80,18,71,1C,16,20,58,2C,25,00,24,72,42 ,00,00,9E,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,
24,72,42,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55 ,00,24,72,42,00,00,1E,00,00,00,00,00,00,00,FE
DJJ1 is offline
post #4292 of 4297 Old 01-08-2017, 12:56 PM
BenPlace's Avatar
Hi Tulli, I don't know if you are still doing these or not, hoping you are.
I have a Samsung UN75JU6500FXZA 4K TV and my HTPC is connected from a NVidia GTX 1080 to the TV via HDMI, then the TV is connected via a Toslink optical cable to my Yamaha HTR-5540 receiver.
I am trying to get INF that will pass through 5.1. My TV is reporting LPCM 2 from the EDID.
I have attached my INF file.
Thanks in advance for any help. The Plex people told me this was not possible but I know it is.
BenPlace is offline
post #4293 of 4297 Old 01-08-2017, 01:46 PM
BenPlace's Avatar
Update - I tried another INF from this thread for a guy that had a Samsung 4k TV and was able to get DTS and HD DTS to play at 5.1! The file didn't include dolby digital format so that still plays at 2.0
Can you make the file to just include all formats at 5.1?
BenPlace is offline
post #4294 of 4297 Old 03-06-2017, 11:36 AM
rphdantas's Avatar
Hello friends.
I read all the subjects here on the topic, it helped me a lot.
But I still have problems. I will tell my situation to see if anyone can help me. I already apologize for my English.
I have an HTPC connected on a Yamaha RX-V377 / HTR-3067 AV Receiver.
At the output of the receiver, an HDMI splitter is connected by sending the signal to an HD141x optoma projector and a LG 60UH6150 TV.
My initial problem was to send 1080P to the two screens, which only recognized 640x480. I was able to use an EDID here from the forum, and it worked.
But I still have instability, when restarting the HTPC it accuses that there was a bad shutdown probably caused by drivers, sometimes I need to reboot twice to give an image, it also happens that if I turn off the TV and only stay with the projector turned on, sometimes it To recognize the receiver in the Windows settings, and need to reboot to return to normal.
My suspicion is that this EDID even though it worked, is still not ideal. Would anyone have a specific EDID to use in my case, or could someone help me create one for my specific case?
Any help will be greatly appreciated!
Thank you all!!
rphdantas is offline
post #4295 of 4297 Old 03-31-2017, 05:37 AM
Liked: 1
Hi,
First time doing something like this, so please advise if it is correct for my situation!
My set up is:
Intel NUC (HD graphics 4000) -> HDMI MATRIX (with a SPDIF out to an old videologic AC3 decoder) -> matrix goes to a Samsung H6700 and a Benq W1110s projector.
Connected to either TV or projector I get no compressed formats found under sound properties (onboard intel sound as part of HD graphics 4000). I thought it might be the matrix, but I've connected NUC straight to TV and straight to projector without any other devices and result is the same, format list is blank, which is totally frustrating.
All I want is AC3 5.1 to my decoder, nothing more sophisticated!
Is the EDID override the right approach? I'd also read that edid overrides didn't work with intel, is that true?
At the moment I have downloaded moninfo but would appreciate thoughts on how best to proceed.
randy_69 is offline
post #4296 of 4297 Old 04-03-2017, 02:02 PM
cerchiarax's Avatar
Quoted: 42 Post(s)
Hi guys,
Would you know what the best EDID would be for my setup below? Sorry if its messy... and thanks for any help ahead of time!
AMD RX480 video card HDMI from PC connected to IOGEAR GW3DHDKIT Wireless transmitter on HDMI input 1 which is then connected to a Sony Playstation 3DTV for HDMI Output. The wireless HDMI which supports 5.1 is then wirelessly sent to the IOGEAR receiver which connects to my Onkyo Receiver TX-SR507. Once I turn on the receiver my PC sound changes from SONY Playstation 3D speakers to TX-SR507, I once saw it actually say in the pc sound control panel that 8 speakers formats and Dobly and DTS supported but for some reason it just disappeared and changed to only say 2 speakers and stereo available, so I assume its the EDID that sometimes works and doesn't. Finally my receiver is connected to a LG OLED65C6P.
Update: I was able to get the 8 speakers and Dolby and DTS with the Sony KDS-55A3000 - ONKYO 805.inf drivers, which is fantastic! Only thing is I can get Dolby working with PowerDVD for example when I force it in output audio settings and then my receiver picks it up. But I haven't been able to do the same in PC games, has anyone else had this issue?
Update 2: Did some more digging looks like PC games are PCM Multichannel when using HDMI from videocards, atleast thats my understanding that it occurs because of licensing and that we can apparently only get Dolby and DTS using a sound card or DAC with optical or coaxial.
cerchiarax is offline
post #4297 of 4297 Old 05-14-2017, 12:12 AM
acem77's Avatar
I created this from my lg oled and my denon,
under speaker setup - configuration, when select anything else other than stereo i am missing sound for most surround options.
when i select 7.1 i get only 2 channels.
I tried a few other .inf files and they all have the same issue. Any advice would be great.
; INF file generated by Monitor Asset Manager (2.90.0.1020), 5/14/2017
; Copyright (c) 1995-2016, EnTech Taiwan.
; Internet: http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=5/14/2017, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\GSM0001
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\GSM0001
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xF F,0xFF,0xFF,0x00,0x1E,0x6D,0x01,0x00,0x01,0x01,0x0 1,0x01,0x01,0x1A,0x01,0x03,0x80,0xA0,0x5A,0x78,0x0 A,0xEE,0x91,0xA3,0x54,0x4C,0x99,0x26,0x0F,0x50,0x5 4,0xA1,0x08,0x00,0x31,0x40,0x45,0x40,0x61,0x40,0x7 1,0x40,0x81,0x80,0x01,0x01,0x01,0x01,0x01,0x01,0x0 8,0xE8,0x00,0x30,0xF2,0x70,0x5A,0x80,0xB0,0x58,0x8 A,0x00,0x40,0x84,0x63,0x00,0x00,0x1E,0x02,0x3A,0x8 0,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x4 0,0x84,0x63,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x0 0,0x3A,0x3E,0x1E,0x88,0x3C,0x00,0x0A,0x20,0x20,0x2 0,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x4C,0x4 7,0x20,0x54,0x56,0x20,0x52,0x56,0x55,0x0A,0x20,0x2 0,0x20,0x01,0x02
;Extension bloc #1 , e.g., CEA-EXT, DID-EXT, etc.
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x42,0xF1,0x5 0,0xDD,0x10,0x04,0x05,0x03,0x02,0x20,0x22,0x01,0x5 E,0x5F,0x62,0x63,0x64,0x0E,0x0F,0x3B,0x0F,0x7F,0x0 7,0x3D,0x1E,0xC0,0x15,0x07,0x50,0x59,0x7E,0x01,0x5 F,0x1E,0x01,0x57,0x06,0x00,0x61,0x54,0x00,0x67,0x1 4,0x00,0x4D,0x02,0x00,0x83,0x5F,0x00,0x00,0x6C,0x0 3,0x0C,0x00,0x32,0x00,0xB8,0x2D,0x00,0xC0,0x87,0x0 1,0x02,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x5 8,0x2C,0x25,0x00,0x40,0x84,0x63,0x00,0x00,0x9E,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0 0,0x00,0x00,0x09
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,0
HKR,,PreferredMode,,"3840,2160,60"
[MODE1]
HKR,,MaxResolution,,"3840,2160,60"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\3840,2160,60",Mode1,,"30.0-136.0,58.0-62.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
;YourColorProfileFile.icm for non-sRGB displays
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="LGE LG TV RVU (GSM0001 EDID Override)"
VENDOR="LGE"
acem77 is offline
Reply Home Theater Computers
