EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 39 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #1141 of 4297 Old 04-26-2010, 05:12 PM
marcdaddy's Avatar
Okay ill try it out tonight then! In between periods of the Blackhawks game... GO HAWKS!!!
marcdaddy is offline
post #1142 of 4297 Old 04-27-2010, 10:37 AM
marcdaddy's Avatar
Hi Tulli i tried the Overide you made me for the Sony5300 and Panasonic projector and now in Poerdvd i do not get the 3rd option, and it still doesnt fix my Problem of ATI locking my Refresh at 30i which is crap that i cant run in 1080P mode. I am about to give up on ATI/PDVD its been months and i still cant get it to work lol.
post #1143 of 4297 Old 04-27-2010, 11:05 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Checked the override and it's fine. Video timings are native to the projector too. Did you uninstall any previous monitor driver/leftover by following section 5 from 1st. post?
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #1144 of 4297 Old 04-27-2010, 02:50 PM
sannieboy's Avatar
I have a Onkyo TX-SR606, Panasonic TX-P42S10E (have to check that!) and ATI 5750 (10.3). I'm using PowerDVD 10 on Windows 7, but can't get DTS-HD working. PowerDVD says that it's playing DTS-HD audio en the output is compressed data, but the AVR only shows the DTS icon.
sannieboy is offline
post #1145 of 4297 Old 04-27-2010, 03:18 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
You need to select the third audio option audio settings while the movie is playing back. If you only get 2 audio options then your 606 is faulty and needs an EDID override.
Tulli is offline
post #1146 of 4297 Old 04-27-2010, 06:37 PM
richarddz's Avatar
Hi,
I am hoping someone can help as I am having the same trouble as most with the bitstreaming issue and I have a ATI 5750 video card. I do not want to add the wrong EDID to my system yet the one I need does not exist I have a Mitsubishi WD52725 DLP display and a Sony STR DA4400ES AVR. Can I use a similar EDID or do I need the specific to my equipment. I am having no video troubles is there a way I can modify the EDID I am using now to correct for my receiver. Thank you in advance for any help.
richarddz is offline
post #1147 of 4297 Old 04-27-2010, 07:49 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by richarddz View Post
Hi,
See if a similar EDID Override works for you (i.e. meaning no video issues, as any of the listed EDID overrides will give you bitstreaming over the SONY AVR).
If you have video issues post the full 256-byte of the Mits and the SONY AVR and I'll mod it for both.
Tulli is offline
post #1148 of 4297 Old 04-27-2010, 11:31 PM
tvboy1428's Avatar
Dear Tulli,
I am using a 5-year old Plasma TV (Hitachi 42PD5000) with DVI - HDMI cable connected to my Sony STR-DA2400ES AVR. There is no audio signal from my ATI HD5450 card HDMI port that can be reconized by my Sony AVR. I have tried to use both the below EDID Override files on my computer but I got no luck on getting the any audio signal from my HD5450 card.
SONY KDL40-X3500 - SONY STR DA2400ES.inf
Sony KDL-46D3500 - SONY STR-DA2400ES.inf
My guess is the problem is caused by the DVI input to my old Plasma TV which the first part of the EDID Override files on the TV cannot be applied to my Hitachi Plasma TV.
Can you help on working out an inf that fits my Hitachi Plasmas TV and my Sony STR-DA2400ES AVR?
John
tvboy1428 is offline
post #1149 of 4297 Old 04-28-2010, 02:14 AM
sannieboy's Avatar
That did the trick! Thank you
post #1150 of 4297 Old 04-28-2010, 03:46 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by tvboy1428 View Post
Dear Tulli,
John
Sure. Post the full 256-byte EDID of both and I'll do the mod.
Tulli is offline
post #1151 of 4297 Old 04-28-2010, 02:06 PM
richarddz's Avatar
Hi Tulli,
Thank you for the assistance, I tried a Mitsubishi DLP and Denon EDID today and found that I lost video to my TV. I imagine the computer went above my TV's resolution so I connected another monitor and followed your guide to remove the EDID (Thank you for that info) and was up and running again with the generic Monitor EDID. I again followed your guide and used Moninfo to create 2 EDID one for my Mitsubishi and one for my Sony AVR. I have included them and hope you will have the time to create an EDID I can use. I believe the other Mitsubishi I used was a 1080P display and mine is only 1080I/720P so that most likely caused the video issue.
Mitsubishi WD-52725 and Sony STR-DA4400ES.zip 2.1572265625k . file
File Type: zip Mitsubishi WD-52725 and Sony STR-DA4400ES.zip (2.2 KB, 30 views)
post #1152 of 4297 Old 04-28-2010, 03:06 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Hi Tulli,
Guys, this thread is HISTORY!!!
I can confirm ATI fixed the EDID issue with Cat 10.4!
Tested on both my x32 & x64 systems over my DENON 988!
Enjoy!!!
Tulli is offline
post #1153 of 4297 Old 04-28-2010, 03:09 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1261 Post(s)
Liked: 1325
Enjoy!!!
But will they break it again with Cat 10.5?
Edit - And THANK YOU very much for all the work you've put into the EDID overrides.
gsr is online now
post #1154 of 4297 Old 04-28-2010, 03:23 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Well, I must say I learned a lot, and that was nice!
Tulli is offline
post #1155 of 4297 Old 04-28-2010, 03:27 PM
vladd's Avatar
Liked: 39
That's great news!
vladd is offline
post #1156 of 4297 Old 04-28-2010, 03:45 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Win7 selection for 10.4 still seems to be broken on ATI site. Choose Vista instead as it's the same driver.
Tulli is offline
post #1157 of 4297 Old 04-28-2010, 06:14 PM
richarddz's Avatar
Hi Tulley,
Thank you for all the help I installed 10.4 and Bingo I had DTSTrue-HD on my receiver. I can see by how many people needed your help that this may have been the push for ATI to initiate this fix.
Thanks Again!
post #1158 of 4297 Old 04-28-2010, 09:18 PM
vladd's Avatar
Liked: 39
Win7 x64 selection worked for me at http://game.amd.com/us-en/drivers_catalyst.aspx
vladd is offline
post #1159 of 4297 Old 04-28-2010, 11:42 PM
ken.s's Avatar
finally , they released this HDMI driver officially .
I've verified the HDMI driver weeks ago, but cant talk about it publicly .
ken.s is offline
post #1160 of 4297 Old 04-29-2010, 04:20 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Well, I still need my override though. My Denon can't handshake with the ATI card when switching, maybe because it's an old model. But TrueHD problem is solved once and for all so I'm using an EDID override without the TrueHD SAD fix.
Tulli is offline
post #1161 of 4297 Old 04-29-2010, 06:46 AM
jimwhite's Avatar
Silent Stream bug?
Jim White
St. Petersburg, FL
jimwhite is offline
post #1162 of 4297 Old 04-29-2010, 06:52 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by jimwhite View Post
Silent Stream bug?
No joy ... still there.
Tulli is offline
post #1163 of 4297 Old 04-29-2010, 10:42 AM
GreenEyez's Avatar
Yup, works for my Denon 1610 too. Ati should pay you 6 months salary for the work you`ve done until they finally sorted this out.
GreenEyez is offline
post #1164 of 4297 Old 04-29-2010, 06:48 PM
daril's Avatar
I'm using a ati 5450 on my Samsung LN-32R7 (all code is LN32R71BAX1XB6) and a Denon AVR 1610
Is there any mod I can use for this combination?
If not, could you please make one for me Tulli???
thanks a lot and thanks for all your work on this topic!!!
Dario.
daril is offline
post #1165 of 4297 Old 04-29-2010, 08:32 PM
vladd's Avatar
Liked: 39
Dario.
um.... have you tried 10.4? You should only need an override if you have a video issue now.
Enjoy!!!
vladd is offline
post #1166 of 4297 Old 04-30-2010, 06:33 AM
daril's Avatar
It's Working!!!!
Thanks a lot!!
Dario.
daril is offline
post #1167 of 4297 Old 05-02-2010, 09:17 AM
nc88keyz's Avatar
Quoted: 178 Post(s)
Liked: 98
Last night i upgraded from the 8600GTS silent pipe III from gigabyte to an HIS 5770 for my HTPC. Newegg hooked me up for 130 and free 4GB flash card.
I am very pleased with the HTPC video upgrade.
I have a Mits 73835 and a Sony STR-5300ES
I didnt see my edid combo listed so i suppose i will have to make one and post it.
My issues are this though. I have a htpc touchscreen case so that is two monitors vs one to deal with and I am somewhat confused with the instructions. Which program should work better then entwain one or vlad's.
i am using the 10.4 catalyst driver and dts-ma was working with avatar 1080p.mkv (test file) however my batman hd-dvd is not working in tmt3 with latest update.
it says hdmi out is selected but its just doing dts or something.
Im not a perfectionist but I would like to hear the very best bitstreaming option available to me for my avr.
it says truehd on the tmt3 but its not displaying on the avr,
In this case, i think 10.4 has fixed some stuff but maybe not for the hd-dvds.
I might buy my first bd disc this coming week to see what i have been missing.
Does it sound like i am in need of the edid override at this point:?
One thing is sure the Audio is very much crisper going out via hdmi vs coaxial onboard sound.
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NV SHIELD(2D)Haswell NUC i5(3D)
HT2: OLED65G6P, AVR: AVRX3300, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2, NV SHIELD(2D) Zidoo X9S(3D)
HT3: OLED55C6P, AVR NR6700 L/R/S, NV SHIELD(2D)
18 Hybrid Raid, (It Just Works!!) R/C: Harmony Elite HarmonyOneX2
nc88keyz is online now
post #1168 of 4297 Old 05-02-2010, 09:28 AM
Davinleeds's Avatar
TMT only plays HDDVD in pcm. Use BD to check for proper True HD and DTS HD MA playback.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #1169 of 4297 Old 05-02-2010, 03:54 PM
nc88keyz's Avatar
Quoted: 178 Post(s)
Liked: 98
good to know ....
guess we are lucky they still have support for hd-dvd
post #1170 of 4297 Old 05-03-2010, 07:09 AM
David Bott's Avatar
Liked: 45
Hi All...
Card ATI HIS 5670
OS - Vista 64 Bit
Drivers - Current 10.4
Software - TMT3 (Current)
Receiver - Anthem D2V
Projector - Runco VX22DC
2 Issues I am running into...
1) If I sent TMT3 to output LCPM, It will output LPCM 48K 7.1 (Highdef audio already decoded by the card.) and the receiver sees 7.1 48K. However, if I try to send the bitstream to my Anthem so the Anthem will decode it, it is not sure what it is seeing and thus no sounds.
2) I usually leave the HTPC running all the time and just shut down the Anthem D2V, amps, projector, etc. If I turn off the Anthem D2V and then back on, I have video, but the computer drops the HDMI audio and stats shows "Not Connected" If I reboot the computer with the Anthem D2V already on , all is well again until I turn off the Anthem. Even if I have the HTPC on, and the Anthem D2V on and pull the HDMI cable and then put it back in, video comes back but not audio.
Note that the driver software reports it sees an AVR50 as the monitor. Anthem did say this was normal it says that as they have standardized on just one name for the handshake.
Any help would be great.
Thank you,
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
Reply Home Theater Computers
