EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 02-04-2011, 05:35 AM
Nenco's Avatar
Originally Posted by Tulli View Post
Post both EDIDs to do the merge. Maybe it'll work as you say but only real way to know is by testing it so let's give it a try.
I only have a denon avr 2310, must find somebody with maratz sr 5004
edit: maybe you are talking about avr and tv edid, i will post it tonight
Nenco is offline
Old 02-04-2011, 08:34 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Correct, that's what I meant (TV & AVR full 256-byte EDIDs).
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 02-04-2011, 09:53 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1058 Post(s)
Liked: 987
5004's scaler can't handle 3d, it must be disabled (or receiver turned off) in order for 3d to pass throuh, thats why i think it's an edid issue
My point was that a receiver that has a scaler that CAN handle 3D most likely isn't going to have an issue with passing 3D formats through in the first place. This was directed at the poster who was suggesting that the scaler might be converting 1080p 3D to 720p 3D - any receiver with a scaler with that sort of capability is going to be HDMI 1.4 (or higher). So in other words, if the receiver is marketed as fully supporting 3D and has HDMI 1.4, we probably wouldn't be having this conversation .
gsr is offline
Old 02-04-2011, 10:45 AM
Nenco's Avatar
uploaded
@gsr
Denon avr2310 Samsung ps50c7000.zip 1.236328125k . file
Samsung ps50c7000.zip 1.185546875k . file
Nenco is offline
Old 02-04-2011, 11:37 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
uploaded
@gsr
Merged ...
Samsung PS50C7000 - DENON 2310.zip 1.2373046875k . file
Tulli is offline
Old 02-04-2011, 12:37 PM
Nenco's Avatar
Merged ...
IT WORK
I just have to switch to another source and back
Thank you very very very much!!
http://www.youtube.com/watch?v=MkagVft8r1s
http://www.youtube.com/watch?v=RM_Aa89iMrw
Nenco is offline
Old 02-04-2011, 01:21 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Is that 1080p 3D?
Tulli is offline
Old 02-04-2011, 01:28 PM
Nenco's Avatar
Is that 1080p 3D?
Yes, because is automatically detected by tv
Nenco is offline
Old 02-04-2011, 01:45 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
So I have to ask: do we really need an HDMI1.4 AVR to get 3D with an HTPC? If the answer is "no" this is really a BOMB! Are there not any qualifications/limitations?
Tulli is offline
Old 02-04-2011, 01:56 PM
Nenco's Avatar
3d support for hdmi is just metadata, this is known, look at ps3 and ati cards
now you must rename your thread
Nenco is offline
Old 02-04-2011, 02:00 PM
Davinleeds's Avatar
My understanding is you need the right TV. A 1.4 AVR is just if you want audio/video through one cable.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
Old 02-04-2011, 02:05 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Ouch! I've been quite happy with two or three mods a day but this would only mean hard work (again!) And it would even be hack-work too!
Let's hope nobody notices it!
Tulli is offline
Old 02-04-2011, 02:13 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Yes, and now it seems you can go full 3D over an HDMI1.3 AVR through one cable with an EDID override.
Tulli is offline
Old 02-04-2011, 02:20 PM
Davinleeds's Avatar
Set up a PayPal account
Old 02-04-2011, 02:29 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Hey, vladd, want to join in?
Tulli is offline
Old 02-04-2011, 04:54 PM
darkvoice's Avatar
Descriptors in the EDID Extension Block were not in the standard order. I don't know if this will affect ATI's parsing of the EDID, but I attach the modded EDID with descriptors reordered in the standard way.
Sorry to bug you guys again, but isn't there any way to edit this inf by inserting also the 3d field support data? I see they're still missing and might be the ones who might fix my 3D
darkvoice is offline
Old 02-04-2011, 05:17 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
All information is there AFAIK. But you could just use the real-time captured EDID of your TV.
Are you sure that you applied the EDID override to the right GenericPnP monitor? It must be applied to the one associated to your TV. You can check that by right-clicking on the GenericPnP device->Properties, then select the Details tab and then choose "Manufacturer" from the Property drop-down menu.
Tulli is offline
Old 02-05-2011, 01:04 AM
darkvoice's Avatar
Yes man, sadly i'm sure i applied the inf to the right display. But i opened the inf with moninfo and 3d support info seem to be still missing. Here's a small paste of it.
3D formats supported..... Not supported
Data payload............. 030C001000382DA06565D004014001FF
That's pretty identical to the standard one, even if, as you said, you reordered the data in the edid.
I see other 3D infs having these data instead:
3D structures supported.. Top-and-bottom, Side-by-side w. horizontal sub-sampling
3D formats supported..... Mandatory formats plus some primary VICs
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
Data payload............. 030C002000B82D20D0040140073F
I don't seem to be able to import such info to my inf instead, sadly. Still assuming that such data might fix my odd issue with 3D. I hope that's my only and last chance, else i guess i have to give up
Old 02-05-2011, 01:15 AM
vasishta.sushant's Avatar
I was having a hard time trying to get this combination working and had lost hope before I ended up here.
Please help me with this combo.
The INF files are attached.
Attachment 200757
LG KH70YR - Onkyo 3300 (HT-R380).zip 2.4287109375k . file
vasishta.sushant is offline
Old 02-05-2011, 05:47 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Ok, try the attached mod. I replaced the Philips VSDB with the one from Nenco's Samsung's 3DTV (see above) that worked fine for him.
3DTV Philips 8605M - Samsung 3D VSDB.zip 1.2470703125k . file
File Type: zip 3DTV Philips 8605M - Samsung 3D VSDB.zip (1.2 KB, 31 views)
Tulli is offline
Old 02-05-2011, 06:00 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Attachment 200757
Mod attached ...
LG LH70YR - ONKYO HT-R380.zip 1.2451171875k . file
Tulli is offline
Old 02-05-2011, 09:18 AM
Mod attached ...
Thanks for a quick turn around. That was indeed impressive.
But somehow this thing is not working still.
I am on Win 7 x64 and using PowerDVD 10. Have ATI 5770 with 10.12 installed.
With the DTS HD, I can see the information being displayed as DTS HD but on the AVR I can see only DTS logo.
And with the DD MA, I am not even seeing anything even in the PowerDVD somehow.
Can you suggest what needs to be done ? I don't mind even re-installing the Windows, if need be.
Old 02-05-2011, 09:52 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Did you reboot after installing the EDID override? If on a dual monitor setup, check that it's applied to the right GenericPnP monitor.
Do you see all audio formats on the "Supported Formats" tab of the ATI HDMI control panel?
For PDVD, do you get the third audio option during playback?
What version of PDVD10 do you have? It must be 10.0.2429.51 to work on Cat 10.12.
Tulli is offline
Old 02-05-2011, 08:10 PM
GregoryRB's Avatar
I have successfuly installed the EDID overide and specified in this forum. The overide was successful, and I am very pleased to have HD bitstream audio finally working.
I have notived however a deterioration in video quality ( especially bright light scenes) and would like to ask if the overriding of EDID, can also be responsible for this video degradation.
Maybe some sort of data exchange is no longer possible and hence an optimised picture is no longer being sent from the PC to the Screen
Looking forward to a response.
GregoryRB
GregoryRB is offline
Old 02-05-2011, 09:48 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
GregoryRB
What specific video degradation? Did you install an EDID override with the exact or compatible video data of your display device?
Tulli is offline
Old 02-06-2011, 03:24 AM
tecram's Avatar
Hello,
I have a problem with my HTPC. I purchase an Asus 5670 1 Gb, and I can't config DTS HD or other HD format. I have an HDMI cable from Asus 5670 to AVR (Marantz SR5003), and output goes to Pio 5090H. In ATI HDMI Output, in speaker config I see 4, 5.1 y 7.1, but in Properties, I don't see DTS HD-MA or Dolby TrueHD modes, only DTS, Dolby and WMA (AVR supports HD modes).
I have Vista32, CCC 11.1 and HDMI is 1.3b. EDID problem?
Very Thanks.
tecram is offline
Old 02-06-2011, 03:29 AM
mpall78's Avatar
Hello everyone!!
I've been following this thread for a long time, and decided to join the board because i'm having a few issues getting bitstream of TrueHD/DTS-HD signals work on my Sony VAIO VPCEC3S1E, with Ati Mobility Radeon HD 5650 and BD-ROM. I have an Onkyo HT-R380 fully connected to my laptop's HDMI port with an HDMI 1.4 cable. Multichannel 48khz/24-bit decoded by TMT 3 (rev. 180) works. But when i pause the movie, the software tries to send the TrueHD/DTS-HD signal to my receiver and i get a very loud white noise throughout my speakers. Whether with FFDSHOW + MPC-HC i can only get TrueHD decoded as PCM & DTS-core signals out of DTS-HD movie samples.
I've tried updating the EDID of my external monitor with one of the Onkyo HT-R380 EDID's posted here, and updated to Catalyst 11.1 but as said, i can only get PCM multichannel and DTS-core's.
In the ATI HDMI Audio properties i see HDCP supported, number of audio channels (2), 192khz/24-bit as the maximum for audio, and TrueHD/DTS-HD in the supported formats table. Knowing that the bitstream should apparently working with an 8-LPCM SAD modified EDID, which one of the many posted here should I use?? And how can i update the EDID of my Onkyo HT-R380 AVR to bitstream TrueHD/DTS-HD??
Thanks in advance!!
mpall78 is offline
Old 02-06-2011, 05:52 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by tecram View Post
Hello,
Very Thanks.
Vista is a problem in itself to get bistreaming of HD, so this is more driver/OS related. Try any of the EDID overrides listed (or posted along the thread) that best suits your Pio 5090H. If it doesn't work then search through the thread for Vista related issues. Otherwise upgrading to Win7 would be your best choice.
Tulli is offline
Old 02-06-2011, 05:57 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by mpall78 View Post
Hello everyone!!
Thanks in advance!!
Make sure that TMT3 has the latest patch applied. Your problem with pausing and getting noise could be related to this.
As for the EDID override you can try any of the listed/posted that is closest to your display device specs.
Tulli is offline
Old 02-06-2011, 07:35 AM
mpall78's Avatar
Many thanks for the reply, Tulli
I did install the latest patch of TMT 3 (rev. 180), but unfortunately that didn't resolve my issue.
I still cannot bitstream neither TrueHD or DTS-HD files of any sort. Unfortunately i don't have a second monitor/TV to hook up and try out. But, if it's possible to get bitstreaming working on the machine itself, without hooking a TV/monitor of any sort, i would be more than glad.
As said, I installed the latest Catalyst 11.1 and the latest Realtek 2.55 ATI HDMI Audio, and I can only get multichannel 48/24 just fine. You said it was possible to apply an EDID override only to the receiver and get bitstreaming working so, how do i do that?? I cannot apply the edid override of the Onkyo HT-r380 to the HDMI AUDIO driver, unfortunately
Thanks in advance!
mpall78 is offline
