EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #241 of 4294 Old 02-24-2010, 02:16 PM
vladd's Avatar
Liked: 39
Originally Posted by Tulli View Post
Samuri, IT WORKS!!!
Just replaced one byte in my DENON 988 EDID to enable 192khz support for TrueHD and that DID IT!
Thanks a bunch to rasmusb and to you for pinpointing the EXACT problem.
So, ladies and gents, mystery solved: ATI is INNOCENT!, or too picky?, for taking too literally (is that a bug?) a FAULTY AVR EDID value.
Now, what about other failing AVRs? Took a look at the failing ONKYO TX-SR875 EDID, and sure enough TrueHD/192Khz is marked as not supported there.
Can't find a couple of SONY AVR EDIDs that I had but this is the issue. OTH Checked one Yamaha and Pioneer AVRs EDID and TrueHD/192khz is marked supported in both.
Great, now that we know the exact issue, I can probably do the fixes programmatically. I would just need to parse the EDID and check the audio block. Tulli won't have to spend his free time making mods.
I'm not sure when I could get it done though. Leaving for vacation on Sunday and I'm trying to wrap up a bunch of stuff.
vladd is offline
post #242 of 4294 Old 02-24-2010, 02:24 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Ha, Ha, that's what I reallly call a FIX! ...
Just checked the failing Sony STR-DN1000 and again, TrueHD/192Khz not supported, but here 2 DTS HD descriptors, and the one with 8 channels has 192khz not supported, so you will have to program to fix that too, vladd ...
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #243 of 4294 Old 02-24-2010, 02:31 PM
vladd's Avatar
Liked: 39
Yeah, I'm figuring that I'll just check to see if a TrueHD entry exists. If it does, I'll know the receiver supports TrueHD. I'll then remove all TrueHD entries (in case there is more than one) and set a single entry with 192/8ch. Then do the same for DTS-HD.
I can probably even implement the override settings programatically so it's pretty much a "one click" solution.
vladd is offline
post #244 of 4294 Old 02-24-2010, 02:35 PM
Davinleeds's Avatar
Isn't 192 for 2 channel?
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #245 of 4294 Old 02-24-2010, 02:35 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
No. The Divertimenti BD, for instance, has 5.1 192Khz DTS HD & TrueHD tracks.
Tulli is offline
post #246 of 4294 Old 02-24-2010, 02:38 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Or maybe just check up for that byte "1E" in each case and replace it with "5E" (or "7E" to include 176.4 Khz too). That's what I manually did.
Otherwise you'll have to keep track and update the Audio Data Block Length, and the Detailed Timing Descriptors Begin Offset, (and the checksum of course, which is no issue, obviously, for you).
Tulli is offline
post #247 of 4294 Old 02-24-2010, 02:48 PM
Davinleeds's Avatar
DTS-HD Master Audio Features
• Lossless Audio with variable data rates up to 24.5 Mbps for Blu-ray Disc and up to 18.0 Mbps for the
HD DVD format
• Up to 7.1 discrete channels with a sampling frequency of 96 kHz and 24 bits of signal resolution
• Up to 192 kHz sampling frequency and 24 bits of signal resolution for 2.0 channels
• Speaker Re-mapping with multiple speaker playback configurations for 7.1 channel systems
• Secondary Audio/Sub Audio Stream for supplemental audio content*
I haven't checked Dolby. This is from DTS HD Whitepaper pdf page 6.
Dolby has 5.1 support with 192.
Supports Blue-ray Disc’s standard eight full-range channels of 24-bit/96 kHz audio, and up to 5.1 channels of 24-bit/192 kHz audio
post #248 of 4294 Old 02-24-2010, 02:55 PM
SamuriHL's Avatar
Samuri, IT WORKS!!!
SWEET!!!!!!! That's awesome! This is very big news.
SamuriHL is offline
post #249 of 4294 Old 02-24-2010, 03:01 PM
vladd's Avatar
Liked: 39
Otherwise you'll have to keep track and update the Audio Data Block Length, and the Detailed Timing Descriptors Begin Offset, (and the checksum of course, which is no issue obviously for you).
I would need to track them anyway. It's possible to have "1E" in other sections of the EDID.
vladd is offline
post #250 of 4294 Old 02-24-2010, 03:03 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
HD DVD format
Thx, Davin!
Tulli is offline
post #251 of 4294 Old 02-24-2010, 03:29 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Yes. But here's a possible algorithm:
Skip first 4 bytes of the Extension block.
Extract video_block_number_of_bytes in byte 5.
Skip video_block_number_of_bytes bytes.
Extract audio_block_number_of_bytes
/* Now each audio descriptor is 3 bytes and the codes we're looking for are:
TrueHD 6 =
65
TrueHD 8 = 67
DTS HD 6 = 5D
DTS HD 8 = 5F
Next byte is the 192khz byte to be changed to 5E (or 7E) */ For i = 1 to audio_block_number_of_bytes
If audio_block_descriptor_code is not ('65' or '67' or '5D or '5F')
skip 2 bytes
else
read next byte and set it to '5E' (or '7E' if you like to enable all formats)
skip 1 bytes
Well, more or less, you get the idea and do it right, vladd ...
Tulli is offline
post #252 of 4294 Old 02-24-2010, 03:39 PM
vladd's Avatar
Liked: 39
Yeah, that's basically what I was going to do. When I said "parse the EDID" I actually meant just enough to get the audio block.
Nice little algorithm. You just saved me some time.
vladd is offline
post #253 of 4294 Old 02-24-2010, 03:53 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
I attach some faulty EDIDs so you can test ...
FAULTY EDIDs.zip 0.9013671875k . file
File Type: zip FAULTY EDIDs.zip (923 Bytes, 24 views)
Tulli is offline
post #254 of 4294 Old 02-24-2010, 04:36 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
@Beamer
Can you capture and post your AVP A1 EDID? It is most likely that the last firmware update fixed the "192Khz/TrueHD non supported" issue with DENONs.
Tulli is offline
post #255 of 4294 Old 02-24-2010, 05:51 PM
vladd's Avatar
Liked: 39
I just looked at this EDID. Did DTS-HD bitstreaming work with this receiver without an override? I'm guessing not. They have the two DTS-HD descriptors as you said and they have a "Dependent format" code for DTS but according to the audio block, the receiver cannot bitstream DTS (no descriptor for it).
vladd is offline
post #256 of 4294 Old 02-24-2010, 06:37 PM
blackcell's Avatar
Quoted: 13 Post(s)
Gee, with all this EDID excitement I just wanted to check for those of us who already applied the EDID mod and have DTS-HD/TrueHD working just fine we can ignore the excitement?...though good job on root causing!
blackcell is offline
post #257 of 4294 Old 02-24-2010, 06:38 PM
SamuriHL's Avatar
If it works.....isn't that what matters? Finding the root cause, however, allows them to fine tune the EDID override process. And maybe even automate it. But for those who have it working, meh.
SamuriHL is offline
post #258 of 4294 Old 02-24-2010, 06:46 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Absolutely, vladd. Sonys have the worst EDID structure that I've checked so far.
Tulli is offline
post #259 of 4294 Old 02-24-2010, 06:48 PM
vladd's Avatar
Liked: 39
Yeah, what he said.
vladd is offline
post #260 of 4294 Old 02-24-2010, 07:07 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1092 Post(s)
Liked: 1073
@Beamer
I just did the following:
1) Uninstall EDID override monitor driver.
2) Uninstall existing ATI driver, etc.
3) Install Catalyst 10.2 (including the ATI HDMI audio driver since I'm using ArcSoft TMT)
4) Tested Dolby True HD - no sound, but TMT reported pass through mode
5) Tested DTS HD Master Audio - worked fine
6) Updated my Denon AVP-A1HDCI to the latest firmware (I already had the DL4 update, so I wasn't too far behind).
7) Tested Dolby True HD - no sound, but TMT reported pass through mode
8) Tested DTS HD Master Audio - worked fine
9) Reinstalled the EDID override monitor driver.
10) Tested Dolby True HD - worked fine
11) Tested DTS HD Master Audio - worked fine
Attached is the output of Vladd's GetEdid tool from the Denon AVP-A1HDCI with the latest firmware update installed.
Hopefully this info is useful.
DENON-AVAMP.0.2_LatestFirmwareAsOf20100224.zip 1.2119140625k . file
File Type: zip DENON-AVAMP.0.2_LatestFirmwareAsOf20100224.zip (1.2 KB, 27 views)
gsr is offline
post #261 of 4294 Old 02-24-2010, 07:48 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Thx a lot, gsr. The EDID you captured just confirms the results of your testing, as the faulty TrueHD 192khz audio descriptor is still there .
Tulli is offline
post #262 of 4294 Old 02-24-2010, 07:50 PM
blackcell's Avatar
Quoted: 13 Post(s)
Agreed. Just was curious if a further mod was necessary on those rare files with 192Khz. In my line of work, "working" versus "working properly" can be two entirely different matters .
post #263 of 4294 Old 02-24-2010, 08:02 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
No, any new mod based on these new findings won't affect any current audio functionality.
Tulli is offline
post #264 of 4294 Old 02-24-2010, 08:42 PM
BigZAJ's Avatar
For TMT3 to work correctly with True HD Audio I need to use the EDID override correct and the ATI HDMI driver, not the realtek HDMI driver?
BigZAJ is offline
post #265 of 4294 Old 02-24-2010, 08:49 PM
vladd's Avatar
Liked: 39
Correct. You need the ATI driver and in your case, you will most likely need the override because you have a Denon.
vladd is offline
post #266 of 4294 Old 02-24-2010, 09:03 PM
Smitty2k1's Avatar
Great work everyone!!
Smitty2k1 is offline
post #267 of 4294 Old 02-24-2010, 09:05 PM
BigZAJ's Avatar
I have the Pioneer Display / Denon EDID override from the first page. I also have catalyst 10.2 installed with the ATI HDMI Driver as well as TMT .170.
When I select to use "original primary audio" it shows as DTS-HD MSTR Pass Through, however I have no audio and video playback is very choppy. Using TMT it shows the stream at about 6-9mbps, if I select DTS Mix audio kicks back in and the stream goes up to 20-30mbps.
BigZAJ is offline
post #268 of 4294 Old 02-24-2010, 09:10 PM
vladd's Avatar
Liked: 39
That sounds like the same thing that happens when using the RealTek drivers. What driver version/date does it show in Device Manager?
vladd is offline
post #269 of 4294 Old 02-24-2010, 09:15 PM
BigZAJ's Avatar
Driver Provider:
ATI Technologies, Inc.
Driver Date:
2/2/2010
Driver Version:
8.702.0.0
BigZAJ is offline
post #270 of 4294 Old 02-24-2010, 09:21 PM
vladd's Avatar
Liked: 39
Driver Provider:
Driver Date:
2/2/2010
Driver Version:
8.702.0.0
Did you install the 10.3 beta by any chance? The 10.2 driver should have a date of 1/21/2010 and a version of 7.11.0.7703
If you still have the extracted drivers, try doing a driver update and specifying the drivers to use. Point the "update" to:
Code:
C:\\ATI\\Support\\10-2_vista64_win7_64_dd_ccc_wdm_enu\\Packages\\Drivers\\WDM\\HDMICE\\[OSVersion]
or wherever you extracted the drivers. Replace "[OSVersion]" with the folder for your OS. For me it was ...\\HDMICE\\WIN64a
vladd is offline
Reply Home Theater Computers
