No 5.1 over HDMI through tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-21-2010, 11:31 AM - Thread Starter
joemoma's Avatar
As described in the title I can't get 5.1 over HDMI through my TV. Setup is Acer Aspire Revo AR1600-U910H (HDMI)> T.V.Samsung 50-inch PN50B530 (optical) > receiver. In case you're wondering the receiver is older and does not have a HDMI input. According to the to the T.V. manual is should be able to pass 5.1 over the optical but the option is not available in windows. I'm running windows 7 and the NVIDIA HDMI out only has 2 channel available. I'm assuming this is because the T.V. only had two speakers and HDMI is two way. My question is how can I tweak/trick the NVIDEA card into sending 5.1.
Thanks for any help you can give. Movies in 2.0 a bummer.
joemoma is offline
post #2 of 4 Old 02-21-2010, 11:36 AM
whiteboy714's Avatar
Some tv's can only pass 5.1 over optical when you are using the tv tuner. As in OTA, QAM, etc. You may want to confirm if this is the case with yours.
whiteboy714 is offline
post #3 of 4 Old 02-21-2010, 01:28 PM - Thread Starter
joemoma's Avatar
Upon further review you are correct. Thanks for the help.
When the receiver (home theater) is set to On, you can hear sound output from the TV's Optical jack. When the TV is displaying a
DTV(air) signal, the TV will send out 5.1 channel sound to the Home theater receiver. When the source is a digital component such
as a DVD and is connected to the TV via HDMI, only 2 channel sound will be heard from the Home Theater receiver.
If you want to hear 5.1 channel audio, connect the DIGITAL AUDIO OUT (OPTICAL) jack on the DVD / Blu-Ray player or Cable/
Satellite Box directly to an Amplifier or Home Theater, not the TV.
joemoma is offline
post #4 of 4 Old 02-21-2010, 02:21 PM
bighick's Avatar
Why don't you just use the optical out on the revo? If you have one that doesn't have otpical i read under 1 of the stickers it is there and works...not sure if its true.
bighick is offline
Reply Home Theater Computers
