Why can't I program a button to scale 16:9 TV in MPC-HC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-25-2010, 11:17 AM - Thread Starter
S2G-Unit's Avatar
Quoted: 16 Post(s)
In MPC-HC there's a Pan&Scan option to "Scale to 16:9 TV". However there is no way to program a simple button on the keyboard to get that option.
My workaround for now is to use the "increase height" & hit that button a few times to fix it for 2.35 movies in my Anamorphic setup.
Any ideas?
S2G-Unit is offline
post #2 of 5 Old 02-26-2010, 09:54 PM
randy5554's Avatar
I'd like to know too. I use an Ipod Touch wi-fi remote, and I hate having to switch to the mouse function to right click to select this option (running MPC on my 1024x768 plasma).
randy5554 is offline
post #3 of 5 Old 02-26-2010, 10:34 PM
nightfly85's Avatar
Quoted: 71 Post(s)
Liked: 41
I do the same thing for my Lens/Anamorphic setup.
Having video size presets selectable via hot-key would be awesome. Also filter setup per sub-type would be another big plus.
nightfly85 is offline
post #4 of 5 Old 02-27-2010, 07:39 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
Originally Posted by S2G-Unit View Post
In MPC-HC there's a Pan&Scan option to "Salce to 16:9 TV". However there is no way to program a simple on the keyboard to get that option.
My workaround for now is to use the "increase height" & hit that button a few times to fix 2.35 movies in Anamorphic setup.
Any ideas?
I'm doing this via Event Ghost, my remote is a PDA running NetRemote. I found an updated plugin for Event Ghost where someone had added the "Scale to 16:9" function.
You could also ask the MPC-HC guys to add a keyboard shortcut for that function into a future version.
JDLIVE is offline
post #5 of 5 Old 02-26-2012, 08:50 AM
robl45's Avatar
Quoted: 167 Post(s)
this is finally fixed if anyone is still interested
https://sourceforge.net/apps/trac/mpc-hc/ticket/355
you can get the executable in that link. then in the player history you can check save pan and scan setting, I just tried it, it works. executable is in like 3rd comment.
robl45 is offline
Reply Home Theater Computers
