Rii Mini Wireless Keyboard - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 01-28-2011, 01:56 PM
kapone's Avatar
Quoted: 260 Post(s)
Liked: 209
Originally Posted by LOTL View Post
My 2.4 Rii knockoff from Amazon wont wake my HTPC
Originally Posted by MarcSparks View Post
My 2.4Ghz Rii from Amazon wakes my PC up from S3 just fine
Hmm.......moral of the story??
kapone is offline
Old 02-14-2011, 02:40 PM
updawg86's Avatar
has anyone come up with an s3 resume fix with this. The receiver light just turns off. But my other mouse can wake this just fine.
updawg86 is offline
Old 03-17-2011, 11:40 AM
smetoyer's Avatar
I'm getting really horrible range on this thing; around 6 or 7 feet with nothing blocking the line of sight. Is this typical? Also, I've noticed that if my left hand covers the upper left hand corner of the unit, range drops down to just like 3 feet.
I want to see if anyone has a similar experience before I return it.
smetoyer is offline
Old 03-17-2011, 12:02 PM
Latenter's Avatar
Do you have the RF or bluetooth version? I have the bluetooth one, but it's an issue with the dongle, not the keyboard. Plugged in to my laptop it's the same, around 6 ft range, but when it's paired with my PS3 I can use it in the next room 20+ feet away. I think I'm going to try to find a better bluetooth dongle and hope it fixes the problem.
Latenter is offline
Old 03-17-2011, 12:43 PM
lashag's Avatar
I just rec'd mine today from Amazon, seems to work okay, however when I switch to off it still is on...am I missing something?
lashag is offline
Old 03-17-2011, 12:46 PM
joners's Avatar
How do you know if it's a knock off?
I found on locally on a classified site for $35 new in the box....really tempting but if it's a knock off, I really need it to wake from standby. lol
joners is offline
smetoyer's Avatar
Unfortunately, I have the RF one. The receiver is down at floor level; I'm going to try to put it up at TV / couch level with an extension and see if that helps.
smetoyer is offline
Old 04-01-2011, 08:51 PM
wsumarine's Avatar
I just got mine today (the RF version), through Amazon, I gave it a full charge before attempting to use it. I plugged the dongle into my laptop's USB port and it loaded the drivers. After that I turned the keyboard on and...nothing. it won't connect. It's about six inches away from the dongle. The keyboard backlight just blinks on and off every few seconds. I tried changing the channel, but I still can't get it to connect (at least I don't think it will. The RF light on the keyboard is orange, and they green light on the dongle flickers when I plug it into the USB port, but nothing after that.).
Any advice?
wsumarine is offline
Old 04-02-2011, 06:29 AM
Sammy2's Avatar
Quoted: 516 Post(s)
Liked: 251
Try putting the USB dongle in a different port or even just unplugging it and plugging it back in the same port. You should see a notification balloon telling you that the drivers are being installed when you plug it in.
Sammy2 is offline
Old 04-02-2011, 08:03 AM
wsumarine's Avatar
I tried several different USB ports, and nothing happened. I plugged it into my wife's laptop and it loaded the drivers (just as on mine), but once they were loaded it did nothing. The back light kept blinking and it wouldn't link up with the dongle.
If I plug in the dongle and open devices and printers, the micro keyboard shows as a device.
Old 04-02-2011, 08:20 AM
Sammy2's Avatar
Quoted: 516 Post(s)
Liked: 251
It appears to be the keyboard and not the dongle.
Sammy2 is offline
Old 04-02-2011, 08:29 AM
wsumarine's Avatar
That makes sense...seems like it may need to get exchanged. If i get one that works I think this thing will be pretty sweet. It's the perfect size.
Old 04-02-2011, 08:35 AM
Sammy2's Avatar
Quoted: 516 Post(s)
Liked: 251
I've had good luck with this one but it doesn't seem to be RF because when I put the dongle on the back of the HTPC it didn't work and if I use it with anything in the way it is a bit glitchy. Other than that it has performed well.
Sammy2 is offline
Old 04-02-2011, 03:50 PM
olyteddy's Avatar
Quoted: 526 Post(s)
Liked: 925
Is there some kind of 'Synch' or 'Connect' button on the keyboard? My Acer keyboard has one.
Woobieizer likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
Old 04-02-2011, 09:30 PM
none74's Avatar
I tried that, made no difference with mine, terrible range. Too bad too, the setup and features are perfectly tailored to HTPC use, especially the backlight...
none74 is offline
Old 04-05-2011, 08:54 AM
teknikk7's Avatar
So I got the Rii N7, love the keyboard. I hate the range, it is horrible. I even got a 10' USB extension and ran the USB dongle near my couch, Still bad.
I popped the cap off the USB dongle and the antenna is pathetic. I see a lead point and am going to try and solder a copper wire onto it. 30mm is ideal but I am not sure I want a straight wire coming out of this thing. I may just try some speaker wire to start and see how it goes. Others are reporting improved range just by wrapping some copper wire around the end of the dongle.
If I decide to try this I will post pics and my results.
teknikk7 is offline
Old 08-01-2011, 06:02 PM
nobb1's Avatar
I just got this for my CarPC. What a POS...I regret getting rid of my Dinovo Mini. Everything seems to work alright...but 5 minutes into operation and the damn thing just seems to disconnect. Only way to fix it is unplug and replug it in. Anyone else have this problem?
nobb1 is offline
Old 09-20-2011, 12:06 PM
zorangl's Avatar
Did you have any success with that?
zorangl is offline
Old 10-23-2011, 08:55 AM
leviathan18's Avatar
Hi guys I have an asrock vision 3D with a rii 2.4 ghz wireless keyboard, my issue with this thing is that it wont wort with the htpc, but it will work perfectly with the laptop so I dont know what to do. In the htpc says usb host controller driver not found, in my laptop it recognize the HID keyboard and HID mouse at the moment in connected the usb dongle.
Any ideas ?
leviathan18 is offline
Old 10-23-2011, 01:03 PM
none74's Avatar
Any ideas ?
Same OS on both computers ?
If not, I'd consider putting the OS that recognizes it on the HTPC, if that's an impossibility, then it seems its a driver issue and you'd need to hunt down the drivers and install them manually via Control Panel/Device Manager. The device should be in Device Manager now as an "Unknown Device" ....
none74 is offline
Old 10-23-2011, 09:30 PM
yes both running windows 7 64bits, both updated I really don't know why the HTPC is behaving like this.
it doesnt say exactly unknown device only usb host controller problem is kinda weird.
Old 10-24-2011, 05:26 AM
none74's Avatar
Is it the same chipset in both computers ? That's unlikely since one is a laptop and one is a desktop...If they're different, try getting the drivers for the chipset that is acting up from the manufacturer instead of using the ones Win7 installed automatically.
none74 is offline
Old 10-24-2011, 09:34 PM
Thanks none74 I kinda feel like an idiot for not trying that one. Now it works like a charm, I will be able to enjoy more my little htpc
Great mini keyboard, glad I got it.
Old 04-29-2014, 05:08 PM
Woobieizer's Avatar
Quoted: 479 Post(s)
Liked: 227
Old advice is still relevant advice. Thanks olyteddy!!
Left: Put in use 29th April 2014
Upgrade Version! Rii® i8+ Wireless 2.4G Mini Keyboard
Right:
Hausbell Wireless 2.4G Mini Keyboard
Hold both FN + RF (F1) to synch
Woobieizer is offline
Old Today, 12:37 PM
Liked: 0
How to turn off Change Keyboard Notification?
I've got an M8R 4K Android box that I've had for about a year. I bought the Rii mini i8 wireless keyboard (Bluetooth) and everytime it goes into sleep mode (about every 5 minutes), a pop-up comes up in the center of my TV that says Change Keyboard (because the keyboard un-syncs). This is a major annoyance and I found a solution shortly after I got this and problem was solved. Well, I recently had to completely reinstall Android on this box and its happening again! Only this time I cannot find the previous solution anywhere on the web. This is driving me nuts and is almost impossible to watch a movie when this pops up and covers the screen until you wake the keyboard again and exit out of the notification.
If I remember correctly, there was a way to turn off this notification altogether and it didn't matter if the keyboard went to sleep, or was completely turned off. Please help! This is unbearable. I've attached a screenshot to show what's happening. Thanks!
Matt Harville is online now
