* Official * Cyberlink PowerDVD 10 Ultra thread - Page 35 - AVS Forum | Home Theater Discussions And Reviews
post #1021 of 1609 Old 09-13-2010, 09:55 AM
SamuriHL's Avatar
Originally Posted by CyberlinkUSA View Post
I'll have to check.
Tom
Thank you, Tom. I know this is a question that's likely to come up so that would be appreciated.
And the more I look at that nVidia 450, the more I'm liking what I see. The only wrench that can be thrown into that decision is the AMD 67xx cards. This is truly awesome to see the competition shake out like this.
SamuriHL is offline
post #1022 of 1609 Old 09-13-2010, 09:56 AM - Thread Starter
CyberlinkUSA's Avatar
Originally Posted by babgvant View Post
Has anyone published power numbers for HTPC use?
I'm not aware of any power figures for HTPC use (sounds like an opportunity for the Missing Remote). I was only reflecting on my personal experience with the Fermi boards. Both the GTX 470 and the GTX 460 have been quiet as a church mouse while playing Blu-ray 3D. Of course, the 470 requires a bigger power supply... which is more challenging for an HTPC setup. I just wanted to let people know that these boards might be good options for those who want to have good gaming capability in their HTPC. If gaming performance doesn't matter to you, the GTS 450 would be the better choice at this point.
Tom
CyberlinkUSA is offline
post #1023 of 1609 Old 09-14-2010, 01:47 AM
gtgray's Avatar
Quoted: 226 Post(s)
Liked: 146
Does Cyberlink and Nvidia with the new card/drivers support checkerboard output?
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #1024 of 1609 Old 09-14-2010, 07:17 AM
babgvant's Avatar
Liked: 30
Agreed, although for pure HTPC use I think the 430 (and lower) will probably be of greater interest. The 450s I've seen have been dual slot cards w/ external power requirements. No way to use that w/ my pico PSU
babgvant is offline
post #1025 of 1609 Old 09-14-2010, 07:46 AM
swoon!'s Avatar
For HTPC, we're supposed to see the GF108 Nvidia-based cards within a month or two and I've read the 6xxx series isn't far behind.
Aaron Ledger - Senior Design Engineer, Ceton Corp.
swoon! is offline
post #1026 of 1609 Old 09-14-2010, 08:14 AM
SamuriHL's Avatar
Yup. Very exciting time for us HTPC owners. I'll be buying in a month or two, so, I'll have some pretty awesome choices.
SamuriHL is offline
post #1027 of 1609 Old 09-14-2010, 08:29 AM
swoon!'s Avatar
I'm doing the same. Right now, I'm using the i3 GPU, but the lack of follow-through (or gross oversight) by Intel on the proper video refresh rates and the desire for new bells & whistles plus improved video processing is driving me to get one of the new discrete HTPC cards when they come out.
swoon! is offline
post #1028 of 1609 Old 09-14-2010, 08:46 AM
SamuriHL's Avatar
I've got a 4850 in my HTPC that's really too big for the machine in terms of heat, plus the fact that it doesn't bitstream, so, I'm looking to upgrade. I now have a receiver in that room to connect it up to HDMI audio, so, I'm ready for a new video card anyway.
SamuriHL is offline
post #1029 of 1609 Old 09-14-2010, 10:02 AM - Thread Starter
Yes.
post #1030 of 1609 Old 09-14-2010, 03:04 PM
ricabullah's Avatar
Test BD : 2012
Player: PDVD10 v.10.0.1830.51
OS: Seven 32 Pro
HW: Clarkdale+Ati 5450 LP
Drivers: CCC 10.8
Connection Style: VGA to AVR, AVR to TV over HDMI cables.
Test result:
After skipping to sixth or seventh chapter i met silent stream bug while WinDVD10 had no issues at all.
(Dıon't ask TMT )
_ _ _ _ _
Chronical Tester
ricabullah is offline
post #1031 of 1609 Old 09-14-2010, 03:19 PM
rickcfer's Avatar
Quoted: 61 Post(s)
Liked: 31
"Actually, the final PowerDVD update will be a higher build number... it should be available tomorrow."
Tom
Cyberlink Posted 9/13/2010
From the Nvidia GTX460 thread. Which "tomorrow" were you refering to?
rickcfer is offline
post #1032 of 1609 Old 09-14-2010, 03:25 PM
ricabullah's Avatar
Next tomorrow, maybe
BTW AnyDVD HD v. 6.6.8.3 was on the background. Impossible to watch without it.
Chronical Tester
post #1033 of 1609 Old 09-14-2010, 03:53 PM
ricabullah's Avatar
Samuri, i say you never prefer LP cards coz they are working very noisy.
The problem is cards need some power cables to be connected on so as to be silent
So if you are buying a card, check out if there is a power cable input socket on it.
Chronical Tester
post #1034 of 1609 Old 09-14-2010, 04:02 PM
SamuriHL's Avatar
The nVidia 450 has one 6 pin power connector. That's not bad. All the reviews I've read say that heat on that thing is very well managed and very silent, as well. I recently discovered that I COULD put a dual slot card in that machine (tight fit, but, it'd work) and I'm a huge fan of those as they can shove the heat out the back which would be good for that case. At the moment I'm very seriously considering a 450. I want to see what AMD has with their 6xxx cards, but, nVidia may win me over on this one.
SamuriHL is offline
post #1035 of 1609 Old 09-14-2010, 04:07 PM
ricabullah's Avatar
Great news.
Chronical Tester
post #1036 of 1609 Old 09-14-2010, 04:20 PM
SamuriHL's Avatar
Yup, I agree. We'll see if I can hold out til the 6xxx cards are out. My 4850 is not overly liking the new tasks I'm having it perform in the new configuration. Heat is definitely becoming an issue with it as I use it more now for movie watching in the bedroom. And because I've been messing around with the configuration, I'm running into some other problems I had with video when I first set it up. It took me DAYS to get it configured to work the first time. I'm really just wanting to get it replaced and get it over with this at this point. The 450 seems like it'll be a good card. We'll need PDVD to get updated and TMT to get updated.
SamuriHL is offline
post #1037 of 1609 Old 09-14-2010, 04:31 PM
ricabullah's Avatar
Just one connector and the lower price,
if (say) 430 will have a connector i would definetely prefer it.
Players PDVD and especially TMT need immediate updates but i love WinDVD since i don't have any issues on bitstreaming with both cards and any drivers with Corel. (PCM streaming another thing btw - i mean downsampling )
BTW what i don't like with Corel is i had to bought it twice since it allows one copy on just two machines. (Me? How many disks i use, just guess? )
Chronical Tester
post #1038 of 1609 Old 09-14-2010, 04:33 PM
SamuriHL's Avatar
I do occasionally like to game on that machine, so, the 450 seems to be the sweet spot for me. PhysX support, DX11, etc. I'm really considering it. Heavily.
SamuriHL is offline
post #1039 of 1609 Old 09-14-2010, 04:45 PM
ricabullah's Avatar
Yes, if you don't play games like me that might be the right address. (430 or whatever?)
Chronical Tester
post #1040 of 1609 Old 09-14-2010, 06:36 PM
vladd's Avatar
Liked: 39
Tom
The Standards use the word "should" where conformance is expected unless, when applying professional judgment, circumstances justify deviation.
http://www.theiia.org/guidance/stand...ull-standards/
Auxiliary verb indicating a lesser obligation to comply with the main verb that follows. Used when there is recognition that although bound by duty, there may be circumstances that warrant not proceeding as stated.
http://www.studiocabrini.com/index_f...P_Glossary.htm
vladd is offline
post #1041 of 1609 Old 09-14-2010, 07:59 PM
mcantu1's Avatar
mcantu1 is offline
post #1042 of 1609 Old 09-14-2010, 08:05 PM
SamuriHL's Avatar
Excellent. It specifically mentions the 460. I assume the 450 is covered as well?
SamuriHL is offline
post #1043 of 1609 Old 09-14-2010, 10:12 PM - Thread Starter
Yes
post #1044 of 1609 Old 09-14-2010, 11:43 PM
Bignickfly's Avatar
Is the black level issue resloved with this latest update??
Bignickfly is offline
post #1045 of 1609 Old 09-15-2010, 01:11 AM
Xylon's Avatar
SÃ*
Xylon is offline
post #1046 of 1609 Old 09-15-2010, 04:55 AM
Ludvig's Avatar
Bignickfly,are you referring to this ?:
http://www.avsforum.com/avs-vb/showt...0#post18557170
1) It appears all newer versions of PowerDVD output at video levels (16-235). Is there any way to change it back to PC levels (0-255) via a registry entry or similar (since there's nothing in the player settings.) I'm using an ATI HD4670 on WinXP. Also why have the player colour controls been disabled? I know this can all be fixed in the driver settings but that's not a good solution since it'll mess up every other video application
Ludvig is offline
post #1047 of 1609 Old 09-15-2010, 05:41 AM
SamuriHL's Avatar
Yes
Awesome. I just ordered one as I was able to work out my budget to include it this month. It's quite the impressive card so I can't wait to try it out.
SamuriHL is offline
post #1048 of 1609 Old 09-15-2010, 06:01 AM
Andy o's Avatar
The problem I think is for ATI cards. There are several fixes and workarounds, depending on what series and driver version.
Andy o is offline
post #1049 of 1609 Old 09-15-2010, 06:46 AM
the48thronin's Avatar
Anyone with Powerdvd set to bitstream HD audio having audio issue during the previews (which are Dolby Digital)? I cant describe the sound but it's awful. If i go into audio settings and set it for DD/DTS or PCM, the problem goes away. It's a pain to change back and forth just so the DD parts playback properly and I still get HD audio.
My setup is:
HTPC HDMI ---> Onkyo Receiver ---> TV
This is on Powerdvd 10 Mark II
and ATI 10.7 drivers
the48thronin is offline
post #1050 of 1609 Old 09-15-2010, 06:50 AM
SamuriHL's Avatar
Is this with the latest patch released yesterday? If not, I've not had that issue. I simply get "DD+" showing up on my receiver for DD previews.
SamuriHL is offline
Reply Home Theater Computers
