Problem with multi display on HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-20-2010, 01:32 PM - Thread Starter
Max-Powers's Avatar
I recently added a new display. I don't use it all the time, so I turn it off a lot. I use ultramon so that I can make a hot key to disable the display.
My problem is, when the 2nd display is disabled, I turn off my main TV with my remote, and windows automatically switches the desktop to the secondary display. This is a problem because it requires me to actually turn off my secondary display so that it is not shining. It also takes several seconds more to switch over when I turn my main back on.
Is there any way I can tell windows to not try to automatically switch to the display that is on?
Will do cable management later. I should have put it lower so that when folded back, it would hide completely behind the TV... oh well.
Max-Powers is offline
post #2 of 6 Old 03-20-2010, 02:28 PM
heartsurgeon's Avatar
if i might be so bold..get rid of ultramon
it looks like your monitor is 1080p.
if that's the case, just clone your monitor to your display.
then, the power status of one display will not effect the other.
i don't exact understand why you've set your displays up the way youhave, but that's what i have done (1080P main display, 1080p dell monitor, clone mode)
Rule #1: You haven't wasted your money...you just haven't spent enough yet.
Rule #2: When in doubt...get both.
Rule #3: No need to invoke malice when stupidity alone suffices.
heartsurgeon is offline
post #3 of 6 Old 03-20-2010, 02:51 PM - Thread Starter
Max-Powers's Avatar
The dell is a 2005FPW. 1680 x 1050
The reason I have it set up like that is when I get involved in work, school, or internet browsing, my screen collects windows. I like to watch movies or TV as background noise, so I throw it up there so that it does not get in the way. When I don't want to use it, I can fold it back behind the TV.
If I clone, then it is useless to have a 2nd display, and I will still have to manually turn off the screen.
post #4 of 6 Old 03-20-2010, 11:56 PM
nijel8's Avatar
You didn't say what card are using, but with ATI you can go extended and setup hotkeys to enable/disable/switch primary/secondary displays however you like it.
Ultramon is useless.
nijel8 is offline
post #5 of 6 Old 03-21-2010, 10:01 AM - Thread Starter
Max-Powers's Avatar
I am using a GTX 260. I still need a way for it to not automatically enable the secondary when the primary is turned off.
post #6 of 6 Old 03-22-2010, 06:05 AM
scat2002's Avatar
Max-Powers
I too like to watch movies or TV as background noise
as I read the AVS Forum and others.
My setup is as follows:
Desktop computer using SageTV Client for playback.
Main display 19" CRT ctx monitor set as display 1
this display is for everything except video playback.
Second display Samsung 40" LCD set as display 2
originally I had used Ultramon but learned I could do it without it.
I use SageTV as a server down stairs on my HTPC and on my desktop PC in a upstairs bedroom is my office and this computer.
On desktop PCI opened SageTV client on first display and drag it to the second disply then maximized it.
I also use the following in the same manor
PowerDVD, Media Player Classic HC, and TotalMedia Theater 3, and when I am done watching video I close the application and turn off the TV with a Harmany 880 remote.
The video card is always outputing to the second display but it only the desktop background image.
Hope this helps you.
Scat
scat2002 is offline
Reply Home Theater Computers
