Netflix Streaming on Windows7 : Any Fix for Tearing? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2013, 11:39 AM
BradChesney79's Avatar
That would explain a lot of the tearing in Windows 7 Starter--
Windows 7 Starter just plain doesn't have Aero. You can't enable something that just isn't there.
BradChesney79 is offline
Old 01-09-2013, 12:34 PM
dn83's Avatar
This is ridiculous and unfortunate. Why should something like streaming internet video be tied to something like that, when the hardware is capable? Maybe because Netflix uses Silverlight and Silverlight is also Microsoft. :-\
dn83 is offline
Old 12-27-2013, 12:51 AM
gorillarabbit's Avatar
Yessss! thank you! I cannot believe this is actually the problem for I'm sure a lot of us. Microsoft...
gorillarabbit is offline
Old 07-27-2014, 05:51 PM
PandaPower's Avatar
Liked: 0
If your device is plugged into a power strip, try plugging it directly into a wall socket even if you have to use an extension cord. My issues with silverlight resolved when I did this. I replaced the power strip with a Belkin product and haven't had a problem since.
PandaPower is offline
Old 06-29-2015, 07:39 AM
jrivett's Avatar
For what it's worth, this was an ongoing issue for my Windows XP media machine until I did a clean install of the Windows 10 Insider Preview. For whatever reason, the tearing issue is now completely gone. Better Windows internals? Or perhaps just doing a clean install did the trick. I may never know for sure. Intel G43/G45, 32-bit Windows, Firefox.
jrivett is offline
Old 06-29-2015, 07:56 AM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
Well, this is a thread from 2013, so it has been discussed heavily since then.
W7 uses Silverlight, and has all sorts of PQ issues. W8 and newer do not use Silverlight and do not have the same issues. This thread needs to die.
TornadoTJ is offline
