Is there a BD-ROM with MultiRegion DVD capability? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-22-2010, 01:40 AM - Thread Starter
alex cheng's Avatar
Hi,
I am currently using a pioneer BD-ROM but is has the DVD restriction of playing DVDs from a certain region. Are there any models available which will play all regions?
Alex
alex cheng is offline
post #2 of 5 Old 03-22-2010, 04:02 AM
sneals2000's Avatar
Quoted: 250 Post(s)
Liked: 127
You will probably find that your existing drive can play DVDs (and Blu-rays) from any region with the use of Slysoft's AnyDVD (Any DVD HD adds Blu-ray support) - assuming you are running a Windows PC. This sits between the drive and replay software and effectively strips regional encoding on the fly.
They offer (or used to) a short trial period so you can try it before you buy.
Most people with HTPCs I know run AnyDVD HD - it can also solve some tricky HDCP issues.
sneals2000 is offline
post #3 of 5 Old 03-22-2010, 05:00 AM - Thread Starter
alex cheng's Avatar
Thanks sneals,
I'll check that out and see how it works.
Alex
post #4 of 5 Old 03-22-2010, 07:26 AM
Krobar's Avatar
Quoted: 17 Post(s)
If your drive is listed here under RPC1 or RPC2 patch then you can modify the drive firmware which allows Windows to change region as many times as you like, no need for paid software:
http://ala42.cdfreaks.com/MCSE/
Krobar is offline
post #5 of 5 Old 01-15-2013, 10:09 PM - Thread Starter
alex cheng's Avatar
Hi,
Just seeing if there was an updated answer to this question.
Reply Home Theater Computers
