HTPC in XBox case - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-27-2010, 11:46 AM - Thread Starter
jstarling82's Avatar
Does anyone have any experience building a HD HTPC in an XBox case? I have this thing ripped apart, and I'm looking at a decent amount of space in an easily accessible case. However, the back panel is going to need some modifying, and I don't think it'll accept the old ATX board I have here. Might have to pick up a Micro ATX mobo. Also, without having everything in front of me, I'm not sure if a low profile video card will fit.
Any suggestions?
jstarling82 is offline
post #2 of 15 Old 03-27-2010, 12:01 PM
whiteboy714's Avatar
I would think you would need to go with an ITX mobo to make if wok. If itsd possible. Maybe one with the ION graphics so you wouldn't need a card. Just a thought, sounds cool though.
whiteboy714 is offline
post #3 of 15 Old 03-27-2010, 12:10 PM
jreese831's Avatar
You'll definitely need an ITX mobo, and a LOT of time to invest in properly modding the case. I saw a video, I think through Tom's Harware, a couple months back of some guy who did exactly this and it came out great. I was looking into doing it as well until my coworker who was going to give me his old xbox decided to throw it away instead
Here's a build thread from the Tom's Hardware forums; not what I had referred to above, but still quite detailed and with pics: http://www.tomshardware.com/forum/26...xbox-orig-case
"Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying." - Arthur C. Clarke
jreese831 is offline
post #4 of 15 Old 03-27-2010, 12:11 PM
Heli Pilot's Avatar
Heli Pilot is offline
post #5 of 15 Old 03-27-2010, 12:49 PM
Swoosh830's Avatar
Originally Posted by Heli Pilot View Post
http://www.youtube.com/watch?v=TggHtINGIyc
Here's one
That was VERY impressive and entertaining to watch... though I must say I had to mute the audio for most of it.
Swoosh830 is offline
post #6 of 15 Old 03-27-2010, 12:54 PM - Thread Starter
Yeah, this looks like it'd be a gigantic PITA. I took one apart this morning just to look around a bit. Could be fun, but I'd have to scrap the (attractive) idea of piecing one together from sale items and parts I have lying around.
post #7 of 15 Old 03-27-2010, 05:01 PM
jreese831's Avatar
Here's one
That's exactly the one I was thinking of! Good find!
post #8 of 15 Old 03-27-2010, 08:25 PM
mike_311's Avatar
i would think and old receiver would make a nicer case. i have always wanted to try a case mod. maybe with the next htpc .
"If the world didn't suck, we'd all fly off."
mike_311 is offline
post #9 of 15 Old 03-28-2010, 06:08 AM - Thread Starter
I've also considered an old VCR or DVD player. Something you could pick up on the cheap.
post #10 of 15 Old 03-28-2010, 12:57 PM
gmanhdtv's Avatar
Quoted: 30 Post(s)
I did not use an Xbox 360 but had great success with a Sony BDP-S1 bluray player using an itx motherboard. Works great and is very stealthy
http://www.avsforum.com/avs-vb/showt...7#post17563757
gmanhdtv is offline
post #11 of 15 Old 03-29-2010, 08:35 AM
daMaster's Avatar
Here's one
That was sick! Beautiful build! I wish I had all those tools to be able to do something like that.
daMaster is offline
post #12 of 15 Old 03-29-2010, 12:22 PM
ScoHo's Avatar
That was pretty crazy. I have to wonder what percentage of the actual case still remained at the end of that build.
Not quite as impressive as this though:
http://www.techeblog.com/index.php/t...ional-computer
ScoHo is offline
post #13 of 15 Old 03-29-2010, 01:54 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Well, I'm trying out a factory modified Silverstone LC02 case. (The modifications basically meant, they drilled holes everywhere in the chassis for airflow and heat dissipation). The LC02 IS about the size of a DVD player/Receiver. It's 15"x11.6"x3.63" And has all the right mountings for a regular motherboard (even takes ATX!).
Here's my build "in progress".
kapone is offline
post #14 of 15 Old 03-29-2010, 06:50 PM
Morpheus_Rising's Avatar
Lian-Li have a X-Box 360 modded case:
http://www.lian-li.com/v2/en/product...35&ss_index=87
I have their PC-71 server case and I have been modding it for the last 4 years. I hope I can get it done this year.
Morpheus_Rising is offline
post #15 of 15 Old 03-29-2010, 09:56 PM
elm_sd's Avatar
gmanhdtv that Sony BDP-S1 is a great looking htpc..
Does anyone now of a list of drives in BluRay STB.
I tore my samsung apart but it doesn't have a normal pc connection on the drive.. It be great to kill 2 birds with one stone and get a drive and case at the same time via a STB
ELM_SD
Quality TV = C-Band
elm_sd is offline
Reply Home Theater Computers
