Handbrake settings for HD 1080/720p encodes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-01-2010, 09:20 PM - Thread Starter
africanmarty's Avatar
hi guys i have finished backing up my dvd collection using handbrake with x264 and wanted to do the same with my bluray and HD-DVD's but i'm getting about 2fps on 1080p and 5fps on 720p encodes (source my HDDVD/Blurays ripped to hard drive). I think the settings I'm using in the advanced tab might be over the top. if you guys could have a look at them for me and see where i am going wrong ( i think i might have some of them on overkill and thats why its taking so long). The PC I'm doing the encode on is an AMD quad core 965 @ 3.8Ghz using windows XP w/ 4 gig of ram.
Heres a pic of my advanced tab.
Hoping to hear from you guys.
Regards Marty.
africanmarty is offline
post #2 of 3 Old 04-01-2010, 09:25 PM
kagolu's Avatar
What you have looks like over kill. Unless you really need the small file size I would try the high profile setting with a crf of 18. A crf of 18 is pretty much transparent.
Kagolu
kagolu is offline
post #3 of 3 Old 04-01-2010, 09:48 PM - Thread Starter
ok sweet i'll try that and post back the fps. thanks mate.
Reply Home Theater Computers
