FAQ for the 3D HTPC - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #811 of 1551 Old 07-04-2011, 08:58 AM
SleepWalker2's Avatar
Originally Posted by Dgephri View Post
What is the best $ GPU with at least as much gaming power as the 4550 and supporting the 3D spec necessary for DXVA decoding?
Will an ATI 6570 do what I need?
I don't know about the 4550 but the 6570 is said not to be good for gaming, see:
http://www.pcmag.com/article2/0,2817,2385799,00.asp
Personnaly I went for a 6850. when I'm not gaming I set max fan speed manually at 28% to keep it silent.
SleepWalker2 is offline
post #812 of 1551 Old 07-07-2011, 10:41 AM
Dgephri's Avatar
my main gaming rig has a 480GTX on iZ3D, so I'm not going to put that kind of horsepower into my HTPC.
Really just want the 6XXX for HDMI 1.4 spec to my reciever, and a bit better for gaming than my 4550 when I choose to use my bigscreen.
Dgephri is offline
post #813 of 1551 Old 07-12-2011, 10:03 AM
Swolern's Avatar
Quoted: 99 Post(s)
Liked: 25
I was going to build a gaming rig then i came across this PC. What do y'all think about this system for $1299? It looks almost too good to be true.
http://computers.toptenreviews.com/g...rl-review.html
Unless im reading it wrong, It has two GTX580s that looks top notch and priced at almost $600 per card. So I don't know how they are selling this rig for only $1299. Any good for 3d gaming? Any suggestions/comments. Thanks.
Swolern is offline
post #814 of 1551 Old 07-12-2011, 06:21 PM
Dgephri's Avatar
FYI on the 6570: installed in my 4U HTPC server/front end, installed the HDMI driver from Safe Mode (my solution, works), XBMC working fine
I got the MSI variant for price and dual fans, hoping it was quiet: pretty good so far, not a noticable "whine" yet, so I will report of if I hear and fan RPM issues.
Then comes some 3D testing: should be roughly double the performance of my 4550 in games and S3D.
Dgephri is offline
post #815 of 1551 Old 07-16-2011, 05:32 PM
tlwizard's Avatar
Originally Posted by renethx View Post
All the GeForce 4xx/5xx GPUs support every HDMI 1.4a 3D display, so do Radeon HD 5xxx/6xxx discrete GPUs (yes, 5xxx too), as well as A6/A8 Series Fusion APUs (Radeon HD 6530D/6550D integrated), and Intel Core i3/i5/i7 Sandy Bridge processors (Intel HD Graphics 2000/3000 integrated). All of them support MVC (BR 3D codec) hardware decoding. Just install the latest GeForce or Catalyst or Intel Graphics driver. That's it.
The Radeon HD 5xxx work with every 1.4a 3D display? Or just the few HD3D displays listed on the AMD website? I've been trying to get my Radeon 5450 to work with my Panny GT25 but to no avail.
tlwizard is offline
post #816 of 1551 Old 07-17-2011, 04:01 PM
ricabullah's Avatar
Hi guys.
Does anybody have 3D experience over Sandybridge mobo GPU?
Chronical Tester
ricabullah is offline
post #817 of 1551 Old 07-17-2011, 05:26 PM
snef's Avatar
Yes me
With a h67ma-ud2h-b3 with a i3-2100
And a z68ma-d2h-b3 with a i5-2500k
I use tmt5 and im connected to a pn50c8000
And everithing work perfectly
snef is offline
post #818 of 1551 Old 07-17-2011, 05:37 PM
ricabullah's Avatar
Thanks snef for the feedback.
Have you ever given it a go with Stereoscopic Player too?
Chronical Tester
post #819 of 1551 Old 07-17-2011, 06:58 PM
snef's Avatar
No sorry
Only tmt5 and wmc for sbs
snef is offline
post #820 of 1551 Old 07-17-2011, 08:23 PM
Swolern's Avatar
Quoted: 99 Post(s)
Liked: 25
Originally Posted by snef View Post
Yes me
Any 3d gaming? If so how is it?(framerate & Res) What kind of GPU are u using? I'm working on my first gaming rig myself and just picked up the i5 2500k and Asus P8z68-V Pro. Planning to connect to my Panny VT30. Looking at the GTX 580 or 590 for my GPU? Getting ready for Battlefield 3.....
Swolern is offline
post #821 of 1551 Old 07-19-2011, 03:13 PM
ricabullah's Avatar
No sorry
Thanks but does "no" mean "no, haven't tried yet."
or
"yes, i've tried with SP and it doesn't work with Sandy, just TMT5 and wmc works.?
If the response means "haven't tried yet", could you give it a go with SP's trial version?
Chronical Tester
post #822 of 1551 Old 07-20-2011, 05:19 AM
ballers34's Avatar
Quoted: 12 Post(s)
Hello all I'm pretty new to the htpc world having built my first one a few weeks ago....I have been backing up my 3D blu rays and I cant seem to get them to play properly on tmt5. I get about 5-10 mins in and tmt stops responding and I have to close the program...this has happened with Avatar and Tron...I have tried playing it as an iso and as a regular rip file but no luck I'm using amd 6870 graphics card with the lastest driver update from amd...should I switch to a nividia card? Any Help would be greatly appreciate.
My setup: HTPC--->onkyo 5008---> JVC RS 50
ballers34 is offline
post #823 of 1551 Old 07-21-2011, 04:28 PM
eubanks718's Avatar
The new mac mini's have the intel core i5 HD graphics 3000 integrated video card. So if I understand this correctly, they have HDMI 1.4a and the hardware to display 3D. Just remains to be seen whether they have the drivers and software?
eubanks718 is offline
post #824 of 1551 Old 07-21-2011, 04:52 PM
snef's Avatar
No gaming at this time but i build a new one and i will out a gigabyte gtx560
I will try it and let you know
or
Havent tried yet
Yes, give me a couple of day because i build a new htpc and will try it on this one
snef is offline
post #825 of 1551 Old 07-21-2011, 05:40 PM
ricabullah's Avatar
OK snef, i keep holding on.
Chronical Tester
post #826 of 1551 Old 07-24-2011, 01:12 AM
blazed's Avatar
hey guys, i have my pc hooked up to a 3dtv, and when i try to play sbs files, i dont get the option on my tv to change to SBS format (SBS option is greyed out).
my computer is an i7, generic motherboard, and a ati 4850. i dont want to spend a lot of money, but i really would like to watch my sbs files.
it it just a gpu problem? or would i need to purchase a new set up? or is it a software problem.
if i put these files on an external HD they will play (i can select the SBS option), but i have to convert the audio to 2ch, which i dont like.
blazed is offline
post #827 of 1551 Old 07-24-2011, 03:53 AM
ricabullah's Avatar
You need at least a 5*** series card for 3D.
But even you put a 3D GPU card:
You can't change your TV's setup when it's connected to an HTPC.
You must adjust it on your player or DVB Software.
If you want to watch live broadcast only ProgDVB Pro is supporting real 3D TV.
If you record first and watch later or if you want to watch your SBS files you can use Stereographic Player.
http://www.avsforum.com/avs-vb/showt...6#post20558256
Chronical Tester
post #828 of 1551 Old 07-24-2011, 04:54 PM
blazed's Avatar
so even if i have a 3d capable videocard & 3dtv, i would still need software?
blazed is offline
post #829 of 1551 Old 07-24-2011, 05:57 PM
fyrfyter71's Avatar
Are you using hdmi to connect to the tv or are you connecting through the pc input? What kind of tv do you have?
fyrfyter71 is offline
post #830 of 1551 Old 07-24-2011, 06:10 PM
ricabullah's Avatar
Yes.
Chronical Tester
post #831 of 1551 Old 07-24-2011, 09:22 PM
blazed's Avatar
im using a dvi-hdmi adapter (video card only has dvi outputs), then i have the hdmi cable from the video card to my tv.
blazed is offline
post #832 of 1551 Old 07-26-2011, 08:37 PM
Tony_Montana's Avatar
Quoted: 45 Post(s)
Yes me
does intel hd2000 support 3D & HD audio bitstreaming (hdmi 1.4) for new receivers?
my main concern are bluray discs
Tony_Montana is offline
post #833 of 1551 Old 07-27-2011, 07:33 PM
uvman23's Avatar
Hi I own a Samsung HLT6187SX/XAA DLP HDTV with a 3DA-1 adapter, and a Onkyo TX-SR876 receiver which is not 3D capable.
I'm looking to build a 3D HTPC that would be compatible with what I own and build it to be somewhat future proof, if that's possible.
This is what I'm looking for:
3D Blu-Ray player/burner.
Silent or quiet case or tower.
Silent or quiet power supply.
A quality & compatible motherboard for what I need.
1.5TB-2TB Hard Drive & hopefully quiet.
If possible wireless internet built in, if not I'll buy a adapter.
3D compatible video card for playing 3D Blu-Ray's, 3D MKV's, HD MP4's. Also I'm not looking to play games but I would like the card to handle 2D To 3D conversion well, if the video card contributes to that.
For Audio I would like to send one HDMI out to my AV Receiver & get Dolby TrueHD, DTS-HD, and one HDMI to my 3DA-1 adapter.
i3,i5 or i7 processor depending on what I need to play all the formats I list & in 3D.
For a TV Card, I would only want one if I could use a program to convert 2D to 3D HDTV stations, if that's not possible I don't need one.
A program or programs that play all the formats I listed, and also does 2D to 3D conversion well.
I haven't purchased 3D glasses yet, but I'm looking to buy the Ultra Clears, and I don't know which would be compatible with a HTPC. DLP Link or IR? If IR I would need to buy a emitter.
For budget, I'm not looking to spend an outrageous amount & I heard it's possible to build a quality HTPC for a low cost if it's not a full blown gaming machine, if that's true or not.
Any help would be great and fast responses would be much appreciated, thanks.
uvman23 is offline
post #834 of 1551 Old 07-27-2011, 07:48 PM
kgod's Avatar
Yes.
kgod is offline
post #835 of 1551 Old 07-28-2011, 10:15 AM
roknrol's Avatar
Quoted: 31 Post(s)
Liked: 36
@ uvman23: Check out Assassin's HTPC Buyer's Guide; he pretty much covers all your questions regarding what it takes to build a nice system including necessary components for 3D playback.
http://www.avsforum.com/avs-vb/showthread.php?t=1302559
roknrol is offline
post #836 of 1551 Old 07-28-2011, 02:10 PM
markm75's Avatar
Quoted: 176 Post(s)
Can someone point me to a thread where there are tips/instructions on what is needed to do the EDID override on my Samsung HLT6187S DLP, so that i can use say the xbox 360 in 3d mode (without buying a gefen or the $170 tru3d kid, but just the $90 adapter)? I know there was a spot here before where the things needed was described?
My TF+TR Atmos Setup
Tech, the Universe, and Everything:  http://tech-stew.com
Just Plane Crazy: http://flight-stew.com
markm75 is offline
post #837 of 1551 Old 07-28-2011, 05:30 PM
ricabullah's Avatar
I think there was somewhere here:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=193
_ _ __ __
Chronical Tester
post #838 of 1551 Old 08-08-2011, 06:02 AM
sobskarlpox's Avatar
i'm currently using my i7 950 for my 3D HTPC, im thinking of switching it with my old Q6600. Would the Q6600 @ 3.6 ghz + 4GB DDR2 Ram be enough to play 3D movies smoothly?
sobskarlpox is offline
post #839 of 1551 Old 08-08-2011, 06:08 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Even a dual-core processor is enough if the graphics card you use supports MVC decode.
renethx is offline
post #840 of 1551 Old 08-08-2011, 06:30 AM
i will still be using my 5970 for the 3D movies. i just wanted to take out my r3e and i7 proc from my htpc. lol
Reply Home Theater Computers
