FAQ for the 3D HTPC - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1501 of 1551 Old 06-04-2014, 11:49 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
XBMC does not support MVC (the video codec of BR 3D). If you want to play BR 3D, you have to re-encode it to SBS or TAB (e.g. by DVDFab). More on this topic.
Mfusick and Vivek Sood like this.
renethx is offline
post #1502 of 1551 Old 06-05-2014, 06:27 AM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
I'm just starting out trying to get 3D (stereo) fsbs MKV's playing on my system. CPU is only a Athlon dual-core CPU, but GPU is now an HD7750 connected via HDMI 1.4a to a 3D plasma TV. I can create the 3D MKV's fine, but getting them to playback in 3D is proving tricky. My preferred player is MPC-HC, but it's not obvious if this can playback 3D files. I've tried TMT3 (w/3D plugin) and TMT5, but while they playback the file, they only play back in 2D, even when I change the settings. I was hoping TMT would detect it was a 3D MKV and playback accordingly.
This is a big thread, going way back, so I was hoping things would have improved and got easier now!
tman247 is offline
post #1503 of 1551 Old 06-05-2014, 07:42 AM
vbvamsi's Avatar
Originally Posted by Vivek Sood View Post
What's the problem in using XBMC for everything? The latest Gotham has some 3D support. Sorry for my blunt question.
xbmc doesn't support frame packed 3d. Gotham only supports half sbs and ou.
LG 50PK350 - BenQ W1070 - Onkyo TXNR626 - Sony PS3 Slim - EPOS AVS 5.1 - HP N54L XBMC - Egreat R6S+ Pro - Harmony Ultimate One
vbvamsi is offline
post #1504 of 1551 Old 07-03-2014, 09:38 PM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Hi,
I have an asus hd6450 and a hp n40l micro server. Will I be able to playback 3d bluray ? If yes is there anyway to get audio happening since my amp is a hdmi v1.3. My tv is a vt60 which is 3d compatible.
Kenn.
k3nnis is online now
post #1505 of 1551 Old 07-03-2014, 09:50 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes, you can play BR 3D and send Frame Packing 3D to your TV. But you can't send audio to your AVR, only stereo in your TV. If you can add another graphics card such as Radeon HD 5450 as a HDMI sound card, but you have to make the PCIe x1 slot 'open'.
renethx is offline
post #1506 of 1551 Old 07-04-2014, 01:51 AM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Thanks. What do you mean by open? Also my panasonic vt60 has a optical connection at the back for audio. If I run that cable to my amp can I get audio that way as well? So the hd5450 can run properly on pcie x1 slot? Also is it known if it will fit with a 6450 next to it in a hp n40l? Does it need to be a 5450 or can it be another card?
Sorry for so many questions.
Thans,
K.
post #1507 of 1551 Old 07-04-2014, 02:16 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
VT60 may pass-though AC3/DTS from HDMI in to optical digital audio out. You should try this first. (TrueHD/DTS-HD are not supported by optical digital out.)
You can't install a PCI Express x16 device (e.g. a graphics card) in a closed-end PCI Express x1 slot. You have to make it open-end. Then a graphics card should work fine (but with poorer video performance; as you use only audio, this is not a problem, of course). Any graphics card supporting HDMI audio bitstreaming is OK. But generally it is easier to replace HD 6450 with a graphics card supporting dual audio stream such as Radeon R7 240. To convert DVI to HDMI you will need this adapter. Or go with a GeForce card, that also supports dual audio stream without a proprietary DVI-HDMI adapter. Personally I prefer Radeon to GeForce for several reasons.
renethx is offline
post #1508 of 1551 Old 07-04-2014, 07:11 AM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Thanks. I prefer Radeon as I heard the deinterlacing is better? This is for live tv. I wonder if the Radeon you are referring to will fit? Or just sacrifice hd audio for normal dts or dd using optical from my tv if it works.
Cheers,
K.
post #1509 of 1551 Old 07-04-2014, 08:46 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
N40L supports only low-profile expansion cards. You should choose such a card.
renethx is offline
post #1510 of 1551 Old 07-04-2014, 08:06 PM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Thanks. I will try playing back full blu ray ISO on the n40L with the 6450 straight to the tv. I am just worried the n40l CPU can't handle full 3D.
post #1511 of 1551 Old 07-04-2014, 09:20 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
6450 decodes BR 3D codec. CPU plays little role here.
renethx is offline
post #1512 of 1551 Old 07-04-2014, 10:42 PM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
I just have some doubts because I have seen some reports that 6450 and hp n40l stutters when playing back 3d bluray.
post #1513 of 1551 Old 07-04-2014, 11:24 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Then perhaps the hardware decoder was not working. Sometimes disabling "Enforce Smooth Video Playback" in Catalyst control center fixes this problem.
renethx is offline
post #1514 of 1551 Old 07-05-2014, 12:26 AM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Thanks. I will make sure that setting is not on.
Cheers,
K.
post #1515 of 1551 Old 07-05-2014, 07:55 AM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Hi,
Just tested and 3d bluray iso plays back without stuttering. However the background images are blurry while the main focus (middle) looks ok. So not sure why this is happening? I used total media theatre 6.x
Maybe I should try Power DVD ultra?
Cheers,
K.
post #1516 of 1551 Old 07-10-2014, 05:54 AM
vbvamsi's Avatar
I have bought egreat R6s media player which I am now using for 3D bluray playback. I wanted to integrate everything with XBMC, but for this I will end up buying TMT or PDVD + anysoft (for cinavia removal). Also I need to keep renewing the licenses every year. The media player only costed me £45 and plays all the 3D content mkv or iso perfectly fine.
http://en.egreatworld.com/en/product-detail-322.html
vbvamsi is offline
post #1517 of 1551 Old 07-10-2014, 06:41 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Integrating everything into XBMC is possible for a cheaper cost ($53) if you give up ISO: rip BR 3D in MKV by MakeMKV (free right now) and play it with Stereoscopic Player ($53).
renethx is offline
post #1518 of 1551 Old 07-10-2014, 07:46 AM
vbvamsi's Avatar
Yes I tried this approach but saw the CPU to be close to 100%. Also you confirmed to one of my earlier messages that stereoscopic player cannot use hardware decoding with MVC files and it is a limitation of CoreMVC. For this reason, I have decided to buy a standalone media player as I didn't want to go down the route of buying more and more software. Below is our earlier conversation.
FAQ for the 3D HTPC
vbvamsi is offline
post #1519 of 1551 Old 07-10-2014, 07:58 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #1520 of 1551 Old 07-10-2014, 08:13 AM
vbvamsi's Avatar
I forgot that we talked.
No worries. You helped me in making a decision on which way to take with 3D and xbmc .
vbvamsi is offline
post #1521 of 1551 Old 07-10-2014, 03:26 PM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 435
I feel lucky.
Got a 3D projector recently, and I didn't think my year+ old A6-5400K rig would be up to the task to play 3D iso without a video card. Plays it great though with PowerDVD 14, at about 40-50% cpu. TMT6 was 100% cpu, with stuttering obviously. Not sure why such a difference.
SBS files no problem using Jriver MC.
Man, if I knew it was that easy I would've done it a long time ago
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
post #1522 of 1551 Old 07-10-2014, 09:51 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
This means that hardware-accelerated decoding does not work. Try to uncheck "Enable smooth video playback" in Catalyst Control Center (although this sounds strange).
renethx is offline
post #1523 of 1551 Old 07-11-2014, 10:51 AM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 435
Yes, does sound strange, but I'll give a try tonight and report back. Thanks.
Spanglo is offline
post #1524 of 1551 Old 07-12-2014, 12:47 AM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Hi Guys,
Just to report back HP n40L + Asus HD 6450 about 3D playback (full blu ray ISO). TMT 6 no luck, no stuttering but blurry. I tried latest version of powerdvd ultra and all is good so I guess I need to stick with PDVD. By the way my CPU usage is around 49-50%.
My amp is not HDMI v1.4 so can't passthrough 3D with HD audio. My TV is v1.4
So at the moment I connect my HTPC straight via HDMI to TV.
My HP n40L have a spare 1x PCIe 2.0 1x. Will a AMD HD 5450 work in that slot to get HD audio? Also my power supply is 240Watts not sure if it will accept 2 video cards??
Cheers,
K.
post #1525 of 1551 Old 07-12-2014, 12:57 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Usually yes, if you mod the slot, no guarantee though. TDP of 6450 = 20W, TDP of 5450 = 19W. So 240W is plenty enough.
renethx is offline
post #1526 of 1551 Old 07-12-2014, 01:13 AM
k3nnis's Avatar
Quoted: 294 Post(s)
Liked: 44
Thanks. If I can find one cheap I may give it a try...
post #1527 of 1551 Old 08-03-2014, 06:55 PM
Vivek Sood's Avatar
Thanks. Using Virtualclone drive and TMT for 3D with no issues yet. Only gripe is I gotta manually change refresh rate of my TV from 60hz to 24hz from ATI Control center but that's fine. At least it works this way.
i5 4440 - H97M-DS3P - Vengeance 8GB - 850 Pro 128 GB SSD - R7 240 - L42ET60/S2240L - Swans M50w - Xonar DX - ATH-M50 - E10 - 5 TB - VS350 - Carbide 400R - Hauppage MCE Remote Control - Windows 10 Pro x64.
Vivek Sood is offline
post #1528 of 1551 Old 08-04-2014, 06:12 AM
shepP's Avatar
Quoted: 39 Post(s)
Download something like hot key resolution changer and set a hotkey for 24hz. Buttons on the MCE remote can be used (I think I used *)
Vivek Sood likes this.
shepP is offline
post #1529 of 1551 Old 08-10-2014, 09:35 PM
Vivek Sood's Avatar
Thanks. That would be one more thing to frequently update and install and tinker with so I use ATI Catalyst center to change it manually.
post #1530 of 1551 Old 08-23-2014, 09:20 AM
jmelan's Avatar
Quoted: 57 Post(s)
Liked: 33
Dual HDMI and TMT 6
Just reconnected my receiver after a year or so and now TMT does not want to send HDMI audio out to my receiver
Win7x64, mvidia 650ti coneected in extended desktop mode via:
HDMI: sony xbr52hx909
DVI-->HDMI: HK AVR-354 (older non 3d receiver)
TMT 6.7.1.199
Nvidia drivers 340.52
I can play 3d just fine but I can only get audio out to my lousy tv speakers
AVr354 is selected as default in windows and works with HDMI audio with MPCHC, WMC, and stereoscopic player
Is dual HDMI out broken in TMT?? thx
jmelan is offline
Reply Home Theater Computers
