FAQ for the 3D HTPC - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #181 of 1551 Old 10-27-2010, 06:52 AM
walford's Avatar
Most AVR's will pass through HDMI 1.4a 3D video formats to a 3D TV and there is no reason that that HDMI 1.4a video format has to be created by a unit with an HDMI 1.4 transmitter chip or even an HDMI tranmitter chip. A DVI transmitter chip could output the 3D video format and then could have a DVI-HDMI adapter used to connect it to the TV via an AVR.
However. Only a 1.4 capable AVR can extract the audio from the doube packed buffer 3D format transmitted from 3D blu-ray players since the audio is not contained in the same location in the buffer as it is in the other HDMI 1.4a 3d or HDMI 1.3 2D formats.
The solution you are using to avoid getting a 1.4 AVR is completly valid and is often reccomended.
walford is offline
post #182 of 1551 Old 10-30-2010, 07:16 AM
childressmd's Avatar
Originally Posted by renethx View Post
The upcoming HDMI 1.4a 3D HDTV is different from the above two.
MPEG-4 MVC
-> frame packing 1920x2160 @23.976Hz (decoded by GPU or CPU/PowerDVD)
-> over
HDMI 1.4a connection (output by a HDMI 1.4a graphics card)
-> frame sequential 1920x1080 @120Hz (converted by the HDMI 1.4a 3D TV, with 2:3 pulldown)
-> frame sequential 1920x1080 @120Hz displayed. To support frame packing 1920x2160 @23.976Hz video signals over HDMI, the graphics card (GeForce GT 240, GTX 4xx, Radeon HD 5xxx, or Intel HD Graphics) will require a driver update (3DTV Play for GeForce in August, AMD and Intel soon?) as well as a patch to PowerDVD 10 Mark II (obviously).
Is there any software that presently supports frame packing?
I can not find any info on the NVidia regarding anything other than the checkerboard, and likewise TMT3 or PowerDVD.
For that matter, the displays listed on NVidia's site are last year's models, and they don't list the Samsung Plasmas. Like the one I have.
Scott
'The Green Room'
childressmd is offline
post #183 of 1551 Old 10-30-2010, 07:28 AM
turbofeet's Avatar
Hi Guys
I use my HTPC to watch all of my Blu-Rays and DVDs. My HTPC has a ASUS Xonar HDAV1.3 which I think sounds great, and enables Dolby TrueHD and DTS Master through my amp using RCA cables.
I have just bought a Panasonic TX-P42VT20B 3DTV.
It came with a 3D Blu-Ray player however it only has an optical connection and my amp will not decode the Lossess Audio from an optical connection.
I was looking at changing the graphics card to enable Full HD 3D from my HTPC. I do not need Ethernet or Sound to pass through, just the picture(s).
Can anyone recommend a card that does the job?
I am a little confused with the choices but these are a couple I am considering:
ZOTAC GeForce GT 240 1GB ZT-20404-20L
Link
MSI Nvidia N460GTX Cyclone 1GB GDDR5 OC
Link
An advice would be appreciated. If you have any specific links to products that will do the job that would be awesome!
Cheers
turbofeet is offline
post #184 of 1551 Old 10-30-2010, 10:40 AM
zombie10k's Avatar
Quoted: 3483 Post(s)
Liked: 3568
In case the DVI port does not support HDMI 1.4a 3D video formats somehow: As the DVI ports of GeForce GT 430/GTS 450/GTX 460 support HD audio bitstreaming (with a generic DVI-HDMI adapter) as ricabullah confirmed (and perhaps HD 6xxx too with the ATI adapter), you should be able to switch DVI and HDMI and use the HDMI port to connect to a HDMI 1.4a HDTV and a DVI port to connect to a HDMI 1.3 AVR.
thank you guys for the advice. I ended up picking up the Acer 5360 and the Nvidia glasses.
I went HDMI -> projector and DVI-HDMI to the Pioneer SC-07.
Powerdvd sent the HD audio to the receiver no problem and the PC picked up on the Acer5360 as an Nvidia 3D capable projector. When I went from PC->reciever->projector, the PC could not identify the projector. The AVR is probably blocking the EDID.
I watched a number of 3D BD's, it's impressive but definately caused some eye strain, mainly trying to look around and follow all the 3D effects.
zombie10k is online now
post #185 of 1551 Old 10-31-2010, 04:02 AM - Thread Starter
8:13's Avatar
That's too bad about the eyestrain. Don't force yourself to watch it if it hurts your eyes, treat it like a novelty.
I added this text below to the first post:
________________________
Best monitor?
The best monitor is the one that doesn't strain your eyes, and this means no crosstalk. For this you would buy a Mitsubishi 3D DLP TV. Look at a mitsubishi model and research it to see if it needs a upgrade or has no crosstalk or is 3D blu ray compatible. This is the way it is in November 2010, in the future the Plasma and LCD TV's may offer no crosstalk.
Checkout the tru3d website, they offer the dlp TV and adapter kit. (I'm not affiliated with any of these people in any way. I got this name 'tru3d' from the 3d forum and googled the link I'm providing now.) link
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #186 of 1551 Old 10-31-2010, 10:11 AM
walford's Avatar
None of the glases that are currently availabe for the Mits DLP are crosstalk free since none of them are completly opaque for the eye who shutter is "closed". Also some glases model have slower response times which also contribute to crosstalk. IMHO the best for use with the Mits adapter are the Viewsonic DLP-link glases.
walford is offline
post #187 of 1551 Old 10-31-2010, 10:18 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Opinion = imagination or real experience? In the latter case which glasses did you compare?
renethx is offline
post #188 of 1551 Old 10-31-2010, 05:21 PM
walford's Avatar
Based on all the reports from users that I have seen and almost 40 years of exeperience with ditgiall dislays and certainly non on my imagination
Any of the DLP link glases have the advantage that there isno possible crosstalk being created by the dispaly and the glases being out of sync since the display creates the sync signal used by the glases. However the response time, and opaque of the DLP-Link glases can differ. The Optima and the Viewsonic DLP-Link glases appear to produce better PQ then the Xpand 102 DLP Link glases and are apparently made by the same manufacturer. Since the Viewsonic glases hava a switch in them that swithes the Lenss being blocked they are best if you might want to use DLP-link and IR emiitter glases concurently.
walford is offline
post #189 of 1551 Old 10-31-2010, 11:40 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I asked this because your posts in the HTPC forum include lots of incorrect information. Perhaps you'd better limit your advice to areas where you have hands-on experience. (Nothing personal, but I am really tired from correcting your incorrect statements.)
BTW why are there so many misspellings in your posts (words in red letters above)? This alone is enough for me to question the credibility of your statements.
- exeperience -> experience
- ditgiall -> digital
- dislay -> display
- glases (8 times) -> glasses
- dispaly -> display
- isno -> is no
- hava -> have
- swithes -> switches
- Lenss -> lens
- emiitter -> emitter
- concurently -> concurrently
renethx is offline
post #190 of 1551 Old 11-05-2010, 05:35 PM
ricabullah's Avatar
Which one?
VIEWSONIC PJD6531 WXGA 3D or ACER H5360?
3D; it's time to have fun but i can't decide what should i buy?
Any ideas?
Chronical Tester
ricabullah is offline
post #191 of 1551 Old 11-05-2010, 06:43 PM
ricabullah's Avatar
Did you give it a go with WinDVD10 Pro as well?
That would be interesting to know the result of the comparison with PDVD10 really. (there is a fully functional 30 day trial of Corel as you know.)
http://www.corel.com/servlet/Satelli.../1287761939663
EDIT: PLS create a restore point before installing WinDVD10 Pro trial.
And do me a favor and give us the feedback?
Chronical Tester
post #192 of 1551 Old 11-05-2010, 08:36 PM
shaithis's Avatar
/showthread.php?p=19180318#post19180318"]ricabullah confirmed[/url] (and perhaps HD 6xxx too with the ATI adapter), you should be able to switch DVI and HDMI and use the HDMI port to connect to a HDMI 1.4a HDTV and a DVI port to connect to a HDMI 1.3 AVR.
I can confirm this also, just set mine up, HDMI to Samsung PS50C6900 and used an old DVI>HDMI cable to connect to the Pioneer VSX-AX4ASi, using 2 ports on a GTX460....full auto-3d switching and full bitrate audio.
The Avatar 3D BluRay looks totally AWESOME, so much better then the above/below version that has been doing the rounds.
Now just need that damned 3DTV Play to become available....got the force unleashed 2 sat here waiting for it...
shaithis is offline
post #193 of 1551 Old 11-06-2010, 08:00 PM
H8nXTC's Avatar
So confused! Which Avatar 3D Blu-Ray? I can't find it and thought I read that they weren't even releasing it in 3-D with the upcoming extended edition. Unless it's the simulated 3D, not actual 3D?
H8nXTC is offline
post #194 of 1551 Old 11-06-2010, 08:52 PM
ricabullah's Avatar
On November 16th:
http://www.avatarmovie.com/
Chronical Tester
post #195 of 1551 Old 11-06-2010, 09:19 PM
H8nXTC's Avatar
Originally Posted by ricabullah View Post
On November 16th:
Yes, that's the one, but as I stated, I read that it won't be available in 3D. So how is he watching Avatar in 3D on BluRay?
H8nXTC is offline
post #196 of 1551 Old 11-06-2010, 09:39 PM
vladd's Avatar
Liked: 39
Really good friends at Fox or Panasonic?
http://www.dvdtown.com/news/avatar-b...equipment/7659
vladd is offline
post #197 of 1551 Old 11-07-2010, 04:04 AM
ricabullah's Avatar
Thanks vladd for the link.
For the time being, it seems that we can find out just two 3D BD in Amazon stocks: (except those of Imax)
1) Cloudy with a Chance of Meeatballs,
2) Monster House...
Alice in Wonderland 3D locked by Sony,
Avatar 3D locked by Panasonic (and two other 3D unknown disks)
Monster vs Aliens 3D locked by Samsung. (and How to Train Your Dragon and Shrek will be locked as well.)
Chronical Tester
post #198 of 1551 Old 11-07-2010, 06:12 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #199 of 1551 Old 11-07-2010, 07:16 AM
ricabullah's Avatar
Thanks for the link rene.
At least we have one option more: MY BLOODY VALENTINE.
EDIT: No it doesn't seem a real 3D.
LATEST EDIT: OK there is another one at bestbuy exclusive but i can't buy it since i don't live in US
Chronical Tester
post #200 of 1551 Old 11-11-2010, 08:50 AM
Is this full HD 3d via HDMI 1.4 using frame packing?
What software are you using for viewing?
Scott
'The Green Room'
post #201 of 1551 Old 11-11-2010, 05:33 PM
ricabullah's Avatar
I know it's not related with 3D HTPC thread directly but i wonder if ex-fat PS3 plays 3D Blues with October 3.5 update? (i know even slim PS3 downsamples HD audio to dts or ac3 but what about 3D video?)
And the question is how PS3 slim sends 1080p over HDMI 1.3?
Is it possible, if so what is 1.4 for?
Or does it send only 720p via 1.3?
Chronical Tester
post #202 of 1551 Old 11-12-2010, 12:11 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
PS3 with 3.5 sends 1080p24 frame packing (i.e. 1080p x 2 at 24Hz) by *software update*. It's purely a software matter if it decodes MVC (by Cell processor) and send it as HDMI 1.4a 3D video format (this post).
renethx is offline
post #203 of 1551 Old 11-12-2010, 02:39 AM
ricabullah's Avatar
rene, i really confused
If PS3 Slim's 1.3 is able to be updated to 1.4 via a firmware (3.5 update) then the same must be valid for ex-fat PS3?
Correct?
Chronical Tester
post #204 of 1551 Old 11-12-2010, 03:13 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #205 of 1551 Old 11-12-2010, 04:22 AM
ricabullah's Avatar
Chronical Tester
post #206 of 1551 Old 11-12-2010, 04:30 PM
ricabullah's Avatar
If it is so easy, AVR manufacturers are expected to update their firmware.
In this case our 1.3 AVRs would be 1.4?
But it won't be happened; never.
Chronical Tester
post #207 of 1551 Old 11-14-2010, 05:33 AM
sobskarlpox's Avatar
How do you guys play your 3D ISO's or MKV (2D to 3D from PDVD10 or TMT3)? Does the 3DTV recognize the content as 3D content automatically and syncs with the shutter glasses?
sobskarlpox is offline
post #208 of 1551 Old 11-14-2010, 01:52 PM
ricabullah's Avatar
Let me tell my own experience:
HW:
HTPC (Clarkdale mobo+460/430) + nVidia 3D Vision glasses kit + Acer H5360.
Original 3D BD: Plays fine with PDVD 10 and WinDVD10. (you should configure the player to 3D-display, source etc)
Created file: m2ts or m2ts under BD structure.
I used TSMuxer to test; re-created BD or m2ts from the main mpls works with PDVD10 only (m2ts file only). WinDVD doesn't work in 3D mode.
Created ISO: doesn't work with any player; always ignores 3D.
mkv: I don't think any mkv muxer is available for 3D as for now.
Chronical Tester
post #209 of 1551 Old 11-14-2010, 03:00 PM
jhoff80's Avatar
Quoted: 395 Post(s)
Liked: 361
Stereoscopic Player works in 3D for mkv with Haali splitter and ffdshow-tryouts installed.
XBL/Steam: JHoff80
jhoff80 is offline
post #210 of 1551 Old 11-14-2010, 03:13 PM
ricabullah's Avatar
I meant true stereoscopic BDs, not anaglyph files.
Chronical Tester
Reply Home Theater Computers
