Convert mkv files to play on PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-08-2010, 02:45 PM - Thread Starter
imp3r10's Avatar
I am wanting to play some HD files on some PS3's and XBOX 360s. I use my home computer as a server for my fraternity house and want to be able to stream HD video throughout our house.
This is a two part question. I can download the .m2ts files but they do not play on XBOX 360s. I tried converting .mkv files to .ts but (1) the files are huge 8gb for 50min, and (2) the audio isn't 5.1. When I play on my PS3 it says that its 5.1 but my receiver only picks up a 2.1 signal. I use Xilisoft Video Converter Ultimate and made sure the settings were 5.1 and AC3 auido codec. Anyone know how I can convert them correctly.
If there is no other way then I just want to convert them to .m2ts with 5.1 so I can play them on my PS3 and others in the house can have them. Anyone know of converters to .m2ts?
I'd like the 1st solution so I can make everyone happy, and would like a way to keep files size to a minimum (4gb for a normal .m2ts 1080p file)
imp3r10 is offline
post #2 of 3 Old 04-08-2010, 03:44 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Use MKV2VOB:
http://www.digital-digest.com/articl...ide_page1.html
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #3 of 3 Old 04-08-2010, 11:36 PM - Thread Starter
imp3r10's Avatar
thanks, will that keep the 5.1 audio and work for PS3 and 360?
also i use WMP as my media center with PS3 and 360 so will all those output files be streamed through WMP?
imp3r10 is offline
Reply Home Theater Computers
