PC screw thread size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-23-2010, 08:38 AM - Thread Starter
TODDAVS's Avatar
Quoted: 50 Post(s)
Does anyone know the thread size for the screws used in a PC to attach items to the case? IE this would be the cover attaching to the back or the dust covers over the slots for the MB and similar items. NOT for attaching hard drives or other periferals. (those are smaller threads).
TODDAVS is offline
post #2 of 2 Old 04-23-2010, 09:24 AM
SugarBowl's Avatar
http://en.wikipedia.org/wiki/Computer_case_screws
There are usually only 2 choices. M3 and 6/32. M3 is the most common. I think you can tell by seeing if the screw you have fits either your hard drive or your CDROM.
SugarBowl is offline
Reply Home Theater Computers
