Is the ATI 5450 the cheapest card that supports DTS HD, TRUE HD bitstreaming - AVS Forum | Home Theater Discussions And Reviews
Old 04-27-2010, 05:16 PM - Thread Starter
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Looking for a cheap and quiet HTPC graphics card.
thanks.
conan48 is offline
Old 04-27-2010, 05:33 PM
wolferl99's Avatar
from what I understand 5450 is the most reasonable priced item for bitstreaming if you don't go the intel mobo way.
just bought one at newegg for ~40 bucks. highly recommended. just make sure, that you get a) fanless version and b) low profile if you have a small (microatx) case.
update: http://www.newegg.com/Product/Produc...-340-_-Product that's what I bought. no low profile though, so i had to get the saw out!
wolferl99 is offline
