Frame rate jumps with DVD's in media portal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-03-2010, 05:06 AM - Thread Starter
HaLo6's Avatar
When I watch a DVD movie (not mkv's) in media portal every minute or so a couple frames, about 1 second worth, seems to advance at a faster rate, then it returns to normal only to repeat itself the following minute. Any ideas? I tried using ffdshow, MS Dvd decoder, and MPC (gabest) under MPEG-2 Options all the same. Fresh install of Win7 and MediaPortal 1.1 RC2.
I am using the
.2104 version of Intel HD graphics, (that covers the display driver and HD Audio)
3342v ffdshow,
MPC-HC standalone filters v1775
HaLo6 is offline
post #2 of 4 Old 05-03-2010, 01:27 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
I never play a DVD straight. I always rip to an .iso file, use daemon tools lite (a new win-7 compatible version) and play via MyVideos... Can't say I've seen this speed-up playback you're describing. I'm also NOT using any refresh rate changer options they added under 1.0.2 opting for the basic 1280x720 HDMI 60Hz my PJ uses natively. It could be a power-saver issue on your cpu/mobo, a priority (I keep MP set at ABOVE priority inside MP-config/general), CPU usage too high. Is this new since you upgraded MP to 1.1, RC2, or is this a new OS upgrade? When did you last have smooth playback?
Andrew Hornfeck is offline
post #3 of 4 Old 05-03-2010, 03:25 PM - Thread Starter
HaLo6's Avatar
i am not adjusting refrash rate at all... at its on a pretty regular frequency which doesnt point to any backgroud system utils... and I really dont have any installed... just barebones windows... i think its a codec issue just wanted to see if anyone else has seen anything similiar... I really just got all the lossy/lossless codecs working perfectly and now I get a video issue... if its not one thing its another...
HaLo6 is offline
post #4 of 4 Old 05-04-2010, 02:25 PM - Thread Starter
HaLo6's Avatar
bump?
HaLo6 is offline
Reply Home Theater Computers
