Audio output via both S/PDIF and HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-13-2010, 05:02 AM - Thread Starter
Fjodor2000's Avatar
Quoted: 349 Post(s)
Liked: 52
Hi,
I just wonder if it is possible to get the audio to both the S/PDIF output and the HDMI output at the same time when playing audio or video with audio on a HTPC?
Is that possible to achive?
PS. The reason for this is that normally when watching video, I want the audio to go from the HTPC's HDMI output to the HDTV so it's speakers can be used. But when playing audio only (i.e. music!), I want the audio to go through the HTPC's S/PDIF output to my HiFi system. And I don't want to have to manually change some configuration on the HTPC determining where the audio should be output every time I switch from playing audio vs video!
Fjodor2000 is offline
post #2 of 14 Old 05-13-2010, 09:39 AM
mirak's Avatar
Quoted: 46 Post(s)
I've got a similar question. My receiver doesn't have HDMI, so I was planning on running an HDMI from my HTPC (the onboard output from my gigagbyte h55m-ud2h) to my TV (Panasonic TC-P50V10), and then optical output from the TV to my receiver. That'll work for movies, right?
But if if I want to play music on my HTPC, I assume I need to run an optical direct to the receiver, right?
So if I have both the HDMI and optical outputs connected from my HTPC, is that going to confuse it?
Or, do I even need the optical output from my TV to the receiver? When playing movies, could I just send the video to the TV via HDMI and the audio to the receiver via the HTPC's optical output? That would be the simplest thing if it can be done.
mirak is offline
post #3 of 14 Old 05-13-2010, 09:59 AM
sgeissler's Avatar
Unfortunately, I cannot answer the OP question because I will eventually have the same setup and will need this question answered. But for mirak, I do know (unless it's different for an HTPC than a DVD/Blu-ray player) that if you hookup an HDMI from your HTPC to your TV and then send the optical audio from your TV to your receiver, you will lose your digital surround sound. The TV only sends a stereo signal from its optical audio output, unless it is from an OTA TV signal.
Hopefully someone else can answer the main question.
sgeissler is offline
post #4 of 14 Old 05-13-2010, 10:02 AM
Mike99TA's Avatar
You just have HDMI to TV and optical to receiver from PC - then you tell the PC to use S/PDIF for everything and as your default audio - you will never use audio on the TV. This would be the best way to set it up.
Mike99TA is offline
post #5 of 14 Old 05-13-2010, 01:38 PM
ES_Revenge's Avatar
Quoted: 411 Post(s)
Liked: 133
Originally Posted by Fjodor2000 View Post
Hi,
Not in Vista or 7 I don't think, no. Unless the application supports outputting to both at once, then I guess it might be possible.
Why not just use the hifi system for both types of audio? Or is it in a different room or something?
The easiest way to do that otherwise is just set Windows to use HDMI audio as the default and then use a music program where you can set the audio output device independently of the Windows default playback device (most 3rd party programs can do this--WinAmp, MediaMonkey, etc. should all be able to). So then you set your music player to output to the S/PDIF device (and not the Windows default) and off you go.
ES_Revenge is offline
post #6 of 14 Old 05-13-2010, 02:45 PM
jrwalte's Avatar
This usually isn't possible, as most TVs, if not all, do not pass through the DD/DTS signal over their SPDIF Out unless it is from an OTA source so all your receiver would be getting is 2 channel PCM audio. As stated, the best way to connect is to use SPDIF from your PC to your receiver.
jrwalte is offline
post #7 of 14 Old 05-13-2010, 02:48 PM - Thread Starter
Fjodor2000's Avatar
Quoted: 349 Post(s)
Liked: 52
Originally Posted by ES_Revenge View Post
Fjodor2000: I just wonder if it is possible to get the audio to both the S/PDIF output and the HDMI output at the same time when playing audio or video with audio on a HTPC?
ES_Revenge: Not in Vista or 7 I don't think, no. Unless the application supports outputting to both at once, then I guess it might be possible.
I'm not sure how I should interpret that. Do you mean this is an OS specific issue, i.e. it might work with Linux or Windows XP? Or do you mean it's an application specific issue? Or both?
The main reason is that my HiFi system is a 2-channel system with the speakers placed a couple of meters apart, and I feel that the dialog is not perceived as comming from the TV (where the video is shown) with that setup. I guess I'm lacking a center speaker basically (and I don't indend to get one!). It's quite annoying, so I actually prefer to use the HDTV's built in speakers.
Yes, having seperate media players for video vs audio would probably work (if they are configured as you described). The thing is though that I'd like to have a single media player for all media, e.g. only running Windows Media Center and playing both video and audio using that.
post #8 of 14 Old 05-13-2010, 03:02 PM
jrwalte's Avatar
It's an OS limitation and not hardware. It may be due to complex issues for the OS to know what to do. Say you have a DD source. The OS knows to pass through the DD signal on a HDMI and SPDIF signal, but if also transmitting to analog speakers, then the internal sound card has to decode the DD source and use its DAC. Maybe due to issues like this the devs decided to only allow 1 device selection at a time.
jrwalte is offline
post #9 of 14 Old 05-13-2010, 03:16 PM
Qaq
Qaq's Avatar
AFAIK, KMPlayer allows output to second device.
Burned by the Audio Inquisition
Qaq is offline
post #10 of 14 Old 05-13-2010, 06:04 PM
CloneX's Avatar
Would something like this help?
http://www.ambery.com/2hddodtsdihd.html
It has HDMI in and HDMI, analog and optical out.
CloneX is offline
post #11 of 14 Old 05-14-2010, 01:41 AM - Thread Starter
Fjodor2000's Avatar
Quoted: 349 Post(s)
Liked: 52
Yes, that might work. However I'd like to avoid having yet another box lying around, unless absolutely necessary...
If it can be solved in software that is preferrable. From what Qaq said, it seems to be an application issue? I'm not sure I'll be using KMPlayer though.
Is there anyone who has tried to get audio to both HDMI and S/PDIF simultaneously using e.g. Windows Media Center, XMBC, MediaPortal or similar? I have not yet bought my HTPC hardware so unfortunately I cannot try it for myself.
post #12 of 14 Old 05-14-2010, 09:33 AM
ES_Revenge's Avatar
Quoted: 411 Post(s)
Liked: 133
Yes it might work with XP and it would probably even work with Vista/7 if it were an AC97 sound device (not sure about this because I've never used an AC97 device in Vista). Because AC97 I don't even think it was capable of outputting different streams. The way the path was routed for AC97 was fixed 48kHz, and then the analog out was just a D/A conversion of the digital out. In 2ch PCM I mean. In bitstream (DD/DTS), the analog out would be off/silent.
But in Vista and with HD Audio (aka Azalia) the output devices are different. Like the digital output acts as if it were a separate soundcard altogether, you don't get simultaneous output on both digital and analog outs, not from the same stream. It might be possible for an application to output to two devices at the same time; but, I don't think I've seen an app that can do that; and, you're using VMC/7MC so that is out of the question anyway.
Ah I see. Makes sense.
Yeah there you have a problem because you aren't going to be able to do it automatically. You're going to have to select your default output device everytime you start VMC/7MC or WMP, because MS never designed a feature to use different outputs on different media playback.
The only other way around this is forget using digital output altogether. Use analog stereo output to the TV, and then (assuming your TV will be on when you are playing music) use the analog out from the TV to the receiver. If your TV will not be on when playing music, then you can split the output to go to both inputs by using simple RCA splitters or a headphone jack splitter at the PC's output and then two Y-cables into that.
The only thing I dislike about analog out from PC sound cards (particularly built-in sound cards) is the relatively low output level. But you gotta make some sacrifices/comprimises to get what you want. Either you are going to have to switch output devices, use other programs, or go analog...
post #13 of 14 Old 05-14-2010, 09:39 AM
jrwalte's Avatar
Using the analog also screws you over in that it will use the crappy on-board PC DAC instead of the good quality DAC I'm assuming you have in your receiver, since I don't know what your receiver is.
jrwalte is offline
post #14 of 14 Old 05-14-2010, 04:00 PM - Thread Starter
Fjodor2000's Avatar
Quoted: 349 Post(s)
Liked: 52
Yes, the intention is to forward the audio from the S/PDIF output to a $5000-10000 HiFi system (including a proper DAC!), so I'd like to avoid using the DAC on the HTPC's motherboard which would be a real bottleneck audio-quality-wise...
Reply Home Theater Computers
