Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 144 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 03-21-2012, 05:30 PM
jasonlund's Avatar
Oh duh. Sorry. Installing now from intel.
jasonlund is offline
Old 03-21-2012, 05:36 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
I'm confident that this will solve your issue.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Old 03-21-2012, 07:17 PM
jasonlund's Avatar
Seems to be working. Thanks so much.
Old 03-21-2012, 08:49 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
glad to hear it.
Shark007 is offline
Old 03-22-2012, 02:25 PM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
MyMovies
Well I finally decided to pony up the $50 to buy enough points to unlock the "external player" feature in MyMovies.
If anyone is thinking of using MyMovies in Windows Media Center, I highly suggest you do this.
Once I got it set up to launch MPC-HC as the external player, everything plays with ease. No more errors from WMC saying it can't play the file. No more picture quality issues (noticable improvements using MadVR in MPC-HC) and everything just seems to work well.
Much more enjoyable to use now.
sebberry is offline
Old 03-22-2012, 02:28 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
Originally Posted by sebberry View Post
MyMovies
Why not just use Media Browse to launch MPC-HC?
assassin is online now
Old 03-22-2012, 02:38 PM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
Because I really like the Collection Management component of MyMovies.
sebberry is offline
Old 03-22-2012, 02:40 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Can't fault you then. If there's a feature you really like then it is worth it for you to pay $50 for it.
Sammy2 is offline
Old 03-22-2012, 02:43 PM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
I also need the collection management feature - I don't do my ripping on my HTPC, so I need a way to manage the database from another PC.
sebberry is offline
Old 03-22-2012, 02:46 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Remote desktop and shared/mapped drives over the network with media browser / media center master work for me but if that works for you then its all good. I have drives scattered in two machines but they may as well be in my desktop..
Sammy2 is offline
Old 03-22-2012, 03:24 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
Have you ever tried media browser? Thats one of its major strengths, imo.
Old 03-22-2012, 03:52 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I don't really consider collection management of Media Browser to be a strength per se (since if you want to manage outside of MB you need to rely on a separate 3rd party tool, and I have always found using MB for metadata is less then desirable, at least for me). Although my setup is metabrowser + Media Browser it does work very well that My Movies has their own collection management program
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 03-22-2012, 03:57 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
I was mainly referring to the ability to be able to included multiple different pcs, drives, folders and files that show up easily as a single collection.
And I am with you on media browsers scraper. But there are ways to improve that metadata collection dramatically and make it automatic.
Old 03-22-2012, 04:15 PM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
Sort of how you can add multiple folders to the "Libraries" in Windows 7?
That's not a feature I need.
I feel like I'm catching flack for using MyMovies. I figure since I haven't bought anything like TMT (and don't need to since I use my PS3 for playing Blu-ray discs) I can buy MyMovies.
sebberry is offline
Old 03-22-2012, 04:20 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
No flack. Just trying to understand what the $50 gives you that you can't get free otherwise for what you want to do.
Old 03-24-2012, 03:49 PM - Thread Starter
GreenEyez's Avatar
Added :
  • Youtube & Youtube HD via Macrotube with working fixes (just tested 5 minutes ago) : http://www.avsforum.com/avs-vb/showp...69&postcount=7
  • MC Themer & MCE 7 Reset Toolbox for theme support instead of Media Center Studio
  • Updated Shark 007 pics and instructions for the latest version as of today
ToDo (tomorrow)
  • Replace AirPlay plugin with a more up to date solution.
  • Test out and make instructions for iOS vmcMote
  • Re-structure some parts of the guide, including the main menu (which isn`t working correctly, btw)
  • Set up instructions for the Media Browser EHS, for weather i mean, since there is no other working weather solution that i know of.
GreenEyez is offline
Old 03-31-2012, 04:26 PM
xcrunner529's Avatar
Quoted: 33 Post(s)
Why is Media Center in like 640x480 resolution every time I switch TV inputs? It's freaking annoying.
xcrunner529 is offline
Old 04-02-2012, 10:07 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
Is MacroTube working for anyone? I tried again yesterday using the updated instructions: re-installed, downloaded the replacement XML files but still get an error on any playback attempt, saying it can't be played for technical reasons or has been removed.
Running Win7 64 bit.
JDLIVE is offline
Old 04-02-2012, 10:31 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Does anyone used secondrun.tv? How is it?
joeydrunk is offline
Old 04-02-2012, 11:18 AM
Joe 6 Pack's Avatar
I've been having a weird issue where whenever I use my Harmony 880 to run the HTPC activity and bring my PC out of sleep WMC will be muted. Before I would see the little popup in the corner with a 50 which I assume is the volume level. Now it will come up and the little sound icon will be X'ed out if I press the info button. Anyone know what could be causing this. I might just need to add an additional keypress to the Harmony activity to hit the volume up key once to fix this.
Also, I asked this in the Plex thread but this one seems more active so I'll ask here as well. Is there a program that will allow me to integrate Plex into WMC7 with it's own icon on the main screen similar to how the XBMC, Boxee, and Hulu Desktop setup works. I would also need it to close WMC and then return to it once I close Plex similar to how the integration for those other programs work.
Just because I don't care, doesn't mean I don't understand.
Joe 6 Pack is offline
Old 04-05-2012, 07:51 PM
rcrach's Avatar
[quote=Joe 6 Pack;21858308]I've been having a weird issue where whenever I use my Harmony 880 to run the HTPC activity and bring my PC out of sleep WMC will be muted. Before I would see the little popup in the corner with a 50 which I assume is the volume level. Now it will come up and the little sound icon will be X'ed out if I press the info button. Anyone know what could be causing this. I might just need to add an additional keypress to the Harmony activity to hit the volume up key once to fix this.
You're going to hear people say it's an HDMI handshake issue but I think it's a Microsoft "feature" It will happen to me consistently if I put the unit to sleep while it's recording a show when it wakes up the volume is muted. Every time. which is kind of a pain because I have my remote mapped to control the TV volume and not the motherboard volume. I have timed sleep disabled.
rcrach is offline
Old 04-06-2012, 06:28 AM
hettar987's Avatar
[quote=rcrach;21873726]
You might want to check this thread http://www.avsforum.com/avs-vb/showthread.php?t=1390139, it looks like it's the same issue.
hettar987 is offline
Old 04-06-2012, 11:32 AM
Joe 6 Pack's Avatar
It hasn't happened for a while so it might be the case where it happens when the PC is put to sleep while recording a show. I'll try to see if I was recording something when I put the PC to sleep the next time this issue pops up.
Next issue on the agenda: I tried out MCE 7 Reset Toolbox per GreenEyez suggestion in the OP and loaded the fractal tiger theme and applied it. It ran through the process that looks like it was making changes to WMC and shows as the applied theme in the program but when I go to WMC the only change I see is the green text that Media Center Themer adds as a default change when you install it.
The version I downloaded was just a trial version so I'm not sure if that prevented it from actually making the change as it wouldn't let me make any changes to the Start menu. It's only $10 so I'm considering just buying it but I wanted to see it actually work before I pay for something that doesn't work on my system. I really like the ability to change items on the start menu as I could then have Movies default to Netflix and get rid of some of the other items like music since I use XBMC for my local movies, music, and TV shows. I uninstalled it since it screwed up my start page and misaligned some of the icons so I'm going to reinstall it when I get home tonight and give it another shot.
Old 04-07-2012, 03:07 AM
aravs's Avatar
would like to say thanks very much to the original poster for creating this guide. This is my 1st install and use of media browsing software for the pc and have to say i love it. Have a number of problems though and hope to get some guidance.
I cannot get avi files to play, get the dreaded "cannot play video" message. what program can i use to get media info about these files to further diagnose the problem here? is G-spot still used or is there something in media browser or windows directly that i can use and report back here with?
followed the guide explicitly for installing everything for Shark's codecs except the LAV Filters/LAV Audio decoder and LAV CUVID decoder. Did not instal madVR, do i still need it?
i am confused by sharks setup instructions under the MKV tab which says to use LAV's splitter but i do not have LAV's splitter installed. Is thigs wrong? I have mine set to Gabtest's splitter. Could this be upsetting my avi playback?
I watch a lot of foreign films from idia, japan etc. How and where do i enable and select subtitles?? I see no option via right click or otherwise to enable the use of english subtitles in media browser.
BTW, i also have MPC-hd installed and it plays everything flawlessly with control over subtitles and multiple tracks (including those stubborn avi the media browser wont play|).
please any guidance or input on these problems would be greatly appreciated
aravs is offline
Old 04-07-2012, 05:59 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Codec packs (sharks) already have all the the different programs installed. You don't need lav because it is included in sharks.
Old 04-07-2012, 07:21 AM
ryanm1058123's Avatar
Random newbie question - I want it so when the tv is turned on... Live tv is turned on (I always have WMC open on my htpc) and when I turn off the tv live tv gets turned off... How can I get this to happen?
ryanm1058123 is offline
Old 04-07-2012, 07:24 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Theres some plugin somewhere that does this, maybe greeneyez knows it. Il look for it.
Old 04-07-2012, 08:09 AM
userx's Avatar
Hey Guys, I am running Windows 7 64 (Ceton Infinitv 4) with a Geforce 9500 HDMI through a Denon 3808CI to a Samsung Plasma. I am having an issue where when I turn the tv back on in the morning I hear the windows sound that it detects the tv is connected then get a very loud screeching sound from media center live tv. When I close WMC and open again, all is fine. Anybody have any ideas what might cause this? I tried turning all sleep functions off and that has not helped.
userx is offline
Old 04-07-2012, 10:12 AM
Quoted: 33 Post(s)
http://www.missingremote.com/guide/c...a-center-valve
Old 04-07-2012, 10:38 AM
Yeah.. But will this work when the tv gets turned back on?
