Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 155 - AVS Forum
post #4621 of 4641 Old 12-18-2013, 02:54 PM
AzDragonLord's Avatar
Originally Posted by dbailey75 View Post
the only way around this is to do a restore of your existing drive image, or clone and some times this has not worked. A reinstallation of the OS is guaranteed to break DRM, bye bye to your copy once programs.
I did this exact thing to move my OS to a SSD drive, it broke my DRM because of the hard drive change.
AzDragonLord is offline
post #4622 of 4641 Old 12-18-2013, 04:28 PM
dbailey75's Avatar
Liked: 33
that's nuts that you can't even swap out a drive, but we don't really have a choice.
Did your shrink your partition such that you could do a straight clone of your exiting OS partition, to the SSD?
PSN: CAPTDANMAN
dbailey75 is offline
post #4623 of 4641 Old 12-18-2013, 05:28 PM
Dark_Slayer's Avatar
Quoted: 29 Post(s)
Liked: 215
I thought I had replied in here but it was a different thread on this same topic. I'm not sure if clone worked, but I thought the repair windows installation from system image worked fine?
Which one are you referring to when you say you did that exact thing
Dark_Slayer is offline
post #4624 of 4641 Old 12-20-2013, 04:27 AM
The SSD drive was larger than my original OS drive. I used Partition Magic to clone the drive over.
post #4625 of 4641 Old 12-20-2013, 04:29 AM
I used Partition Magic to clone the OS drive over to a new SSD drive.
post #4626 of 4641 Old 12-30-2013, 11:02 AM
swing8's Avatar
Is there a way to wipe out all the WMC settings and just start over? I actually had it set up fairly well until...
1. I added a HDHomerun tuner which for a while only saw 2 of the 3 tuners and wouldn't d/l a channel guide. I got that fixed then
2. I saw the guide at the beginning of this thread and tried to switch to media browser from metabrowser. The themes don't seem to be applying and now I can't use the HDHomerun. The guide is still populated but whenever i choose a channel it hangs then says it can't find a tuner.
I think I'd like to just follow this thread from scratch, although that may be drastic unless someone can help with the HDHomerun.
swing8 is offline
post #4627 of 4641 Old 01-01-2014, 08:03 AM
WaterBoyz's Avatar
I think I'm using the first .gov time server, time.nist.gov, which has been anywhere from right on time to roughly off by 15 seconds, one way or the other when compared to the time I get on the Comcast weather info channel, powered by the weather channel. I have my time set to sync every ten minutes if I recall correctly, and was the single best thing I've done to my HTPC in terms of reliable recordings.
as far as the sycn feature, I think that's left over when you could sync files to your zoom or maybe other portable media player
Are you using the Task Scheduler for the 10 minute time fetch?
And while I got you, I have a program, RealTemp, that I can't seem to get to stay active. As in, when I start it and come back next day, it is not running. The HTPC is 24/7. I'm pretty sure I have it in the Startup group. Any preliminary ideas?
Thanks..........
I'm old.
Was trained on vacuum tubes.
Most everything I've worked on is in the museum or on the History Channel.
WaterBoyz is online now
post #4628 of 4641 Old 01-01-2014, 08:33 AM
dbailey75's Avatar
Liked: 33
Thanks..........
Here are some basic directions on the time sync, but once your in there you can see that you apply different options, http://www.pretentiousname.com/timesync/, I'm not familiar with real temp, I might suggest you work with the developer, its not like your trying to run it as a service, you could also try CPUZ, GPUZ (which I think is from the same dev as Realtemp), and you can also try speed fan to monitor temps.
Thanks for the reminder on the time sync, I just rebuilt one of my HTPC's, and forgot to apply this fix. Happy New Year.
PSN: CAPTDANMAN
post #4629 of 4641 Old 01-01-2014, 03:22 PM
gonzo90017's Avatar
I followed the directions on the page but it never worked for me. I've since started using AtomicClockSync which is working great.
I have it sync the time every 12 hours.
gonzo90017 is offline
post #4630 of 4641 Old 01-02-2014, 05:06 AM
dbailey75's Avatar
Liked: 33
definitely go with what ever works for you and is easy, but for the benefit of others, the directions on the link do work, but a couple of items that may throw you off, if you copy and past the program and arguments, make sure you don't accidently include a space at the beginning or end, and on the triggers tab, the author does not highlight that he/she has checked the enabled box, this is crucial and makes it all work.
PSN: CAPTDANMAN
post #4631 of 4641 Old 01-02-2014, 06:52 AM
post #4632 of 4641 Old 01-02-2014, 08:52 AM
geoffgoddard's Avatar
Follow well documented instructions to the letter should work.
geoffgoddard is offline
post #4633 of 4641 Old 01-04-2014, 11:47 PM
gerryinnv's Avatar
A few weeks ago I realized that my sports option is gone from WMC. I figured it was something I inadvertently did but I checked on my 2 other WMC computers and it's gone from all of them. I'm assuming this is something done deliberately by MS although I can't imagine why in the name of God they would remove such a useful option from WMC? Is there any way to re-enable it?
gerryinnv is offline
post #4634 of 4641 Old 01-05-2014, 12:46 AM
rc05's Avatar
Liked: 44
Nope, it's gone. This is the message that was posted in the Sports page, but the KB link doesn't work.
As of December 10, 2013, the Windows Media Center Sports experience will no longer be available. Please visit http://support.microsoft.com/KB2901043 for more details. You can still find all your favorite Sports news through your internet browser at http://www.msn.com/sports.
rc05 is online now
post #4635 of 4641 Old 01-05-2014, 10:07 AM
gerryinnv's Avatar
Incredible. Only Microsoft...
post #4636 of 4641 Old 01-05-2014, 11:38 AM
WaterBoyz's Avatar
Just curious, where did you find the spot to select "10 minute" fetch? I only noticed daily.
I'm old.
post #4637 of 4641 Old 01-05-2014, 11:46 AM
WaterBoyz's Avatar
While on the subject of time, noticed that the time in WMC7 was behind the PC SysTray time by about 2 hours. I closed WMC and restarted it. Time is correct now. I've not checked every day so this could be an intermittent issue.
I did a quick 1/2asse search and found no obvious answer.
I just installed the "Make Windows synchronize time more often" scheduler. I'm guessing that is for the M$ clock.
I did check in WMC under Tasks>General>blah blah to enable the update service and it was.
Any thoughts?
I'm old.
post #4638 of 4641 Old 01-05-2014, 12:44 PM
dbailey75's Avatar
Liked: 33
Yep, I loved checking the scores, seeing the other games that were on now and later, this feature stopped working earlier in the year. Here MS has a product, that use to be included with every single version of windows, and they failed to capitalize, MCE would destroy a roku, Apple TV, and it's been around since 2000 or there abouts, a product before it's time, but did you ever see them advertise MCE in a commercial for windows? I'll compare MCE to windows home server, a fantastic piece of software, that they poorly promoted.
PSN: CAPTDANMAN
post #4639 of 4641 Old 01-05-2014, 12:45 PM
dbailey75's Avatar
Liked: 33
it's under triggers,
triggers.JPG 50k .JPG file
PSN: CAPTDANMAN
post #4640 of 4641 Old 01-05-2014, 12:48 PM
dbailey75's Avatar
Liked: 33
Any thoughts?
Check the clock in the bios, it could be the issue, maybe you need to replace the battery on the MB too.
PSN: CAPTDANMAN
post #4641 of 4641 Old 03-21-2014, 06:00 AM
bnewt's Avatar
Is there a way to delete all channels & program guide information from Media Center? I had a new pc built with windows 7 32 bit, which I thought was 64 bit. In this set up I believe that when I was going thru
the original set up process, I scanned for the channels 1st & then added the guide information. Regardless, all of the local channels appeared. Then I had windows 7 64 bit installed. This time, I downloaded the guide information & then scanned for the channels. Now I can't receive the local ABC channel. It appears in the guide & shows 100% in the edit channel screen, but I get no picture or sound. I even tried to add manually & nothing. I thought about disconnecting the antenna & scanning, but did not know if that would clear out the channel information. Any suggestions, greatly appreciated
May God Guide and Guard the USA!
bnewt is offline
Reply Home Theater Computers
User Tag List
