Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #4651 of 4760 Old 08-17-2014, 03:55 PM
Ken.F's Avatar
Quoted: 1545 Post(s)
Liked: 1337
Originally Posted by JorgeA View Post
I wonder -- if the Ceton driver gets reinstalled, will that affect the ability to watch previous copy-protected recordings, or not really?
Protected recordings are tied to the WMC computer that made the recording, not the tuner. I've re-installed drivers, replaced a failed CableCARD and cloned the OS HDD to a SSD and that had no effect on being able to play protected recordings. I've since removed the Ceton tuner card from that computer and installed it in a different computer. All of my protected recordings continue to play as long as I play them from the PC that recorded them.
Ken.F is offline
post #4652 of 4760 Old 08-17-2014, 04:35 PM
JorgeA's Avatar
Quoted: 59 Post(s)
Wow, it's a relief to know that I can experiment around so much without fear of losing everything the wife has recorded. Thanks @Walternate and @Ken.F for the info.
After the latest fail, I set off the AV (Norton) firewall to be turned off for 1 hour and rebooted the PC with the firewall off, to see if WMC screws up near the 60-minute mark when the firewall comes back online. From my reading, firewall issues are another thing to look at, although I've never had any problems with that before.
Everything's working again for now. This time WMC invited me to set up or activate the CableCard, but clicking through most of that I was able to tune any and all channels again. For now.
JorgeA is offline
post #4653 of 4760 Old 08-17-2014, 05:06 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
Help!
I'm using WMC on Windows 7 Home Premium, with a Ceton InfiniTV4 PCI-e tuner.
Everything had been working fine for months until this afternoon, when I installed this month's massive load of Windows Updates. Unfortunately, to confuse things there was also a Norton Internet Security update that required a reboot, and a spontaneous "Microsoft Office Starter 2010" update (I'd never had one of these before on this machine).
After the reboot, I had to do the usual things with WMC to get it working again -- slide out the CableCard, wait 30 seconds, and slide it back in, then change the channel. Everything seemed to be working fine, but then after a few minutes the screen went black. None of the usual quick fixes I did (close and relaunch WMC, slide the CableCard out and back in, reboot the computer) got it to work again. At best I wouid get the "Viewing or Listening Conflict" error, or else the one telling me that "The TV signal cannot be configured because no TV tuner was detected."
What's frustrating is that when I go into Device Manager, it tells me that the tuner is working properly. Moreover, the Ceton Diagnostics Tool gives me all green checks, including the ones for tuning to a channel to check for entitlement/authorization. And yet WMC won't budge; going into TV Setup it tells me that it can't find any tuners?!?
What could be going on, and what can I do to get this fixed? WAF is fast plummeting to zero and a cableco DVR is looming on the horizon.
TIA for any tips or suggestions.
System Restore is your friend. Roll back to the restore point that Windows automatically created before installing all those updates.
My WMC box is dedicated to that task. I've not only turned off Windows Updates, I've also turned off the Update service itself (otherwise, "critical" updates will continue to slide in). I've learned over the years that what you describe is more typical than not, as a result of various updates.
gonzo90017 likes this.
adam1991 is offline
post #4654 of 4760 Old 08-17-2014, 07:29 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
And here's the best reason to leave updates off for a PC that does nothing but record TV and serve it to the wife and family:
http://www.computerworld.com/s/artic...f_Death_update
Microsoft urges customers to uninstall 'Blue Screen of Death' update
One of last week's security updates has bricked an unknown number of PCs running Windows 7
...Within hours of its release, however, users reported that MS14-045 had generated a Stop 0x50 error on some systems, mostly on Windows 7 PCs running the 64-bit version of the OS.
"Installation went smoothly. After rebooting everything worked fine. But when I shut down my notebook and switched it on a little later it came up with a blue screen with a Stop 0x50 in Win32k.sys. I could not even boot into safe mode as Windows failed to start no matter which mode chose," wrote a user identified as "xformer" to start a now-long thread on Microsoft's support discussion forum...
adam1991 is offline
post #4655 of 4760 Old 08-18-2014, 10:45 AM
dbailey75's Avatar
Quoted: 62 Post(s)
Liked: 47
yet another reason why it makes sense to backup that HTPC too, even if your media is stored some where else. Otherwise all those encrypted recordings are toast.
PSN: CAPTDANMAN
dbailey75 is offline
post #4656 of 4760 Old 08-18-2014, 12:37 PM
jeremyhelling's Avatar
Quoted: 32 Post(s)
I had not one but TWO different Windows 7 64-bit updates corrupt the partition of my secondary 3TB WD Red HDD. Two different drives, two different updates. Still trying to rebuild the partition of one to not lose all the data contained within as there were some files that weren't backed up on the 2nd one. It should be noted that in both instances these were brand new WD Reds known for reliability and were less than 3mos old at the time of the update that resulted in a toasted registry after the very next reboot.
Jer
'Build a man a fire and he stays warm for one night. Set a man afire and he stays warm for the rest of his life.'
jeremyhelling is offline
post #4657 of 4760 Old 08-18-2014, 09:21 PM
JorgeA's Avatar
Quoted: 59 Post(s)
Sadly, System Restore wasn't enough of a friend to resolve the problem. I tried three different restore points, including two that were prior to the Windows Updates, and it didn't help.
Gor a new CableCard today in case it was that which was acting up. Put it in, called Comcast to activate it, and it worked -- for about an hour and twenty minutes, then we went back to the same "Viewing or Listening Conflict" message.
I checked Event Viewer and all it says is that, at the specific moment the error occurred, handling of the tuner switched to "manual".
That "conflict" error in WMC has been coming up fairly reliably at one of three points in time: 4-5 minutes after rebooting and relaunching WMC (plus sliding the CableCard out and back in its slot); or about 20 minutes after; or about 1 hour 20 minutes after. Today with the new CableCard it stopped again at approximately the 1:20 mark.
Two questions:
1) Could it be the Ceton tuner that's acting up, and not the CableCard and not Windows? (Although it would be one heck of a coincidence that this started just when I installed Windows and Norton updates.)
2) If I reinstall Windows from scratch, will I lose access to the protected recordings? Presumably in order to keep the recordings at all, I'd have to copy them off the internal hard drive, then copy them back to the internal drive after the fresh Windows installation. (I did see Ken.F's reply, but want to make sure that what he said also applies to Windows reinstalls.)
Wife has started to talk about WMC in the past tense: "It was a nice experiment with its own advantages over a DVR, especially that talking double-time fast-forward, but..."
JorgeA is offline
post #4658 of 4760 Old 08-19-2014, 02:31 AM
Ken.F's Avatar
Liked: 1337
You probably won't be able to play your protected recordings after reinstalling Windows.
Ken.F is offline
post #4659 of 4760 Old 08-19-2014, 08:47 AM
JorgeA's Avatar
Quoted: 59 Post(s)
Exclamation
Thanks for that info, good to know if it comes to that.
Good news, though: I changed a couple of settings in the Norton firewall according to these instructions. Everything was still working last night well after that 1:20 mark, and I left it playing a cable channel overnight (with the TV set off). Still working this morning!
I had no reason to suspect anything having to do with the firewall, as I'd always used Norton on this PC and never had a firewall-related problem. But I was running out of options other than reinstalling Windows. (The other option was, I was about to open a ticket with Ceton to see if the tuner had gone bad.)
Then I thought, Saturday's Norton update involved installing a new version of Norton Internet Security, and it occurred to me that in their infinite wisdom they might have changed some setting along with the new version of the software.
Not sure what the old firewall setting might have been, but I changed the Ceton tuner from "full trust" to "shared" (as Ceton recommends) and that seems to have done the trick. So far, so good.
Man, a WMC system is so complicated. So many things that could go wrong. Definitely not for the impatient or the convenience-minded, but well worth it if you're willing to take it on.
JorgeA is offline
post #4660 of 4760 Old 08-20-2014, 09:31 AM
sgbroimp's Avatar
Quoted: 277 Post(s)
Liked: 36
There are a couple of no-no's for Tuner-HDPC's according to some including Assassin and Ceton: One Anti-virus system only and preferable MSE, no doubling up on that. Second, keep the install/use of other programs to a minimum. Do not use as web surfer above all. I recently did a complete Win7 reinstall, however, and lost no recorded material. Last year lost an MB and kept most but not all recorded material. Will depend on how much protected premium TV content you recorded. Mine was just regular channels, so no big deal apparently.
sgbroimp is offline
post #4661 of 4760 Old 08-20-2014, 10:31 PM
JorgeA's Avatar
Quoted: 59 Post(s)
We do do most of that list, except for Norton instead of MSE, and using Internet Explorer to visit Hulu/Netflix or network sites for the occasional show streaming. (We just got into "Extant" and have been streaming from the CBS website.)
I'm especially glad to learn that you got to do a complete Windows reinstall withoug losing recorded material. It's reassuring to know that we can always resort to that when all else fails and not necessarily lose the protected programs we've stored up. (We don't have a lot of them, mainly some movies, but it would still be disappointing to lose them.)
JorgeA is offline
post #4662 of 4760 Old 08-22-2014, 05:15 AM
sgbroimp's Avatar
Quoted: 277 Post(s)
Liked: 36
I want to come back on the topic of material loss with an update: As noted, I had my Win7 reinstalled this week. Last night I had a careful look at my recorded tv shows which includes movies of course (I do not record/rip from DVD or BluRay so do not know much about that), but out of perhaps 100 recorded shows and films, 5 films showed the plain blue screen in place of the scene shot which one normally sees. Going to them, I see they can no longer be played and at the bottom they have a logo and the words "copy protected", so this type of stuff you will apparently lose. You should be able to tell in advance what is copy protected I think. I lost "the Longest Day" which made me unhappy as I am going to Normandy next month, but I think my library probably has. Anyway...word to the wise. Wonder if you cloned that drive before you did the re-install if that would hold the material. I would think it might, but others are more savy than I am on this.
sgbroimp is offline
post #4663 of 4760 Old 09-02-2014, 01:47 PM
dbailey75's Avatar
Quoted: 62 Post(s)
Liked: 47
Interestingly, I had a similar issue reccenlty, I have Norton on my main office PC and my kids for some reason like to watch TV in there, anyway, there was a Tuner profile that you could enable in the Norton firewall setting to open the proper ports, but I guess my Norton was automatically updated, and and the new setup was blocking the ports, and I followed the exact same instructions mentioned above, and I'm good to go. Easy enough.
PSN: CAPTDANMAN
post #4664 of 4760 Old 09-10-2014, 11:20 PM
Vipfreak's Avatar
Quoted: 82 Post(s)
Liked: 83
My win 7 mce recordings seem fine and for a while now I've been using MCEbuddy to transcode my recordings into a smaller mkv file so I can watch them on the go. My PC however pretty much dedicated to the transcoding will create video hesitation, artifacting, and video/audio sync issues. Anyone have any idea why? I'm on a i5 with 4 gb of ram (thinkpad x1). Thanks for your help. Also, MCEbuddy is on high priority.
My Summer Motto: "When Nature turns off the damn heat I'll turn off my A/C"
Vipfreak is offline
post #4665 of 4760 Old 09-11-2014, 11:56 AM
mteastham's Avatar
Quoted: 26 Post(s)
I'm very sorry if this has been discussed here already, but where did my "sports" tier go in my WMC homescreen? I used to have "sports" along with movies, music, TV, and the like.... Thanks for any help you can offer!
mteastham is offline
post #4666 of 4760 Old 09-12-2014, 09:25 AM
JDLIVE's Avatar
Quoted: 96 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
It's no longer functional, along with the "Internet TV", etc. WMC is really down to just DVR/LiveTV. With the occasional scare when the guide data function breaks.
JDLIVE is offline
post #4667 of 4760 Old 09-12-2014, 10:02 AM
Quoted: 32 Post(s)
I personally have never had my guide not there in the years I've been using WMC as my only media service house-wide.
Jer
post #4668 of 4760 Old 09-12-2014, 10:42 PM
JorgeA's Avatar
Quoted: 59 Post(s)
I noticed that the other day on my Vista Media Center system (OTA, not cable). Most if not all of the Internet-dependent programming is gone. I used to be able to watch sports recaps and all sorts of old TV shows online via WMC -- Dick Van Dyke, Star Trek, you name it. Not anymore, at least not through the "one-stop shopping" of WMC.
The question now is whether WMC will even make it in any guise into Windows 9. IIRC, it was already relegated to a "media pack" that you could buy for $15 if you also shelled out an extra $100 (over and above Win8) for Windows 8 Professional.
JorgeA is offline
post #4669 of 4760 Old 09-12-2014, 10:48 PM
JorgeA's Avatar
Quoted: 59 Post(s)
You've been fortunate. There are threads around the forum where people have reported guide outages where the programming guide wouldn't update for days at a time. It's happened to us, and I sure do get nervous when that happens -- WAF would drop like a stone if the guide got to zero days advance info.
JorgeA is offline
post #4670 of 4760 Old 09-13-2014, 03:22 PM
mdavej's Avatar
Quoted: 2164 Post(s)
Liked: 952
Everybody has had outages, but most probably haven't noticed. It usually gets corrected before the data runs out. There was a worldwide guide failure a few months ago. Took MS a while to find someone who knew how to fix it since nobody is assigned to work on WMC full time anymore.
Keeping my fingers crossed WMC survives in Win 9. If anything, with so much more streaming now than when WMC was conceived, they should capitalize on the platform and improve it. With Xbox One it's as if they forget WMC ever existed and used technology from 10 years earlier. IR blasters, seriously?
mdavej is offline
post #4671 of 4760 Old 09-13-2014, 04:02 PM
Ken.F's Avatar
Liked: 1337
No WMC extender capability was a total shocker to me.
Ken.F is offline
post #4672 of 4760 Old 09-13-2014, 10:18 PM
C17chief's Avatar
Liked: 24
I don't think it was much of a surprise. It's no secret cable co's spend a lot of money on politics, writing laws to clearly protect and increase their profit rather then doing anything beneficial to the average person, etc. I would not be surprised in the least if they had a hand in not only helping WMC die out, but especially extender functionality. Even though WMC may be 1 box rental they lose out on, when you start talking extenders, now you are talking an average of several. How many times have you heard or seen people mention spending $30-$40+ per month on provided equipment alone! That's a big revenue stream they lose out on if this stuff really started catching on, so of course they need to make their closed door deals and such to prevent that from happening.
I'm def not one for conspiracies or anything, but I personally think this is one of the biggest reasons why WMC isn't being touched anymore, no other software has surfaced that really has the same or better functionality these days, etc. When WMC came out, especially with the cablecard support, it was a little ahead of the times as people weren't considering using desktop computers in that way, hardware wasn't quite as small, powerfull, and efficient as it is today, that sort of thing. There were also a few other players around too (remember Sage for example?) at the time. Just seems kind of odd to me that finally once this stuff reached a point that it could really start catching on fast, all the big commercial software suddenly gives up/goes away/no new players. I don't think that is coincidence or that MS threw in the towl on WMC because it would never catch on or anything. I think an outside hand helped make things go away.
C17chief is offline
post #4673 of 4760 Old 09-14-2014, 09:53 AM
Quoted: 32 Post(s)
I'm a gamer and own 4 Xbox 360's... soon to be five. I also own many PCs and laptops. If Micro$oft had native WMC support in Windows 8 and the Xbox One I likely would have bought several of each. I've been a gamer for a while and would have had at least two One's pre-ordered for launch and would have surely replaced the other two shortly thereafter if they made the cut gaming-wise. Funny that they named it the 'One' because their idea was to use one device to replace all the others you currently own. Funny that I've had 'One' device for all of our media & gaming needs for years now but to upgrade to the new 'One' I'd have to start using two devices once again due to lack of WMC support. Lame. This is a larger oversight than M$ realizes. WMC is a fantastic product with plenty of ways to improve and monetize but they missed the boat entirely.
Jer
post #4674 of 4760 Old 09-15-2014, 10:43 AM
JDLIVE's Avatar
Quoted: 96 Post(s)
Liked: 51
Yep, that's what I meant, not an actual failure of the guide data, but a down-to-the-wire race to get it working before it runs out.
JDLIVE is offline
post #4675 of 4760 Old 09-21-2014, 02:59 PM
JorgeA's Avatar
Quoted: 59 Post(s)
Unpromising early scoop on the inclusion of WMC in the upcoming Windows 9. From Windows Weekly 375 (transcript):
Leo: I presume it's too early to know, but will Windows Media Center be included in Threshold? It wasn't included in 8, right? But you could download it later.
Mary Jo: I'd be surprised.
Leo: It'd be shocking if they put it back in. Look you got a menu button, let's not push it okay? But they [may continue to offer it] as a download.
[Mary Jo: Maybe. Yeah, I haven't heard anything on that.]
Leo: I think Microsoft wants to stop that and I bet they'll do so as soon as they can.
(transcript fixed manually)
Continuing to offer WMC as a separate add-on package would be better than dropping it entirely.
If anybody has info (positive or negative) relative to this early report, please chime in!
JorgeA is offline
post #4676 of 4760 Old 09-21-2014, 05:09 PM
RichardU's Avatar
Windows 7 forever.
At least for my WMC DVR. I really wish Ceton would let me use the cable card with something else.
AzDragonLord likes this.
Richard
RichardU is offline
post #4677 of 4760 Old 09-27-2014, 11:11 AM
tighr's Avatar
Quoted: 42 Post(s)
Liked: 83
I just moved to a new city, and my computer has been boxed up for over a month. I recently went to setup WMC for the new zipcode, and am currently unable to download new guide data. It's a little distressing, but I'm doing some google-fu to try and find a resolution to this problem. Until I can get it set up, I'm unable to watch anything in WMC.
I also recently subscribed to FiOS here (my new city doesn't exactly have good coverage OTA-wise) so I'm trying to get WMC up and running before I go and get a cablecard. This really puts a damper in my tv-watching experience. The FiOS box is terrible.
~Tighr: Not helping the situation since 1983
tighr is offline
post #4678 of 4760 Old 09-27-2014, 11:38 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
http://www.thegreenbutton.tv/forums/...php?f=6&t=7861
Windows Media Center - TV guide issue
It appears switching to Google DNS no longer fixes the issue, you have to modify your hosts file to point to the right guide servers for now.
rc05 is offline
post #4679 of 4760 Old 09-27-2014, 12:27 PM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
This might be a dumb question, but don't you need the cable card installed and set up before you can download guide data?
dfkimbro is offline
post #4680 of 4760 Old 09-27-2014, 12:40 PM
tighr's Avatar
Quoted: 42 Post(s)
Liked: 83
No, WMC will download guide data for clearQAM. My Hauppage 2250 will add those channels, then once I'm up and running I'll get a card from Verizon, re-run the setup, and add the HDHomeRun Prime that I just bought.
I was able to download guide data by changing my hosts file, we'll see how long this fix lasts.
tighr is offline
Reply Home Theater Computers
