Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #4741 of 4760 Old 02-20-2015, 08:40 AM
Ken.F's Avatar
Quoted: 1514 Post(s)
Liked: 1294
Originally Posted by mdavej View Post
Those two are definitely incompatible...
Rats. You hit send right before I did.
Ken.F is offline
post #4742 of 4760 Old 02-20-2015, 10:52 PM
JorgeA's Avatar
Quoted: 59 Post(s)
Thumbs up
Those two are definitely incompatible. So you must use the matching dongle that came with each remote. But as I said, you can continue to use both simultaneously if you want. I found that the one on the left would wake my PC reliably, but the one on the right would not. So I also used both for years.
The thing I like about the old Ortek (the one on the left) is the integrated mouse. If you prefer your old remote, I have a couple like new that you could have for the price of shipping if you want ($4 or so). I only use the dongles since I have universal remotes. So either you take them or my wife throws them out. PM me if interested.
Thank you @mdavej and @Ken.F for the info on these remotes, it's just what I was looking for. If there were a "thumbs up" smilie, I'd be putting it right here.
It'd be a shame to throw out perfectly good remotes, but wife is very happy with the HP model as the buttons are bigger and easier to find in the semi-darkness. Thanks for the offer, though. Hope they find a good home.
JorgeA is offline
post #4743 of 4760 Old 02-25-2015, 11:31 PM
Liked: 0
Thanks! Good post. I love this sharing.
micagordon is offline
post #4744 of 4760 Old 02-05-2017, 12:50 PM
lfox's Avatar
Has anyone else gotten a notice that their Rovi TV Guide data is about to run out on Tues 2/7?
lfox is offline
post #4745 of 4760 Old 02-05-2017, 01:06 PM
Ken.F's Avatar
Liked: 1294
I got a pop-up in WMC this morning saying there were only 3 days of guide data left.
Ken.F is offline
post #4746 of 4760 Old 02-05-2017, 01:37 PM
jimmyv's Avatar
WMC Guide Data runs out 2/7 @ 6pm CST
Yep - everyone has the same problem - there have been 100's of posts on it here:
http://www.thegreenbutton.tv/forums/...0615&start=160
bmcn likes this.
jimmyv is offline
post #4747 of 4760 Old 02-05-2017, 02:22 PM
Davidt1's Avatar
Quoted: 104 Post(s)
Liked: 34
Guide on both my laptops run out on 2/8/2017. So it's not just me. Looks like I will have to go back to manual recording.
Davidt1 is offline
post #4748 of 4760 Old 02-05-2017, 09:00 PM
Worf's Avatar
Quoted: 477 Post(s)
Liked: 234
Do a guide update. I had guide data ending February 7/8 last week, and it turned out it was a rovi problem as TiVo had the exact same problem - just over a week if data.
I just checked and I have a full set of guide date till next week.
Worf is offline
post #4749 of 4760 Old 02-06-2017, 04:12 AM
Ken.F's Avatar
Liked: 1294
I updated the guide data this morning and now have 13 days worth.
Ken.F is offline
post #4750 of 4760 Old 02-06-2017, 08:14 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
Convert over to EPG123. Costs $25/year for the subscription to Schedules Direct, but worth it, IMO.
JDLIVE is online now
post #4751 of 4760 Old 02-06-2017, 10:02 AM
Davidt1's Avatar
Quoted: 104 Post(s)
Liked: 34
I clicked on the "Get the latest guide listing" and it downloaded and said downloading is complete. But there is no guide data.
OK: I just checked again. There is about two weeks of data now.
Davidt1 is offline
post #4752 of 4760 Old 02-06-2017, 10:07 AM
Davidt1's Avatar
Quoted: 104 Post(s)
Liked: 34
Definitely something to consider. Thanks.
Davidt1 is offline
post #4753 of 4760 Old 02-06-2017, 12:39 PM
Super Moderator
DrDon's Avatar
Quoted: 959 Post(s)
Liked: 1925
Yeah, I just forced an update. Good to the 19th, now.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #4754 of 4760 Old 02-07-2017, 02:57 AM
headcase151's Avatar
Quoted: 17 Post(s)
I updated the data Sunday, before the super bowl. It started recording the super bowl. When I went to start watching the super bowl. After 30seconds,the screen blanked out. Then I got a message drivers were missing for video play back. Still happening now I`m not getting update my Rovi warning now. Any ideas to what happened. I haven't had any problems with this setup in 7 years. Any help would be welcomed. Thanks in advance.Dennis
headcase151 is offline
post #4755 of 4760 Old 02-07-2017, 08:05 PM
lfox's Avatar
Does anyone else think the listings have improved since the guide data hiccup was fixed? Fewer teams TBA for college basketball for example?
lfox is offline
post #4756 of 4760 Old 02-11-2017, 05:10 PM
DavidinCT's Avatar
Quoted: 245 Post(s)
Liked: 69
I'll have to admit, after the last few "hiccups" the guide data seems to be a little better with ROVI. Double recordings are down, and details are a hair bit better. Besides the "No data" issues, I have not missed a recording in a while due to bad data, so I would say things are getting better.
Maybe it's because of TIVO users complaining (paying customers) but, if it gets better and more stable, I am all good with it.
But these...every 2 month 1-2 days with out data is starting to get to me.
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #4757 of 4760 Old 02-17-2017, 03:20 PM
etrin's Avatar
Quoted: 25 Post(s)
I switched to a silicon dust prime and windows media center, comcast cable card and have problems with channels.
The SD shows all my channels, and I can use the SD viewer to watch them but media center can not find 5 channels.
I looked at adding channels like 1220 TBS but it requires a signal of _ _._
I looked and can't find anything that shows these types of numbers for the missing channels.
Is there a list of conversions to get the media center to use the missing channels?
etrin is offline
post #4758 of 4760 Old 03-20-2017, 06:01 AM
6athome's Avatar
Quoted: 464 Post(s)
Liked: 140
I picked up a HP Z230 core 5 with Windows 7 pro. Dropped in a 9500 NVidia card for 1080 play back.
I have HD home run prime and can't get my HBO channels. WMC said it's not digital ready to display it and tells me to activate Windows, it is active . What am I missing? Also the sound will not play though HDMI and when I go to the NVidia setup it shows my Samsung but will not show up in windows.
6athome is offline
post #4759 of 4760 Old 03-20-2017, 06:25 AM
mdavej's Avatar
Quoted: 2152 Post(s)
Liked: 949
Several things going on here.
- Make sure cable card is properly activated with cable company. Without that, HBO will never work.
- Run Digital Cable Advisor until it passes. If you can't get it to pass, there is a utility to override it
http://rricketts.com/digital-cable-a...stry-override/
- Sound card needs to be set up to run in Exclusive mode.
- Confirm Windows is really activated. "Active" and "Activated" are not the same thing.
Have you ever run WMC before?
mdavej is online now
post #4760 of 4760 Old Today, 06:43 AM
Postmoderndesign's Avatar
Quoted: 238 Post(s)
Liked: 90
Yesterday, 7MC epg was back loading my TV schedule. Patience sometimes pays in the wacky world of software and hardware. But I am not making any promises for tomorrow.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is online now
Reply Home Theater Computers
