Windows 7 Media Center : Setup Guide, Knowledge Base & Support - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1081 of 4757 Old 07-25-2010, 07:55 PM
puckalicious's Avatar
Originally Posted by GreenEyez View Post
It will, the next version will support all subs according to MikeEby.
Regarding BR playback : f you want a more simple solution, just get TMT3 and rip to BR folders/ISO images. Yes, it costs, but BR licensing costs. That`s why if MS did an update for full BR playback, it would jump up the price of Windows, due to licensing fees from the Blu Ray Consortium. Tehnically, they already have a h.264/VC-1 decoder and m2ts splitter + AC3/DTS decoder, so they only need to build an HD audio decoder capable of bitstreaming, but the licensing fees will bump up the price of the OS.
Thx for the info! BTW do you know when next release of the GUI w/enhanced subtitle support is slated to come out?
puckalicious is offline
post #1082 of 4757 Old 07-25-2010, 08:07 PM
devoz's Avatar
If I want to use your guide to set-up an HTPC
but my Receiver doesnt decode Dolby True HD
or DTS MA(ie Hi-Def codecs)....
and I have a
video card that cant bitstream Hi Def codecs..but only provide Multi-channel
LPCM(ATI 4670 card)...
are there any set-ups for this configuration?
you only seem to talk about bitstream or analog set-up.
My receiver can handle multi-channel LPCM(that my video card can output)
I am assuming using FFdshow with haali media splitter for codecs.
Can you help with audio config using your guide??
devoz is offline
post #1083 of 4757 Old 07-25-2010, 09:02 PM
Postmoderndesign's Avatar
Quoted: 221 Post(s)
Liked: 85
I have the 4670 and use the realtek drivers with flac files to get lpcm. See this thread: http://www.avsforum.com/avs-vb/showthread.php?t=1029603 .
Use this guide to rip blu-ray: http://www.avsforum.com/avs-vb/showt...light=make+mkv
I play mkv's with MPC-HC. It will work and the audio is as good as bitsteamed in my opinion.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #1084 of 4757 Old 07-26-2010, 01:10 AM
devoz's Avatar
Thanks Postmoderndesign...I already use the realtek driver for the audio.
In this set-up guide however... it only talks about
settings for audio for either bitstream or analog.
With my setup...I obviously cant do bitstream
especially for Hi-def codecs like Dolby True HD.
ie my card is the 4670...and not a 5xxx series card
So I am seeking guidance how I can set-up to output
multi-channel LPCM...??
devoz is offline
post #1085 of 4757 Old 07-26-2010, 07:43 AM
Quoted: 221 Post(s)
Liked: 85
Right click the speaker icon in the bottom right system tray. Go to playback devices. Is Realtek HDMI output the active device? If so go into configure and see if it is set up correctly.
post #1086 of 4757 Old 07-26-2010, 12:22 PM
devoz's Avatar
yes...postmoderndesign... its showing the Realtek HDMI output
...and I have it set and configured for 5.1 output...
it has DTS and Dolby Digital ...plus all the sample frequencies under properties
(ie 32KHz, 44.1 KHz, 48KHz, 96KHz etc)
I am using an ATI 4670 card not an ATI 5xxx series card
...so I cant ..bitstream... Hi-def Blu-ray codecs...via FFDshow
(as per the set-up guide)
I am mainly concerned with configuring FFDshow ...
to output 5.1 Multi-channel LPCM
ie not passthru the DTS and Dolby digital AC3
...but also importantly!...to convert the Hi-def codecs ...such as Dolby True HD(ie from Blu-rays)
and DTS MA...into also 5.1 multi-channel LPCM and pass that to
the amp.
So I am hoping someone can guide me with these settings??
I already have the FFDshow set-up to convert 2-channel MP3 audio tracks
in Xvids/Divx...to 5.1 multi-channel LPCM
Then the ATI 4670 will be able to handle everything
I play ...and pass it thru its on-board sound card as multi-channel
LPCM
devoz is offline
post #1087 of 4757 Old 07-26-2010, 06:25 PM
duff99's Avatar
the amp.
LPCM
For dolby TrueHD it's quite easy. Just don't check the bitstream TrueHD box in ffdshow. For DTS-MA it's a different story since there is no open source decoder for it. You've got two choices. One is if you uncheck the box in ffdshow you'll get the dts core, I can't remember if it will bitstream or be LPCM. To get the best quality you'll need to convert to flac as stated earlier. Then FFDshow will output LPCM. Good luck.
duff99 is offline
post #1088 of 4757 Old 07-26-2010, 10:02 PM
devoz's Avatar
Thanks ...duff99...okay... I have seen that part in FFDshow
even if it only gives me the DTS core(probably the same for True HD)
..that will suffice till I can
afford a 5xxx series card..to be able to bitstream
and allow me to use this guide for my setup..Thanks
devoz is offline
post #1089 of 4757 Old 07-27-2010, 12:23 PM
the_average_joe's Avatar
Anyone have any insight into good windows 7 surveillance software -- preferably free (like Linux zone-minder -- but I would be willing to pay up to 100 bucks or so). I would build this for Linux, but everything I am reading about cable card tuners require Widows 7
I can't find anything....
Secondly, any one have a good recommendation for a 8 channel DVR card? I have 8 CCTV cameras with BNC connectors and one audio connection.
the_average_joe is offline
post #1090 of 4757 Old 07-27-2010, 01:37 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hi everyone, i plan on getting the 5770 for hd audio bitstreaming but i am concern that i will no longer be able to use the onboard audio?
well, i would only use hdmi audio bitstreaming when i am watching a movie/video. but when working, i want to use the onboard audio connected to a pair of pc speakers. i don't want the entire ht setup to be on when i am working.
can i still use both the onboard audio as well as the hdmi bistream, or is it one or the other?
thanks
smokarz is offline
post #1091 of 4757 Old 07-27-2010, 02:17 PM
johndeacon's Avatar
thanks
I found out last night when I installed the XFX Radion HD 5670 to replace an NVIDIA GT 8500. My on-board speaker setup was 5.1 through sound blaster.
I was amazed that when I applied power to my Sony 7.1 receiver/ Samsung 67 inch LED. The Radion video card drivers automatically switched the audio from the on board 5.1 speakers (attached to my sound blaster card) to the HDMI, rendering 7.1 sound on the speakers attached to my receiver. When I turned off the Samsung/Sony, the Radion drivers again switched the audio back to the on board 5.1 speakers.
I would imagine the same thing will occur if you use motherboard sound chipsets for your computer speakers.
johndeacon is offline
post #1092 of 4757 Old 07-27-2010, 05:06 PM
duff99's Avatar
FFDshow can decode Dolby TrueHD with no loss of quality, just not DTS-MA. So your not going to miss much.
duff99 is offline
post #1093 of 4757 Old 07-27-2010, 08:40 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
thanks, that's good to hear. what player are you using?
smokarz is offline
post #1094 of 4757 Old 07-27-2010, 10:46 PM
Supra13's Avatar
I just recently installed Windows 7 Professional Edition along with the shark codecs, and it's running smoothly for the most part.
However, WMC isn't playing my top gear hd videos properly. The video looks fine, but the sound isn't working at all. They are a '.ts' extension, and MediaInfo says that the audio stream is AC-3. My other movies that utilize AC-3 play fine. Any thoughts on this?
Supra13 is offline
post #1095 of 4757 Old 07-28-2010, 01:11 AM
RocShemp's Avatar
Quoted: 12 Post(s)
Anouncement : Since "somebody" decided to act like a douchebag even though i never attacked him, and pissed me off, when i get back from vacation, i`m starting my own codec pack.
As long as it's super user friendly, I look forward to it.
RocShemp is offline
post #1096 of 4757 Old 07-28-2010, 05:05 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
On the SWAP TAB, choose to disable Windows Media Foundation.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #1097 of 4757 Old 07-28-2010, 05:59 AM
johndeacon's Avatar
MPC-PC 64 bit for M2TS files; Windows 7 64 bit Media Center for non-bluray titles
post #1098 of 4757 Old 07-28-2010, 09:47 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
another question.
let's say when i want to listen to music (mp3, flac, etc) in mpc-hc can i use the hdmi connection on the radeon vid card to bistream audio to the receiver?
or this only work with bluray videos?
smokarz is offline
post #1099 of 4757 Old 07-28-2010, 10:25 AM
johndeacon's Avatar
another question.
I run bluray videos with the external MPC-HC because Windows Media Center (WMC) does not support that format internally. For all formats WMC supports, I prefer to run them via WMC using the hdmi connection on the radeon. The HDMI connect has run seamlessly on the video formats I have tried (M2TS and VOB) .
I have not tried flac files yet since I only installed the radeon about 30 hours ago. I will try that tonight but see no reason why they would not run via the HDMI connection.
post #1100 of 4757 Old 07-28-2010, 10:52 AM
Supra13's Avatar
Thanks for the help. That worked like a charm!
Supra13 is offline
post #1101 of 4757 Old 07-28-2010, 10:56 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Media Foundation (which WMC uses) doesn't support VC-1 (m2)ts, which is why you were getting sound but no video, and is the reason why you need to disable MF
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1102 of 4757 Old 07-28-2010, 12:58 PM
Supra13's Avatar
Hi Damian,
I've been browsing on your website trying to get my blu-ray rips to work with W7MC. However, I'm having issues with that as well. Here is my setup:
Denon avr-788 (doesn't support DTS-HD or Dolby TrueHD)
Windows 7 64-bit
ATI Radeon 4xxx
Shark 007 codec pack
Microsoft Audio Decoder disabled
Windows Media Foundation disabled
Quantam of Solaceblu-ray ripped with Another EAC3toGUI
AVC video stream
DTS (MA) audio stream
mkv container
Also, here's what my graphstudio graph looks like:
Any help from anyone would be appreciated. Thanks!
Supra13 is offline
post #1103 of 4757 Old 07-28-2010, 01:47 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Hi Damian,
Windows 7 64-bit
ATI Radeon 4xxx
AVC video stream
mkv container
You graph doesn't look good because you have no video decoder attached. I assume since you are using Sharks Codec Pack you have both the x32 and x64 version installed, correct? Unde the h264 tab what codecs do you have ticked off? Try using MPC HC. Under the mkv tab you can also try using Gabest instead of Haali
Cheers,
Damian
post #1104 of 4757 Old 07-28-2010, 02:57 PM
Supra13's Avatar
I think I screwed everything up by uninstalling the Shark codecs and trying this method: http://www.mediasmartserver.net/2010...-htpc-part-ii/
Is there a way I wipe the slate clean without reinstalling Windows and starting over?
Supra13 is offline
post #1105 of 4757 Old 07-28-2010, 03:19 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
When you uninstalled Sharks codec pack did you do it through the control panel or through his UI?
Ideally, the best bet to make sure you don't have any sort of conflicts would be to do a clean reinstall. Otherwise, can you conform with Win7DSFilterTweaker what video decoder is assigned to your AVC/h264 for x64
Cheers,
Damian
post #1106 of 4757 Old 07-28-2010, 03:50 PM
Supra13's Avatar
For H.264, it shows that I have it set to MPCVideoDec for 32-bit and 64-bi decoders.
Also, this is what the graph looks like now:
It looks like I have the opposite problem now. I'm tempted to just blast everything and start from scratch...let me know your thoughts. Thanks!
Supra13 is offline
post #1107 of 4757 Old 07-28-2010, 04:36 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Ouch, that graph looks ugly, you have a lot of stuff going on there! You should definitely not have AVI Decompressor or Color Space Converter in there. I honestly would just start from scratch. WHat I always do is after I do a clean install I create a backup with WHS, that way if something goes wrong I can just restore the backup. You can also create a restore point. If you liked Sharks Codec Pack I would try that again first, as that should be able to get mkvs working for you in WMC
Cheers,
Damian
post #1108 of 4757 Old 07-28-2010, 04:58 PM
Supra13's Avatar
Starting from scratch it is then. I'm not sure if I ever got the bistreaming to work correctly with the Shark codec pack, so I will give your DIY way a shot. Thanks for all the help.
Supra13 is offline
post #1109 of 4757 Old 07-28-2010, 05:00 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Try this first, after you do a clean install and install the HDMI driver (Catalyst 10.6 or Realtek HDMI), test out bitstreaming using just ffdshow + mpc hc. This is the best way to test out your setup in the cleanest state. You can see how to set up with my guide below or Greeneyez detailed on the first page of this thread as well:
http://www.mediasmartserver.net/2010...7-htpc-part-i/
Cheers,
Damian
post #1110 of 4757 Old 07-28-2010, 07:52 PM
johndeacon's Avatar
another question.
let's say when i want to listen to music (mp3, flac, etc) in mpc-hc can i use the hdmi to bistream audio to the receiver?
I ran the test tonight and as I suspected Flacs run through the HDMI connection on the radeon vid card with either MPC-HC, or Winamp. To play flac on WMP you must download a plugin. The same is true for W7MC. I tested the latter two with a plug-in and they too run through the HDMI connection.
Reply Home Theater Computers
