Utilizing receiver + speakers with desktop in basement. - AVS Forum | Home Theater Discussions And Reviews
Old 05-28-2010, 08:23 AM - Thread Starter
polarism's Avatar
Hi,
I'm wondering how I can use my onkyo tx sr-606 receiver that currently powers my gaming setup in the basement with my desktop that sits in the corner next to it.
My desktop uses an ASRock P45TS-R motherboard (this one: http://www.newegg.com/Product/Produc...82E16813157138), and I'm pretty sure it's just using onboard sound. I currently just use a USB headset.
My video card is an ATI Radeon 4850
What would I need to buy in order to do this? Do I need some kind of HDMI sound card?
polarism is offline
Old 05-28-2010, 08:42 AM
HDvids4all's Avatar
The only thing you'll need is the ATI DVI-HDMI adapter for your 4850. That card still supports audio over HDMI, and the adapter allows the conversion.
Or, you could also just use the built-in S/PDIF ports on the mobo and connect either one (COAX or optical) straight into the receiver. If you're just gaming and not using it as an HTPC, S/PDIF will work just fine (and probably less hassle).
HDvids4all is offline
Old 05-28-2010, 08:51 AM - Thread Starter
polarism's Avatar
polarism is offline
Old 05-28-2010, 08:55 AM - Thread Starter
polarism's Avatar
Oh and I went into my playback devices in Win7, and I do see "ATI DP Output", is that what this is?
It's currently saying "Not plugged in"
polarism is offline
Old 05-28-2010, 09:17 AM
HDvids4all's Avatar
Yep, that should do the trick. Install the latest CCC from ATI, and be sure to include the ATI HDMI audio device driver as well. Then you just configure your audio settings for that output.
Are you planning on running video and audio over HDMI to your receiver? Because if you're not using the video portion, the S/PDIF would be a better choice IMHO.
Old 05-28-2010, 09:20 AM - Thread Starter
polarism's Avatar
I'd like the option for both. It's not THAT important, but being able to show a movie on the 52'' LCD from my desktop might not be a bad thing from time to time.
polarism is offline
Old 05-28-2010, 09:22 AM
GreenEyez's Avatar
Yeah, because we all know S/PDIF is superior to HDMI (wallbash)
GreenEyez is offline
Old 05-28-2010, 09:39 AM
HDvids4all's Avatar
Cute.
If you read the original post, he's currently using his PC for gaming, not HD audio and HTPC use. If HD audio output isn't a consideration, S/PDIF is superior to HDMI. Why, you might ask? Because they offer the exact same audio capabilities in this situation, but there are no adapters necessary for S/PDIF. There are no handshake issues, and you only need to troubleshoot audio, not both audio and video if there are problems.
To the OP,
If you go with the HDMI solution, just be aware that you'll be effectively outputting to 2 monitors at that point, so a little extra configuration will be necessary for watching movies.
Old 05-28-2010, 10:11 AM - Thread Starter
polarism's Avatar
That's cool. I don't mind some things going wrong and having to troubleshoot. I'm just an audio idiot and figured i'd get some advice, mainly because my color vision sucks major b@lls and having to figure out the ports on the card/receiver can be a real pain for me.
I already output to two monitors at the moment, so I guess the 19'' can take a backseat when I want the TV involved.
polarism is offline
Old 05-28-2010, 10:33 AM - Thread Starter
polarism's Avatar
By the way, I really appreciate the advice guys!
polarism is offline
