HD Audio: to FLAC or not to FLAC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 06-04-2010, 09:43 PM - Thread Starter
aprikh1's Avatar
Using Another Eac3to GUI-Plus I am able to convert my Blu-Ray ISOs to MKVs. The option I select for audio is to extract HD-Audio and core tracks. My ATI 5XXX picks up those audio streams, performs the decoding, and everything is gravy.
My question is Does it make sense for me to convert the HD Audio to FLAC as I convert the ISOs to MKVs? I understand that the conversion will be lossless, but how do I verify that my HD Audio has indeed been converted into lossless FLAC? Also, is there an advantage to having the audio as FLAC in the MKV container vs. the regular HD-Audio streams?
Thanks in advance!
aprikh1 is offline
post #2 of 47 Old 06-04-2010, 10:04 PM
harmann's Avatar
As far as I know, there's no free decoder for DTS-MA yet, only Dolby TrueHD. So if you want to play DTS-MA on PC you have to convert to flac. That's what I do anyway.
harmann is offline
post #3 of 47 Old 06-05-2010, 08:31 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 108
What free decoder do you use to convert your DTSHDMA tracks? Last time I looked (a bit ago admittedly) there were no free codecs for ocnverting DTSHDMA losslessly.
-Suntan
Suntan is offline
post #4 of 47 Old 06-05-2010, 08:34 AM
Mike99TA's Avatar
This post confuses me a bit... wouldn't it be better to just leave the HD audio untouched and have it bitstreamed to your receiver to decode, which negates the need to convert anything and gives you 100% untouched HD audio? I extract the HD audio untouched in my MKV files and they play through mediaportal bitstreamed to my receiver and I get the blue DTS-MA/TrueHD light and everything.
Mike99TA is offline
post #5 of 47 Old 06-05-2010, 08:40 AM
GreenEyez's Avatar
I don`t understand too. What do you mean by "the 5xxx series card performs the decoding" ? The 5xxx series cards perform no decoding, they bitstream audio to your receiver which does the decoding.
What receiver do you have?
GreenEyez is offline
post #6 of 47 Old 06-05-2010, 08:53 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
ArcSoft Audio Decoder (from the trial version of TMT; a kind of free) decodes DTS-HD with full resolution. That's the method suggested in BLU - RAY/HD-DVD to mkv .....the options are endless!!!!
Converting to FLAC vs keeping the original HD audio format is just a matter of taste. Those who own a HD 5xxx/Clarkdale and a HDMI 1.3 receiver perhaps prefer the latter...
renethx is offline
post #7 of 47 Old 06-05-2010, 09:06 AM
davdev's Avatar
Question, with the 5xxx do you still need TMT or PDVD or can you bitstream natively out of Media Center.
I use FLAC simply because I refuse to use either TMT or PDVD, and it's the only way I can get lossless audio. Currently I just use the on board audio on my G45 MB (which I know won't bitstream)
davdev is offline
post #8 of 47 Old 06-05-2010, 09:08 AM
GreenEyez's Avatar
ffdshow is used for bitstreaming from mkv files, if that`s what you mean.
post #9 of 47 Old 06-05-2010, 09:21 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yup.
1. Ripping BD movies into MKV with the original video/audio format intact.
2. Playing MKV with HD 5xxx/Clarkdale, an appropriate video decoder (such as MPC Video Decoder) and ffdshow Audio Decoder (thus TrueHD/DTS-HD are bitstreamed to an AVR)
is a preferred method of many people in this forum. The player is immaterial; you can use any customizable DirectShow media player including the 7MC internal player. (But for various reasons, people often prefer MPC HomeCinema [can be launched as an external player from inside 7MC].)
renethx is offline
post #10 of 47 Old 06-05-2010, 10:45 AM - Thread Starter
aprikh1's Avatar
My apologies, I was not very clear. The ATI 5XXX does not do any decoding it just bitstreams the untouched HD Audio to my receiver, which does the decoding. The methodology I follow is precisely as Renethx stated.
I am just wondering if there is some kind of advantage for me to convert the HD Audio to FLAC. I plan to keep my Blu-Ray rips indefinitely, and would hate to re-rip movies down the line because something is not compatible with HD Audio. As an example, lets say I wanted to stream the movies to an iPad (don't have this yet) can I do it with MKVs with HD Audio? What about extenders, do they work with MKVs with HD Audio?
Yup.
aprikh1 is offline
post #11 of 47 Old 06-05-2010, 10:50 AM
GreenEyez's Avatar
The Ipad doesn`t support H.264 High Profile nor 1080p resolutions nor FLAC or DTS-HD MA or True HD. You have to re-encode the entire movie (both audio and video) to do that. Or buy a netbook with a ION GPU .
post #12 of 47 Old 06-05-2010, 11:02 AM
jrwalte's Avatar
I'm also curious about HD audio and extenders. Has anyone tried this to see if the transcoding extracts the core DD/DTS from the HD audio or does the transcoding software not recognize HD audio?
jrwalte is offline
post #13 of 47 Old 06-05-2010, 11:39 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Depends what you mean by Extender. My Popcorn Hour C200 happily bitstreams DTS HD and True HD over HDMI to my amp for it to decode - though this is from BD ISOs. AIUI they are producing new firmware from a new Sigma SDK to cope with HD audio in other situations (MKV etc.)
sneals2000 is online now
post #14 of 47 Old 06-05-2010, 11:42 AM
jrwalte's Avatar
I'm talking about transcoding to Xbox360
jrwalte is offline
post #15 of 47 Old 06-05-2010, 01:24 PM
Mac The Knife's Avatar
Liked: 24
Originally Posted by aprikh1 View Post
I am just wondering if there is some kind of advantage for me to convert the HD Audio to FLAC. ...
Basically just a little more compatibility at the expense of more work and more storage space.
So, for example, if you want to go over a buddies house and he doesn't have bitstreaming capabilities you at least have a chance of getting flac decoding working.
Or if you buy new hardware and end up not being able to get the bitstreaming working (like a bunch of people around here) then you're not screwed.
But in both those cases there's not a big incentive to transcode everything right now since you can always wait until you actually need it.
I have heard of some people who transcode everything to FLAC so that everything is the same so that they don't have to constantly tweek settings when switching from one format to the other (this can also improve the WAF since it means fewer variables that can trip up the casual user).
Mac The Knife is offline
post #16 of 47 Old 06-05-2010, 01:44 PM
GreenEyez's Avatar
Please enlighted us what settings i/we should be "tweaking" when switching from one one format to another....
post #17 of 47 Old 06-05-2010, 02:54 PM - Thread Starter
aprikh1's Avatar
Well, I spent this afternoon listening to Star Trek 2009 with FLAC and with HD Audio. Both of the rips were in MKV format played back by MPC HC. The HD Audio MKV seemed more lifelike and a tad bit louder. I know that FLAC is supposed to be lossless, so I am not sure why HD Audio sounded better. It could be just my perception.
When I look at my eac3to log I see this
eac3to v3.17
command line: "C:\\eac3to\\eac3to.exe" 1) -log="C:\\Program Files (x86)\\ACD\\Another EAC3to GUI\\log.txt"
M2TS, 1 video track, 4 audio tracks, 7 subtitle tracks, 2:06:50, 24p /1.001
1: Chapters, 15 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
(embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB)
4: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
6: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB
7: Subtitle (PGS), English
8: Subtitle (PGS), English
9: Subtitle (PGS), French
10: Subtitle (PGS), Spanish
11: Subtitle (PGS), Portuguese
12: Subtitle (PGS), French
13: Subtitle (PGS), Spanish
So which audio stream was encoded into FLAC? TrueHD or AC3? How do I know?
aprikh1 is offline
post #18 of 47 Old 06-05-2010, 02:58 PM
Bojangles139's Avatar
if its just future compatiable, with both makemkv and Another EACto GUI you can keep both tracks, DTS/DD and any hd audio.
but if you want future proof and keep hd audio always, flac would be the way to go. if you just want to make sure you can play the audio, rip both tracks.
Bojangles139 is offline
post #19 of 47 Old 06-05-2010, 08:59 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Have you tried WASAPI exclusive mode to play FLAC? Otherwise you won't get sounds faithful to the original. (Another advantage of bitstreaming.)
renethx is offline
post #20 of 47 Old 06-06-2010, 04:36 AM
Rigby Reardon's Avatar
In my view, there are three advantages to using FLAC:
- Hardware compatibility: No HD audio bitstreaming capable hardware required. This problem will go away over time, but right now it's limiting hardware choices somewhat.
- Software compatibility: Last I checked the available non-commercial solution (ffdshow) and also the drivers were still a bit immature and had issues like incorrect EDID readout etc. Might be better now though.
- Space: FLAC encodings are usually significantly smaller than DTS-HD MA due to better coding efficiency. On a 2hr feature film, it often saves a GB or more. This is not so much the case for TrueHD though.
But if you are sure that your software and hardware is compatible, keeping the original encodings should be fine too.
Rigby Reardon is offline
post #21 of 47 Old 06-06-2010, 04:55 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Since all the HTPCs in my house are bitstream capable I just stick with the original HD Audio track as I see no need for FLAC. Any media players that don't support HD Audio can at least downmix it to stereo (and some of those players don't support multi channel FLAC), so the original HD Audio tracks works best for me. Really nothing more then a matter of preference. Bitstreaming HD Audio (FFDShow + MPC HC) has been very stable for me on both the core i5 and ATI 5670 and seems to be getting better support amongst various front ends (I have bitstreaming working with XBMC and almost there with SageTV). And of course there are some of us that just like to see the HD Audio lights light up on the AVR
I can't recall off the top of my head, but is Reclock only for x32 systems?
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #22 of 47 Old 06-06-2010, 06:51 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Correct, the latest beta FW for the C200 allows for bitstreaming of HD audio from standalone mkv/m2ts:
http://www.mediasmartserver.net/2010...beta-firmware/
Cheers,
Damian
post #23 of 47 Old 06-06-2010, 01:52 PM
jrwalte's Avatar
On the topic of MPC-HC and FFDShow working with bitstreaming, does anyone have a link to a guide of setting this up and how to properly extract the HD audio into a MKV? I've been having a hard time finding it, as most searches result in threads with 100s of posts.
jrwalte is offline
post #24 of 47 Old 06-06-2010, 04:11 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Here is my guide on setting up MPC + FFDSHow:
http://www.mediasmartserver.net/2010...7-htpc-part-i/
Here are some of my guides on mkv creation:
http://www.mediasmartserver.net/tag/mkv/
Another EAC3To GUI is probably the easiest method or some version of EAC3To (like Clown_BD) + MKVMerge
Cheers,
Damian
post #25 of 47 Old 06-06-2010, 06:24 PM
jrwalte's Avatar
Thanks for those links - it's exactly what I was looking for.
jrwalte is offline
post #26 of 47 Old 06-07-2010, 07:08 PM - Thread Starter
aprikh1's Avatar
Thanks for all the feedback. I think I am just going to stick with MKVs with unaltered HD audio streams. It's simpler and I have peace of mind that my HD Audio is working when that magical HD logo lights up on my receiver.
aprikh1 is offline
post #27 of 47 Old 06-07-2010, 10:28 PM
curtisb's Avatar
Quoted: 29 Post(s)
Liked: 39
I would differ that this is a minor preference decision as the time it takes to rip a collection of any size isn't trivial and as noted, you really can't have things set up to go to receiver if you have a mix and want to bitstream some and covert others like FLAC.
Almost as relevant is even if you choose to do MKV vs. movie-only ISO or BR folders.
For my 100+ HD movies I've been ripping as FLAC as it was the instructions that originally was the only reasonable way to go and now it is primarily because most of my viewing is on PC where DTS MA isn't supported by solutions like TrueHD is.
I now also encode a second ac3 track for compatibility backup as it takes only 300mb extra space. I would be doing that even if if I was keeping just lossless.
If you just envision bitstreaming as your only main usage, then just I'd recommend continuing the path and skipping FLAC now. Saves time on ripping.
curtisb is offline
post #28 of 47 Old 06-07-2010, 11:15 PM
GreenEyez's Avatar
Wtf? Is that swahili ?
post #29 of 47 Old 06-08-2010, 11:40 AM
Pertwee454's Avatar
Sorry if this is rude or off topic, but I have a question.
Using the WASAPI mode in Reclock and MPC-HC gave me simultaneous audio playing from both the primary FLAC audio and the secondary AC3 audio, I uninstalled Reclock, and now can switch between the 2 audio streams.
Is there a setting in MPC-HC or Reclock to fix the problem? I would like to make the Flac bit-perfect. Thanks
Pertwee454 is offline
post #30 of 47 Old 06-08-2010, 12:20 PM
MikeEby's Avatar
A second audio track is next on my list of updates for AnotherEAC3toGUI. Then support for 1080i source material. I'll be using "Life" for all my testing of 1080i. Does anyone know of any good 1080i Concert disks? I want to do some testing with one of those too.
The whole demux/convert to FLAC and Remux to MKV's only takes between 1/2 hour to an hour anyway. Less time then copying the whole disk image to the hard drive. When testing both types of audio it seems to only takes a few minutes longer to do the FLAC conversion.
Mike
MikeEby is offline
Reply Home Theater Computers
