Do I need Haali splitter? - AVS Forum | Home Theater Discussions And Reviews
Old 06-17-2010, 10:34 AM - Thread Starter
Teac's Avatar
I am running MPC and send all audio to SPDIF where my receiver decodes it.
In the past I used Haali but now all works fine. Is Haali still important to use?
Teac
P.S.
should one use Haali renderer?
Teac is offline
Old 06-17-2010, 10:45 AM
mike_311's Avatar
Teac
P.S.
haali is just a media splitter, it allows windows to open the .mkv container. but i,m not sure is a program like MPC has a built in splitter, if you can open mkvs then you dont need it...or you already have it.
"If the world didn't suck, we'd all fly off."
mike_311 is offline
Old 06-17-2010, 10:59 AM
mslide's Avatar
MPC-HC has its own mkv splitter so in that sense you don't need Haali. The only time I've found myself needing haali is when using eac3to to rip a blu-ray (when you specify the video track output file as an mkv file). So, I have it installed on my htpc.
mslide is offline
Old 06-17-2010, 11:13 AM - Thread Starter
Teac's Avatar
thanks guys! Thats what I thought..
I am trying to install as little as possible to keep the machine running bette
Teac is offline
