older AMD 5050e laying around - worth it for HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-26-2010, 09:34 PM - Thread Starter
DireWolf08's Avatar
Quoted: 14 Post(s)
So, I've got this old, unused AMD 5050e sitting in my closet collecting dust, and I am thinking of using it as the CPU in a new HTPC build (based on Win7MC). It's AM2, so that severely limits me in terms of motherboards, but is there a consensus best AM2 motherboard out there? I am looking at this one:
http://www.newegg.com/Product/Produc...-394-_-Product
Any thoughts? The cool thing is I could throw a system together for real cheap, and I know it could handle all the video I threw at it, but would I be bummed I didn't spring for something a bit more powerful or speedier?
DireWolf08 is offline
post #2 of 11 Old 06-26-2010, 09:38 PM
GreenEyez's Avatar
HD audio or no HD audio?
GreenEyez is offline
post #3 of 11 Old 06-27-2010, 06:46 AM
Eopian's Avatar
My main htpc is running an AMD X2 5000 AM2 (the same thing as the 5050e, but your is the energy efficient model). With a 5670 it plays everything I throw at it including blu-ray. That is with win7 32bit by the way. Plus, correct me if I'm wrong, but you can put an am2 processor in any am3 motherboard with no problems.
Eopian is offline
post #4 of 11 Old 06-27-2010, 06:49 AM
tman247's Avatar
Quoted: 57 Post(s)
Liked: 51
The 5050e should make a great HTPC CPU (it's not that old either). Dual core, 45W is a very good start. Mobo seems fine as well. The integrated HD4200 graphics should be fine for everything inc 1080P.
Stick a couple of gig of ram in there, and you should be good to go.
tman247 is offline
post #5 of 11 Old 06-27-2010, 08:12 AM
hirent's Avatar
I use a 4850e for my HTPC; works just fine.
Get any older AMD board, a 5000 card and you will be fine with the 5050e.
hirent is offline
post #6 of 11 Old 06-27-2010, 09:42 AM
Servicetech571's Avatar
4850e works fine for the most part but you will need a card for graphics. The 4850e doesn't do well with IGP.
Servicetech571 is offline
post #7 of 11 Old 06-27-2010, 10:37 AM
tiredder's Avatar
that's what I found as well, especially with my ECS mobo.
using a GT220 now
Timm
tiredder is offline
post #8 of 11 Old 06-27-2010, 03:13 PM - Thread Starter
DireWolf08's Avatar
Quoted: 14 Post(s)
Thanks for all the great advice! Agreed the 5050e is not terribly old, but bleeding edge, it is not!
To answer the HD audio question: No, I won't need HD audio capability . . . at least not at first, my receiver is an older HK that doesn't handle 7ch HDMI. In the event that I wanted to upgrade to full HD audio, a 5000 series Radeon card would enable that, right?
post #9 of 11 Old 06-27-2010, 04:12 PM
GreenEyez's Avatar
Yup, a cheap HD5450 will get you HD audio. For the moment, the 785G is fine for bitstreaming DTS/DD and decoding H.264 / VC-1 video.
post #10 of 11 Old 06-27-2010, 06:31 PM
hirent's Avatar
hmm....don't know about that.
Mine is plugged into a M3A78-EM w/ a 780G chipset. It works just fine with the integrated HD3200. Never had a problem with the IGP.
I use a 5750 now for HD audio with the same board.
hirent is offline
post #11 of 11 Old 06-27-2010, 08:41 PM
Might be an Nvidia thing, Couldn't get my 8200 or 8300 boards to work w/o stuttering with the 4850e. Works fine with a 7750.
Reply Home Theater Computers
