HTPC using SPDIF (w/ AC3filter ) to Av reciever are these settings correct ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-01-2010, 05:30 AM - Thread Starter
africanmarty's Avatar
hi guys i am setting up a htpc for my girlfriend i will be using mpc-hc for video file playback and TotalMedia Theatre 3 Platinum for DVD/bluray playback. I have setup to use SPDIF ( it is built into the mobo ) and it works great with TotalMedia Theatre 3 Platinum (DTS and dolby digital - show up when playing back DVD/ blurays on the AV recioever). when using mpc-hc for playback of video files i want all the prcocessing done on the Av reciever. I was after DD/DTS to be passed through to be decoded to the reciever (wich is working as DTS and Doldby Digital show up) and everything else to be passed through as PCM and then for the AV to use Pro Logic II to turn it into surround sound. I am using the following settings in AC3filter ) shown in the images. The reason i ask is beucase i have no speakers yet. I think it is right but thought i would check with others user who might be trying to get the same result.
africanmarty is offline
post #2 of 10 Old 07-04-2010, 12:51 AM - Thread Starter
Bump any thoughts ??
post #3 of 10 Old 07-04-2010, 03:45 AM
Wo0zy's Avatar
If you want PCM to be passed so the AVR can do Pro Logic, you don't want " Use AC3 Encoder" checked.
Wo0zy
Wo0zy is offline
post #4 of 10 Old 07-04-2010, 06:47 AM - Thread Starter
thanks for the tip. i thought that if i didn't click that then the computer might send mp3,aac or some other codec that wouldn't be understood from the receiver ? is that not the case.
post #5 of 10 Old 07-04-2010, 09:02 AM
Eddie2u's Avatar
Everything looks ok. If you see DTS on your receiver than its bit streaming.
You could test it out by playing a dts file with mpc-hc and clicking on the ac3filter icon file when it appears. If I remember right you should see some info of what is being bit streamed and stream info. AC3filter will only start up when a DTS or DD track is detected all other sound like stereo PCM will be unaffected. Did you try headphones to test for sound for PCM or DTS?
Eddie2u is offline
post #6 of 10 Old 07-04-2010, 12:41 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
I've opted for AC3Filter's little brother SPDIFer to just do passthrough of DD & DTS. Fewer settings with the same result!
Andrew Hornfeck is offline
post #7 of 10 Old 07-04-2010, 06:16 PM
athe's Avatar
What OS are you using? Why not just setup the audio rendered in MPC-HC to be one that is SPDIF, and modify the AC3/DTS filter settings to output to SPDIF. No need for AC3Filter (or SPDIFer). Non-AC3/DTS audio should be downmixed to stereo and output as PCM.
I currently do this in Win7, and it works fine.
Of course, this assumes that your audio drivers install a Digital Output device into things.
Cheers,
athe.
athe is offline
post #8 of 10 Old 07-04-2010, 06:52 PM - Thread Starter
Cheers,
athe.
and how are you doing this ? do you have a tutorial ??
post #9 of 10 Old 07-04-2010, 06:56 PM - Thread Starter
it does say 'dts' and 'dolby digital' when using spdif in both mpc-ha and arcsoft total media theater. i will try to untick the 'use ac3 encoder' and see if it work. but i will have to wait till tomorrow as i broke my ATI 4670 AGP and i have to get another...
post #10 of 10 Old 07-04-2010, 07:24 PM
athe's Avatar
In MPC-HC
- Go into options
- Select Playback -> Output
- For the audio renderer, select the digital device you are connecting to your AVR (it'll probably mention SPDIF or digital in the name). Another option is to go into Windows Audio Devices and set the Digital output device as the default, and set MPC-HC's audio rendered as System Default
- Select Internal Filters
- Double-click on AC3 or DTS (both use same settings dialog)
- Select SPDIF for both AC3 and DTS, and click OK
That's it for MPC-HC.
In Arcsoft, you should be able to select the digital output device as the audio renderer.
Cheers,
athe.
athe is offline
Reply Home Theater Computers
