Nvidia GeForce GTX 460(GF104 GPU) supports full audio bitstreaming - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 1812 Old 09-14-2010, 11:24 AM
jakmal's Avatar
Originally Posted by steveo08 View Post
anyone tested bitstreaming dts-hd in mkv?
Yes, works fine with ffdshow + MPC-HC
Ganesh T S
Sr. Editor, AnandTech Inc.
jakmal is offline
post #392 of 1812 Old 09-14-2010, 03:21 PM
rickcfer's Avatar
Quoted: 51 Post(s)
Liked: 24
Originally Posted by CyberlinkUSA View Post
Actually, the final PowerDVD update will be a higher build number... it should be available tomorrow.
Tom
Cyberlink
Which "tomorrow" were you refering to?
rickcfer is offline
post #393 of 1812 Old 09-14-2010, 04:04 PM
steveo08's Avatar
great! Thx!
steveo08 is offline
post #394 of 1812 Old 09-14-2010, 10:19 PM
CyberlinkUSA's Avatar
Sorry for the head fake. The update is available now.
http://www.cyberlink.com/downloads/s...hes_en_US.html
Tom
CyberlinkUSA is offline
post #395 of 1812 Old 09-14-2010, 10:37 PM
tourettes's Avatar
Originally Posted by Andy o View Post
Hmm installing the laptop version of 260.63 here, and it comes with a newer HDMI audio driver than the one Anandtech had. This new one is 1.1.9.0.
There is a huge difference between 1.1.7.0 and 1.1.9.0 HDMI driver revisions. The 1.1.9.0 supports WASAPI exclusive + event driven mode.
Finally I can be almost happy with the http://forum.team-mediaportal.com/ge...quality-84441/ on Nvidia GPU
Unfortunately there still seems to be "silent stream" & "random noise" issues present. Those are happening randomly (in other applications as well). Both are quite annoying issues and happen at least with GT220.
tourettes is offline
post #396 of 1812 Old 09-14-2010, 11:34 PM
Andy o's Avatar
I'm not getting any "random noise", can you elaborate? Also, you might wanna report the silent stream to nvidia. I did and surprisingly after some days someone apologized for the delay and assured me it was being looked into. Nothing to lose, everything to gain.
Andy o is offline
post #397 of 1812 Old 09-15-2010, 01:48 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Update to this post:
Associate recently reported that prior to the end of year NVIDIA will release video card GeForce GT 440, which, in spite of relationship with GeForce GT 430, will be based on GF106 chip as GeForce GTS 450. In this case the quantity of stream processors will decrease from 192 to 144 pieces. It was assumed that the 128- bit bus and support to GDDR5 memory will be preserved.
Associates report that to the GeForce GT 440 are now assigned 128- bit bus and support to GDDR3 memory. This card will presented to the end of October for $99.
renethx is offline
post #398 of 1812 Old 09-15-2010, 05:44 AM
SamuriHL's Avatar
Alright guys. I'm jumping in head first. I just ordered an ASUS GTS 450. Slightly overclocked with their very nice cooler on it. I'm HOPING it comes this week but I suspect it'll most likely come on Monday. I guess I better find my copy of Driver Cleaner and get it ready for that machine. Sorry, AMD, but, quite frankly the latest driver fiasco is not making me happy.
SamuriHL is offline
post #399 of 1812 Old 09-15-2010, 06:00 AM
Andy o's Avatar
Nvidia is including a "clean" option in their new drivers though. I didn't use driver cleaner.
Andy o is offline
post #400 of 1812 Old 09-15-2010, 06:19 AM
SamuriHL's Avatar
That doesn't help me remove the existing AMD crap, though. Remember I'm replacing the 4850 blast furnace with this card. I'm sure some people will be surprised to see me go with nVidia, but, that just means they haven't known me long enough. I had an 8800 that's still in my son's machine. One of the best cards I ever owned, but, they blew it on HTPC stuff until this generation. So, nVidia, I'm back, but, let's not screw it up again, yea?
SamuriHL is offline
post #401 of 1812 Old 09-15-2010, 07:09 AM
Andy o's Avatar
ah yes. Don't know how you're playing, but I'm getting audio glitches (James confirmed too) with the Nvidia+TMT3+ReClock+24p combination.
Andy o is offline
post #402 of 1812 Old 09-15-2010, 07:12 AM
SamuriHL's Avatar
Oh sure, NOW you tell me. WHACK! I guess if I run into that I'll have to lean on some people to get that fixed. Cause yes, I will need ReClock + TMT3 (when it's patched) and the 450.
SamuriHL is offline
post #403 of 1812 Old 09-15-2010, 10:08 AM
Andy o's Avatar
I don't know if it will happen when bitstreaming though. See here.
Andy o is offline
post #404 of 1812 Old 09-15-2010, 10:46 AM
SamuriHL's Avatar
Not everything I do is bitstreamed, though. For example, HD DVD's are decoded to PCM. Any PCM movies will likely exhibit this behavior. As long as it's repro'able we can maybe get ArcSoft to look at it.
SamuriHL is offline
post #405 of 1812 Old 09-15-2010, 12:08 PM
mcantu1's Avatar
something to keep in mind with the new drivers (from tweakguides):
Update: You must now keep the Nvidia Driver Helper Service set to Automatic, or preferably Manual, otherwise the Nvidia Control Panel may not open.
mcantu1 is offline
post #406 of 1812 Old 09-15-2010, 05:35 PM
ricabullah's Avatar
OK guys, these trials have been made on a fresh install of seven 32.
Win updates+dxwebsetup only.
Players pdvd10 the latest patch and WinDVD10 the latest.
clarkdale i3+ H55
460
Here are the results:
PDVD10:
Never wants to run with AnyDVD.
DTSHD-HR:
Works without AnyDVD and i get blu light on my AVR. (doesn't work with AnyVD at all.)
(test BDs:
Predator 2, Hitman)
DTSHD-MA:
Never works with/without AnyDVD: no sound no blu light.
(with AnyDVD you wouldn't hear anything even from the intro clip.)
(test BDs:
Alchemy Live Dire Straits, Clash of the Titans)
THD:
Same results with DTSHD MA:
No sound no blu light.
(test BD: Spiderman3)
Guys i'm tired of making tests really.
But i have to say WinDVD10 works great with both nVidia and Ati.
THAt's all.
Cyberlink guys making joke with us i think.
Chronical Tester
ricabullah is offline
post #407 of 1812 Old 09-15-2010, 05:39 PM
SamuriHL's Avatar
You aren't the only one reporting that PDVD10 isn't bitstreaming with the nVidia cards. This has me worried. I bought the 450 this morning and it should be here in a couple days. So, this is not the time to be telling me that bitstreaming in PDVD10 isn't working considering TMT hasn't been updated yet. Cyberlink needs to address this. Immediately.
SamuriHL is offline
post #408 of 1812 Old 09-15-2010, 05:43 PM
ricabullah's Avatar
I consider myself as an objective tester; i hope
And here is what i said:
Even i paid for it twice
Chronical Tester
post #409 of 1812 Old 09-15-2010, 05:45 PM
SamuriHL's Avatar
Rica, I hope you realize that a LOT of us have come to trust and appreciate fully your analysis of a great many things, so, I definitely trust your tests. I only have one license for WinDVD, so, it does me no good on the machine with the 450, unfortunately. I will have MPC-HC + ffdshow, obviously, but, I need to have a commercial player bitstreaming, as well. Here's hoping ArcSoft not only gets it out quickly, but, correctly.
SamuriHL is offline
post #410 of 1812 Old 09-15-2010, 05:59 PM
ricabullah's Avatar
Samuri, thanks a lot for your compliment but i wouldn't mean it.
But if you have a license of WinDVD you can use it on just two HDDs.
Why not ask them to extend your activation?
I suppose they will do this by pleasure
PS i think they should donate us
Chronical Tester
post #411 of 1812 Old 09-15-2010, 06:05 PM
SamuriHL's Avatar
Wait we get two? Oh, I thought it was only one. I guess I could use it on there then. Will have to find my installer for it and see if it works. Thanks for the info!
SamuriHL is offline
post #412 of 1812 Old 09-15-2010, 06:16 PM
ricabullah's Avatar
If you gonna make a clean install to another disk yes.
If you want to use the same disk which WinDVD already installed, there is a cleaning procedure.
Chronical Tester
post #413 of 1812 Old 09-15-2010, 06:17 PM
Andy o's Avatar
I find it more worrying that it doesn't wanna run with AnyDVD on.
Andy o is offline
post #414 of 1812 Old 09-15-2010, 06:21 PM
SamuriHL's Avatar
WinDVD installed on the second machine no problem. So that's sweet. I've got the nVidia driver download sitting on that machine's download dir and waiting for the card to get here.
SamuriHL is offline
post #415 of 1812 Old 09-15-2010, 06:28 PM
ricabullah's Avatar
Agreed. That's really boring.
Think about i have a disk from region x and i wouldn't remove the region code at least and i would have to rip my original diks to watch with a fake BD player later for the sake of a commercial player.
Chronical Tester
post #416 of 1812 Old 09-15-2010, 06:32 PM
ricabullah's Avatar
Perfect.
What is missing here is downsampled PCM streaming and why we don't use MPC-HC/FFDSHOW together with Haali for them.
So my final choice will probably be:
WinDVD for bitstreaming,
MPC-HC/ffdshow/haali/ReClock-bitperfect mode- for PCM streaming (24/16 automaically selected via direcly linked filters: haali > reclock)
If you don't like MPC' s internal video filter, use ArcSoft video filter
Chronical Tester
post #417 of 1812 Old 09-15-2010, 06:37 PM
SamuriHL's Avatar
Perfect.
So my final choice must probably be:
MPC-HC/ffdshow/haali for PCM streaming
Yup. I would agree with that. Can't wait for TMT to get updated.
SamuriHL is offline
post #418 of 1812 Old 09-15-2010, 06:50 PM
ricabullah's Avatar
BTW samuri the latest version is 10.0.5.536.113375.
If not, check out for the updates.
Chronical Tester
post #419 of 1812 Old 09-15-2010, 07:09 PM
SamuriHL's Avatar
The last update I have is from April, so, I'm guessing I'll need to run the update. Not a big deal.
SamuriHL is offline
post #420 of 1812 Old 09-16-2010, 03:43 PM
ricabullah's Avatar
Perfect.
As for PCM:
I forgot haali doesn't support 96.
So you have two options:
Opening just from the file: (i don't like it because it doesn't recognize mpls)
Select Arcsoft 2.125 filters under external filters (arcsoft demux, arcsoft audio decoder hd, arcsoft video)
This time you have to select 5.1 every time.
Or
Select MPC's internal gabest filters and ffdshow.
This time you have the chance open DVD or from the file but you have to select the bithdepth manually.
I think the second choice is more handy and more functional.
I hope somebody will write codes to run it automatically some day.
_ __ _ _
Chronical Tester
Reply Home Theater Computers
