Nvidia GeForce GTX 460(GF104 GPU) supports full audio bitstreaming - Page 53 - AVS Forum | Home Theater Discussions And Reviews
Old 05-18-2011, 02:52 PM
adrift's Avatar
Get ready for a really stupid question (I admit I didn't search the whole thread for the answer).
If I connect a mini-HDMI to HDMI cable from a GTX 460 to my Onkyo HT-S5400 I should be able to play PC games like BFBC2 in full 5.1 surround sound, correct?
I'm asking this dumb question because I recently got my first surround setup in years, and after years of casually playing PC games, and even working in IT, it was a complete revelation to me that PC games don't produce surround sound with basic optical out. It was driving me nuts that I could watch blu-rays from my htpc in full surround sound, but playing a game of BCBF2 dropped audio to stereo. I started googling the issue today, and found that this has been common knowledge for some time. I asked my IT co-workers and they were as clueless as I was about the subject so that made me feel a little better.
As a side question to my main dumb question... how does a video card extract and output audio from the motherboard to begin with? I don't understand how that works. Oh, and just in case its important in answering question number 1, this is my current motherboard: GIGABYTE GA-MA785GM-US2H
Thanks for any answers/advice anyone can offer.
adrift is offline
Old 05-18-2011, 03:12 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Yes, with HDMI you can get full 5.1 sound. (even 7.1 if you want)
The GTX 460 has its own sound card in board. Once you connect a HDMI device that accepts sound, it'll show up in your audio configuration.
Some motherboards also come with a Dolby encoder that allows you to pass 5.1 through the optical link, but not all. Its mostly a licensing issue, really. If yours does, you can choose a "Dolby Digital 5.1" output format in your audio device configuration.
Nevcairiel is offline
Old 05-18-2011, 03:40 PM
adrift's Avatar
Terrific! Thank you.
Yeah, I don't see anything with the 5.1 designator in the output properties or anything, just plain DTS and DD (which, again, seems to work fine with everything except games).
adrift is offline
Old 05-18-2011, 10:05 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You should have bought GA-MA785G(P)MT-UD2H, that supports Dolby Home Theater (including Dolby Digital Live).
renethx is offline
Old 05-19-2011, 02:35 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by renethx View Post
Tong Chia,
Have you tried LAV CUVID + ffdshow Raw (for SVP) + madVR? I have a color space conversion issue.
Selecting ffdshow raw > Codecs > Raw video: YV12 fixed the issue. Both video in and out are YV12 in ffdshow raw filter. This combination works for every HD/SD video formats (AVC, VC-1, MPEG-2) beautifully.
Edit
This was already answered in FAQ:
I see wrong colors, for example the skin is blue like in Avatar movie.
The simpliest solution is to turn on "Postprocessing" in ffdShow.
This is another solution.
renethx is offline
Old 05-19-2011, 06:11 AM
adrift's Avatar
Oh wow. Yeah. Well I bought the board a year ago, and it was before I knew I was going to use the pc for an htpc, I just needed a new board, and it had decent reviews and price at the time. At least now I have a somewhat reasonable excuse to upgrade my ancient (2 and a half year old) current video card.
adrift is offline
Old 05-19-2011, 06:51 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
All these SVP color issues are weird. It sounds like its interpreting NV12 data as YV12, or vice versa. I don't know if its a ffdshow issue, but it certainly doesn't seem to be a issue with my decoder.
Possibly only with AVISynth in ffdshow. You give it NV12 data, and it tells the script its actually YV12? That would surely explain totally wrong colors.
The future version will allow you to force a specific pixel format, so if only YV12 works, then you can just force YV12 in LAV CUVID.
Of course that adds a small overhead converting the NV12 to YV12, but i wrote some assembler optimized code for that, so it should be pretty fast.
Old 05-20-2011, 01:42 AM
Tong Chia's Avatar
That worked well, the colors are back to normal. Thank you for that.
LAVCUVID has surprising low CPU utilization, most of the work is now
pushed to the GPU. I am getting better than 60% peak utilization
on the GPUs (i7 + GTX460pair) from less than 40% with CoreAVC
This in turn, allows for more aggressive motion vector search and prediction
Tong Chia is offline
Old 05-21-2011, 10:22 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Since there is no software solution similar to what i can do with my NVIDIA for ATI (at least that i know of), which i outlined above as well, i think this is a clear factor to help the selection process.
Its not pretending, no other solution to my specific requirements exist.
Hardware decoding, hardware deinterlacing, madVR. Show me the ATI solution to this.
Actually there is. I've just discovered the Korean software player PotPlayer and can get DXVA + MadVR with my ATI 5750. This is an evolution of KMPlayer and by the same author AFAIK, incredibly customizable in every conceivable way that I can imagine. Highly recomended!
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 05-21-2011, 10:25 AM
SamuriHL's Avatar
I don't need another player. I would love it if that code were in a stand alone decoder, but, that doesn't seem likely does it?
SamuriHL is offline
Old 05-21-2011, 10:28 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Well, it's good to know that there is a DXVA + madVR solution for ATI cards, and I want one!
Tulli is offline
Old 05-21-2011, 10:29 AM
Andy o's Avatar
I tried PotPlayer just because of that feature, and it was a massive fail for me, but since Tulli is using a 5750 (me a 5770) I guess there's something in my system. Man I can't wait to upgrade to Ivy Bridge and a Radeon HD 7000.
Andy o is offline
Old 05-21-2011, 12:38 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Actually hardware deinterlacing (i.e. AMD's VA) never works. Ranpha didn't say so:
Then go to 'Deinterlacing' filter section and configure it exactly like what the picture below suggests. This filter is optional if you use LAV CUVID Decoder as your video decoder (the only decoder that can do decoder-level deinterlacing).
and I couldn't get it work either for Cheese Slices. Hardware decoding is not important for today's processor, but software can't do deinterlacing properly.
Or am I missing something?
renethx is offline
Old 05-21-2011, 01:24 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
The player itself actually kinda sucks. Customizability isn't always good, heck in most cases it ends up in bloating and options overload - like in that one. I find the player unintuitive and really unnatural to use/configure.
Plus, i really wouldn't want to switch player..
Anyhow, i actually know how that DXVA mode works, and i nearly wrote a codec to do that, but instead i decided to write my CUVID filter instead, because it seemed so much easier (and was!).
All non-DirectShow players use that mode for DXVA, like VLC and XBMC and whatnot. It'll only work on Vista/7, and is still severly limited.
Anyhow, like others pointed out, that one does not use hardware deinterlacing, which is a crucial feature for me - decoding can be done in any CPU of todays generation.
Old 05-21-2011, 05:59 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
No, you're missing nothing Rene. After more checking found that the player is in fact only doing (ffmpeg) software deinterlacing. So the solution of Nevcairiel for Nvidia is the only true/complete hardware accelerated one that works with madVR.
Sorry guys for getting OT somehow but maybe this will add to the clarification of the very interesting situation we have now, where Nvidia, thanks to Neivcairiel's masterful work, is enjoying a clear, neat advantage over AMD for a graphic card recommendation.
Tulli is offline
Old 05-23-2011, 03:10 AM
Faceless Rebel's Avatar
Quoted: 80 Post(s)
Liked: 39
I think Nvidia's clear, neat advantage over ATI has always been their drivers. With my GTS 450, I was able to correct my issue of the card refusing to output Full Range simply by creating a custom resolution of 1920x1080 to output to my TV, the card accepted this without complaint. I was then able to also create a custom resolution of 1920x1080 with 23.976hz refresh, again the card accepted this without complaint and with MPC-HC using EVR Sync, I am able to get true 24fps playback of content. It's just so much easier when Nvidia gives you all these options in their drivers to create your own custom profiles for things when default ones don't work. My main gaming PC is the same way, I'm able to create custom AA and SLI profiles for games which don't have a default profile (the vast, vast majority already do), something that ATI owners have been complaining about for something like 5 years now with absolutely no plans for resolution.
Faceless Rebel is offline
Old 05-24-2011, 01:35 AM
jakmal's Avatar
Has anyone using a NVIDIA card (4xx or 5xx series) successfully got an interlaced VC-1 clip to play back with EVR renderer? I am specifically looking for a setup where the decoder uses DXVA2.
If you have any graph fitting this criteria, please let me know! Thanks!
Ganesh T S
Sr. Editor, AnandTech Inc.
jakmal is offline
Old 05-24-2011, 02:19 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
ArcSoft Video Decoder or CyberLink Video Decoder as mentioned in another thread.
renethx is offline
Old 05-24-2011, 11:12 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
LAV CUVID can do it, its not "strictly" DXVA2 in the traditional sense, but you know, same thing.
I wonder how much work it would be to add interlaced support to the open source VC-1 DXVA decoders, would mostly just be header parsing.. i should pick up my video decoder again.
Old 05-24-2011, 11:31 AM
SamuriHL's Avatar
Yes, for the love of God, yes, you should!
SamuriHL is offline
Old 05-24-2011, 11:39 AM
madshi's Avatar
Quoted: 501 Post(s)
Liked: 475
If only a day had 48 hours...
madshi is offline
Old 05-24-2011, 11:42 AM
SamuriHL's Avatar
Yea, I know how that goes. Work is currently killing me for that very reason.
SamuriHL is offline
Old 05-26-2011, 11:42 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Did anybody try to play Basketball clip (1080p60) with LAV CUVID Decoder + madVR? I see lots of dropped frames even with GTS 450.
renethx is offline
Old 05-27-2011, 12:08 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I did run it before, but i'll do it again when i get home to double-check.
What OS? XP might have some performance deficits that Vista/7 don't have due to the new driver model.
Old 05-27-2011, 12:21 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
Old 05-29-2011, 03:24 PM
adrift's Avatar
Okay folks, I went ahead and got an MSI GTX 460, and finally have 5.1 in games (woohoo!), I'm just curious about something. As I mentioned in a previous post, audio is going out to an Onkyo receiver. While playing any audio content, whether it be blu-rays, mp3s, streaming media, my receiver only ever shows MCH PCM 5.1. I never see it display anything like Dolby TrueHD or anything. Is this to be expected or do I have something not quite configured right?
adrift is offline
Old 05-29-2011, 03:35 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
What are you using for playback, wmc, xmbc,etc...?
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 05-29-2011, 04:51 PM
adrift's Avatar
I don't really use a media center (though I have and occasionally run both Windows Media Center and Boxee). I'm playing blu-rays with PowerDVD 10, and other video content with VLC. Nothing fancy. I stream Netflix and Hulu from my browser, and play audio content with foobar2k. No matter what player I'm running media through the only thing that displays is MCH PCM 5.1. I mean, it sounds okay. Surrounds seem to work fine. I do currently have the system running with PLIIz front highs, but I wouldn't think that would matter. I don't know. I asked the same question in one of the Onkyo threads, but based on the lack of feedback, I figured maybe it was something to do with Windows and the GTX 460.
adrift is offline
Old 05-29-2011, 05:17 PM
SamuriHL's Avatar
In PDVD10 you need to change the audio setting *WHILE PLAYING A BLU-RAY*. Then, and ONLY THEN, will you get bitstreamed sound. And if you play a non-Blu-ray, you will need to go back in and change it again when you play the next Blu-ray.
SamuriHL is offline
Old 05-29-2011, 05:34 PM
adrift's Avatar
Hmm. Not sure I quite follow... If I take a BD disk like 5th Element it has 2 English 5.1 tracks, PCM 5.1 (Uncompressed), and 5.1 Dolby TrueHD. If I swap between the two tracks while the movie is playing, the display on my receiver still reads MCH PCM 5.1 no matter which track I choose.
adrift is offline
