Nvidia GeForce GTX 460(GF104 GPU) supports full audio bitstreaming - Page 58 - AVS Forum | Home Theater Discussions And Reviews
Old 07-14-2011, 03:34 PM
erik71's Avatar
Several of the newegg reviews report that their GTS 450 worked fine for weeks or months, then for no apparent reason developed problems (BSOD, freezes, recovered messages, etc.). I was going to buy one until I saw so many reviews like that.
erik71 is offline
Old 07-14-2011, 05:26 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Yeah, the reviews scared me as well but I decided to throw caution to the wind. Hoping the issue is just as Andy o suggested
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 07-14-2011, 05:45 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
I have the single-slot MSI GTS 450 and it's been a great card so far. No problems to report and I'm using the latest Nvidia released drivers.
LexInVA is offline
Old 07-14-2011, 08:13 PM
Andy o's Avatar
Originally Posted by dbone1026 View Post
Hmmmm....sounds like that could be the issue. Definitely had issues when viewing firefox 5. What is odd is that it just started yesterday (pc has been up and running and no issues with ff for a week). When my replacement card comes in I will look at that. Do you disable hw accel in the firefox settings?
Yes. You have to uncheck it in Advance options. It seems to happen when I'm scrolling (not always of course, but when it happens, I'm scrolling).
Andy o is offline
Old 07-15-2011, 05:07 PM
JDz
JDz's Avatar
I hope so too, that is the exact card I just bought and put in my htpc.
JDz is offline
Old 07-29-2011, 01:21 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
New Beta Drivers are out, 280.19, on NVIDIAs page.
XP:
http://www.nvidia.com/object/winxp-2...ta-driver.html
XP64:
http://www.nvidia.com/object/winxp64...ta-driver.html
Vista/7 32-bit:
http://www.nvidia.com/object/win7-wi...ta-driver.html
Vista/7 64-bit:
Feedback so far seems very good.
The driver claims to add support for a GT530 (not the OEM version) and a GT520MX (apparently mobile?), anyone has any spec details on those?
Nevcairiel is offline
Old 07-30-2011, 02:06 AM
balky's Avatar
Quoted: 227 Post(s)
Liked: 131
XP:
XP64:
Vista/7 32-bit:
Vista/7 64-bit:
Running very good so far on my GTX 460 with madVR v.61 since installing yesterday...
balky is offline
Old 08-09-2011, 08:35 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
It looks like if I created a custom resolution, this will be always the "current" resolution even if the actual resolution is different.
Well, that's not a big issue. To edit it, create a new custom resolution "24Hz" that will override the old one. The original "24Hz" = 24.000 Hz will be lost even if you specify "23Hz" as usual.
renethx is offline
Old 08-09-2011, 08:50 AM
MickBim's Avatar
Which fault is it ? nVidia or MS ? Who rounds up 23.976 to 24Hz ?
It's incredible that everybody praises HTPC and that no GC can't output 23.976fps natively
MickBim is offline
Old 08-09-2011, 09:06 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Well, creating a custom resolution that is almost exactly 23.976Hz is pretty easy (at least in my configuration).
BTW at "23.97601Hz", "1 frame drop every 9.93 hours" is not correct: 23.976 - 23.97601 = 0.00001 s^(-1), 1/0.00001 = 100000 s = 27.7 h; so 1 frame repeats every 27.7 hours.
renethx is offline
Old 08-09-2011, 09:11 AM
MickBim's Avatar
Yeah I created the 23.976 custom res too but I lost the 24Hz correct one in the process.
I tried to create a correct 24Hz one over the native 25Hz (since in the custom res creator screen the refresh rate has to be between 23 and 25Hz) but I can't. It seems that the drivers only support one custom res
GG nVidia
MickBim is offline
Old 08-09-2011, 09:17 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I use that version just fine with 3 custom resolutions, 24, 50 and 60Hz.
Old 08-09-2011, 09:28 AM
MickBim's Avatar
On these latest version drivers you can create multiple custom res now ?
But maybe the bug appeared on my side because the refresh rates were too close (23.976, 24 & 25)
MickBim is offline
Old 08-09-2011, 10:04 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Custom resolution "23Hz" with refresh rate > 23.5000 Hz is considered as "24Hz" by the tool and "24Hz" is overridden. So you can never create both of "23Hz" = 23.976Hz and "24Hz" = 24.000Hz.
23Hz: 22.500Hz--23.5000Hz
24Hz: 23.500Hz--24.5000Hz
25Hz: 24.500Hz--25.5000Hz
Right now there are 232 24.000 fps BDs out of 4296 BDs according to NEW Unofficial Blu-ray Audio and Video Specifications Thread (I don't own any of them BTW). This is definitely a bug that should be fixed quickly.
renethx is offline
Old 08-09-2011, 10:10 AM
madshi's Avatar
Quoted: 499 Post(s)
Liked: 471
madVR tries to take the audio clock deviation (deviation between audio hardware clock and system clock) into account, too. The refresh rate is calculated by using the system clock. The audio hardware clock can differ from the system clock and the audio hardware clock is (usually) the master clock of the DirectShow graph. Unfortunately measuring the exact audio clock deviation is very hard to do right, because the audio clock jitters like hell...
madshi is offline
Old 08-09-2011, 10:20 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
232 out of 4296 is around 5%, i wouldn't call that ground breaking, considering that probably 80% are 23.976, and the remaining are split between 25p and 60i.
I think i have one disc thats 24.000, and i just use ReClock and don't worry about it. I don't get why people obsess about it that much, and don't just get ReClock.
Its a very rare refresh rate to use, some discs have it, but none are really that mainstream - so i don't require the 100% absolute perfect solution, and ReClock does just fine providing a 99% solution.
PS:
If thats something that broke in a recent driver, you can just create the resolutions in an older version and then install the new one.
PPS:
I don't see how the list you linked makes a difference between 23.976 and 24.000, all i see about video is it saying "1080p24"
Old 08-09-2011, 10:24 AM
MickBim's Avatar
You can't use reclock when bitstreaming audio (which I'm doing)
And btw, reclock convert DTS into AC3 no ? Is there any audio loss ?
MickBim is offline
Old 08-09-2011, 10:34 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
1080p24* (asterisked) is 24.000 fps.
renethx is offline
Old 08-09-2011, 10:48 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I also don't understand why people insist on making it so hard on themself by insisting on bitstreaming.
Wonder how hard it would be to write a small tool that can just set the custom resolutions inside the nvidia settings without the limitations of that control panel. Or maybe the limitation isnt in the panel, but rather somewhere deeper, even in windows itself?
Old 08-09-2011, 10:52 AM
MickBim's Avatar
For DTS-HD audio, simple as that.
Reclock resamples in AC3 no ?
MickBim is offline
Old 08-09-2011, 10:57 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
ReClock *can* encode into AC3, but it does not *have* to, its purely optional if you only have a SPDIF connection and want multi-channel audio.
Anyhow, i get all audio decoded to PCM (including DTS-HD), let ReClock do its magic, outputting full PCM over WASAPI, and it all works so smoothly.
I'll leave everyone else to their setup, just saying, its possible to get near perfect playback.
Old 08-09-2011, 11:04 AM
MickBim's Avatar
But in that case no "DTS Master Audio" led on my onkyo
And your solution, even if it works (no sound loss what so ever ?) is a workaround for the buggy drivers.
MickBim is offline
Old 08-09-2011, 11:09 AM
SamuriHL's Avatar
He's using the ArcSoft DTS-HD MA decoder, so, no sound loss whatsoever is correct. And you ALWAYS need workarounds for buggy drivers with videocards. That's a decent solution as you get consistent PCM output which is flawless and ReClock does channel mapping correctly by using WASAPI excl mode.
SamuriHL is offline
Old 08-09-2011, 11:10 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
There is only a very very minor loss in quality due to the resampling done by ReClock. I doubt anyone can actually hear the difference. Who knows what a receiver does to the audio before sending it to the speakers.
Anyhow, you might call it a workaround, i call it a smooth movie experience.
Sure, they could fix the control panel one day, but shrug, gotta go with what we have. IMHO, its still vastly superior to ATI where you simply cannot create a custom resolution at all.
Old 08-09-2011, 11:11 AM
SamuriHL's Avatar
I would LOVE a tool that creates those custom resolutions for us. HINT HINT.
SamuriHL is offline
Old 08-09-2011, 07:24 PM
Andy o's Avatar
No one using the 280 drivers with any of these cards still experiencing driver crashes when using Firefox 4 or 5 with HW accel on? I still am, up to 280.19 beta, but I'm using a 9200m GS on Win 7-64. I don't think the ones reported earlier were able to confirm that this was their problem with the 450GTS.
Trying the 180.26 now but don't have much hope.
The most annoying thing is that with most driver versions I've tried (which is all since FF4 came out officially) I don't get the black flash and "driver recovered" message. Just a plain old crash that requires a hard reboot.
Andy o is offline
Old 08-21-2011, 04:45 PM
nightfly85's Avatar
Quoted: 71 Post(s)
Liked: 41
I bitstream and use reclock without issue. The key thing is that reclock really isn't doing anything while I am bitstreaming so it's main purpose is defeated, but for LPCM/PCM, works great and get's around the Nvidia's 7.1 channel mapping issue.
nightfly85 is offline
Old 08-22-2011, 01:20 AM
Andy o's Avatar
I don't think there's an Nvidia 7.1 channel mapping issue anymore. Is this what you're referring to? If so, you don't need to bitstream to get around it, you can just use ReClock's WASAPI exclusive mode.
Andy o is offline
Old 09-21-2011, 01:21 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I have an NVidia Gigabyte GTS450. Just came home from vacation today and whenever I go to play any sort of video the driver crashes and I get a message that the driver kernel has stopped responding but has been recovered. Thinking it may be a driver issue I just upgraded to the latest beta driver and still the same issue. What do you guys think, the card is toast? It is only 2 months old so it should still be under warranty from Gigabyte, but if this card went bad to be honest my experience with NVidia cards will be a bit soured (this will be the second card that has gone bad since I bought two months ago)
Cheers,
Damian
Old 09-21-2011, 01:37 PM
SamuriHL's Avatar
I'd try the following:
1) Uninstall the current driver completely
2) Shut down the machine, pull the card, clean all the contacts, and reseat it. I know that sounds stupid but it's worth trying anyway.
3) Do a clean install of the driver.
See if that helps. If not, um, well, that's not so good.
SamuriHL is offline
