HELP! 1080p playback on i5 661 is stuttering - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-02-2010, 09:16 PM - Thread Starter
epoc2207's Avatar
Hey guys I'm having a bit of an issue on my new HTPC -
Quick specs -
Mobo: Gigabyte H55N-USB3
CPU: Intel i5 661 (Clarkdale)
2TB HDD
4GB Ram
450W PSU
LG Blu-Ray Player
I've finished setting up the PC, installed everything I can possibly think of, and started trying to play 1080p mkv (H.264) movies that I know work well. Unfortunately even though hardware acceleration appears to be running (CPU is about 20% w/ video playback) the video remains stuttering (slightly choppy).
My ultimate goal is to get this working with XBMC but if I can get it working on MPC-HC or VLC for now I'd be put at ease. Everyone has told me that my build has/is way overkill for just playing 1080p movies but yet it still can't under it's current configs. Can anyone help me find out what I'm doing wrong?
epoc2207 is offline
post #2 of 10 Old 08-02-2010, 10:33 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
Which directshow filters are you using in MPC-HC? Make sure your PC isn't in some power saving mode either, i.e. lower performance.
fitbrit is offline
post #3 of 10 Old 08-02-2010, 11:17 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
No, definitely hardware acceleration is NOT working. CPU usage would be ~5% if it were working.
Hardware is good, but the software decoder is not good. Use DSPlayer (built in a version of XBMC) or MPC HomeCinema.
renethx is offline
post #4 of 10 Old 08-03-2010, 01:05 AM - Thread Starter
epoc2207's Avatar
I was actually (inadvertently) not in a high performance mode (which was corrected).
As for the filter - I'm sorry I can't remember the exact name - I did a complete wipe of the system and lost the filter. I think if I remember right it was something like MPC Decoder (i think). Which filter would you suggest when I re-install it?
renethx - What would you suggest I do if I want to get hardware acceleration working correctly for my system. In XBMC there's an option to enable DXVA2 (which I have done) but apparently that isn't working properly. Also - are you suggesting to use DSPlayer as a sort of wrapper for XBMC?
epoc2207 is offline
post #5 of 10 Old 08-03-2010, 03:21 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
DSPlayer is another XBMC internal player. It is a customizable DirectShow player. Download this version. DSPlayer is essentially MPC HomeCinema, but its UI is completely integrated in XBMC.
renethx is offline
post #6 of 10 Old 08-03-2010, 05:22 AM
dbone1026's Avatar
Quoted: 235 Post(s)
Liked: 117
With the Core i5 you may have to switch away from the FFDSHow/MPC Internal filters, as they cause green blocking. I just ended up switching to the MS DTV Video Decoder (only downside is you lose DXVA for VC-1 but I have a core i5 as well and it has plenty of juice to play back VC1 without issue). Here is my writeup on using DSPlayer and also how to assign the MS Video Decoder - http://www.mediasmartserver.net/2010...sing-dsplayer/
You can also use the Arcsoft or PDVD Video Decoder if you prefer
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is online now
post #7 of 10 Old 08-03-2010, 11:13 AM - Thread Starter
epoc2207's Avatar
Thanks so much guys - I'll give it a try when I get back home and let you know how it goes!
epoc2207 is offline
post #8 of 10 Old 08-03-2010, 12:12 PM
valtopps's Avatar
i was going to build a i3 htpc but a lot of people are compaining about this. so i built a socket 775 htpc.
GIGABYTE GA-E7AUM-DS2H LGA 775 NVIDIA GeForce 9400 HDMI Micro ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813128363
with 4gb memory and a e2140 oc to 3ghz 1tb hdd. works great. cost us $160.
now i just need a better htpc case.
valtopps is offline
post #9 of 10 Old 08-04-2010, 08:49 PM - Thread Starter
epoc2207's Avatar
So I've been messing around with different configurations trying to get the dsplayer setup to work properly.
Almost every solution comes up with roughly the same amount of stutter (never in the same place). Also - as Damian said there would be - there was some major green blocking. So as suggested I followed his guide and have everything setup the way the guide follows (setting up everything as a fresh setup) for MS Video Decoder but I'm now getting a different error: "An Error Occurred when trying to render the file".
The error list:
Code:
20:44:21 T:1908 M:2328260608  NOTICE: Loading filter core factory settings from special://profile/dsplayer/filtersconfig.xml (filters configuration).
20:44:21 T:1908 M:2328219648  NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
20:44:21 T:1908 M:2328211456  NOTICE: Loading filter core factory settings from special://profile/dsplayer/mediasconfig.xml (medias configuration).
20:44:21 T:1908 M:2328199168  NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig.xml (medias configuration).
20:44:21 T:1908 M:2328195072  NOTICE: Successfully loaded rules
20:44:21 T:1908 M:2327887872  NOTICE: CFGLoader::InsertAudioRenderer Successfully added "DirectSound: LG TV (Intel(R) Display Audio)" to the graph
20:44:21 T:1908 M:2327691264  NOTICE: No renderersettings.xml to load (special://masterprofile/dsplayer/renderersettings.xml)
20:44:21 T:1908 M:2326921216   FATAL: CFGFilterFile::Create CoCreateInstance failed!
20:44:21 T:1908 M:2326921216   ERROR: CFGLoader::LoadFilterRules Failed to insert source filter
20:44:21 T:1908 M:2326921216   ERROR: CFGManager::RenderFileXbmc Failed to load filters rules
20:44:21 T:2472 M:2326978560   ERROR: Playlist Player: skipping unplayable item: 0, path [Y:\\HD Movies\\Sunshine\\Sunshine.mkv]
To give more info - I know there are issues with subtitles and I'm working to demux them out of the files (Sunshine never had subs of any form) but I'm not using those for testing.
Also I know this question may be better suited for the XBMC forums at this point and I'm searching endlessly for a post that already exists, but in the instance someone can potentially help me - that'd be fantastic.
Thanks again for all the help
epoc2207 is offline
post #10 of 10 Old 08-04-2010, 10:39 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I would try MPC HomeCinema (a standalone player) first and find the best source/splitter/decoder combination, then use the same combination in DSPlayer. If a problem occurs only with DSPlayer, then DSPlayer is the cause of the issue... (Use MPC HomeCinema as an external player then. )
renethx is offline
Reply Home Theater Computers
