Antec ISK 300-150 mini-ITX case - Can you fit a 3.5" drive (instead of 2.5")? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-08-2010, 07:12 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I am interested in using the Antec ISK 300-150 for a few upcoming builds but am wondering if you can put 1 3.5" hard drive in the two 2.5" slots.
The people who I build for aren't interested in SSD technology and I would like to put a hard drive bigger than a 2.5" 500GB.
Please let me know.
http://www.newegg.com/Product/Produc...-080-_-Product
assassin is offline
post #2 of 11 Old 08-08-2010, 08:47 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Did another google search. Haven't found an answer yet.
assassin is offline
post #3 of 11 Old 08-08-2010, 09:32 PM
blue_z's Avatar
Quoted: 12 Post(s)
Nope. The drives sit side-by-side.
There doesn't seem to be clearance for a 12.5mm thick drive either.
BTW that case has an eSATA port.
Now, if you leave out the (slim) optical drive too, then a 3.5" drive should fit; it's really cramped on the back, connector end of the drive.
Regards
blue_z is offline
post #4 of 11 Old 08-09-2010, 07:17 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Regards
So if I leave out the optical drive how do I mount the 3.5" drive where the slim drive would have gone? Is there some sort of bracket or adapter I could buy?
Or am I better off going with a 2.5" SSD/HD and adding an external drive via USB/eSATA?
assassin is offline
post #5 of 11 Old 08-09-2010, 02:27 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Can anyone who actually owns this drive comment on this issue?
assassin is offline
post #6 of 11 Old 08-09-2010, 07:24 PM
blue_z's Avatar
Quoted: 12 Post(s)
"Drive" or case?
FYI, I own the 85-watt version of this Antec case.
I've installed drives per the manufacturer's specification, and have not tried to modify it. Hence I cannot provide any guarantees as to installing a 3.5" drive.
The optical drive is mounted on a tray. So if four holes are drilled, then the bottom-mount holes of the 3.5" drive would secure the HDD to this tray. But I have not done this, and there is a frame member that could interfere with the drive (power and data) connectors.
You're welcome.
And if you're wondering about my ability to modify or build stuff, here's one of the vacuum tube audio amps I've built:
http://mysite.verizon.net/ress3f9f/s...g.w560h357.jpg
blue_z is offline
post #7 of 11 Old 08-10-2010, 10:41 PM
Smitty2k1's Avatar
I just put together a computer using this case. Absolutely no way to fit a 3.5" drive and an optical drive. You could fit a 3.5" drive and no optical drive with some pretty good cutting and modding of the internal sheet metal brackets.
Smitty2k1 is offline
post #8 of 11 Old 01-08-2011, 07:09 AM
Stereodude's Avatar
Quoted: 3090 Post(s)
Liked: 2238
This is only partially correct.
I tried to find out if a 12.5mm thick drive would fit or not myself by searching the web and couldn't find an answer to this question so I did my own testing.
You can fit a 12.5mm thick 2.5" HD in one of the two 2.5" "bays" in the Antec ISK 300. As you can see in the picture below it sits just a touch below the metal edge of the case. The cover slid onto the case without any issues.
However, the other 2.5" "bay" will require modifying to fit a 12.5mm drive because there is a lip / flange in the way. Here you can see a standard 9.5mm drive installed in the second "bay" and how the lip overhangs the drive.
The lip could be cut off, or perhaps folded to not extend over the drive.
Stereodude is offline
post #9 of 11 Old 01-28-2011, 02:24 PM
DssTrainer's Avatar
I too am looking at this for my HTPC case.... I really want to shove an internal blu-ray burner in the drive bay.. but while it looks like it will fit a normal sized 5.25" drive, it claims that it must be "slim". I don't see any slim blu-ray burners on newegg.. I am safe to assume this will not fit a standard internal blu-ray burner?
DssTrainer is offline
post #10 of 11 Old 01-28-2011, 02:30 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Won't fit a standard.
Have you thought about building an external bluray drive?
assassin is offline
post #11 of 11 Old 01-28-2011, 02:44 PM
DssTrainer's Avatar
Well my next idea would be to get an internal bluray burner with an enclosure plugged into the external e-sata connector
OR
Switch to a slightly larger case:
http://www.newegg.com/Product/Produc...D=3727197&SID=
This also adds a bit of extra power, tho also a bit of extra noise... Noise isn't a huge concern as long as the heat generated doesn't pose a problem for me hiding the htpc in my tv credenza. I did add a ventilation fan to the back of my credenza so it should eject the heat so-so but that will be a bridge to cross after building the htpc
Reply Home Theater Computers
