Help i crashed my Win-dvd 2.3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-21-2002, 01:06 PM - Thread Starter
caryt's Avatar
I am a novice at this so please bear with me, I have an AVS 733 dvd computer running Win 98 2nd edition. My player is a Windvd 2.3, I went to play starwars dvd and when the screen came up to add some special feature I goofed and turned off the computer. Dumb, Now every time I try to use Windvd the system LOCKS UP!!! So I tried to fix it by downloading 2.64, No luck, so I filed 2.3 in the trash can! I have searched in vain to find 2.3 to reload. Any sugestions, I dont want Windvd 3.0 Thaks for your help
caryt is offline
post #2 of 2 Old 03-21-2002, 02:13 PM
Huey's Avatar
Use Zoomplayer to play DVD using your 2.3 video and audio filters. The filters should be in Program Files/Intervideo/WinDVD/Common/Bin subdirectory though ZP will find them automatically for you if you pick WinDVD video and Directsound audio graph. Good luck.
If this does not work just deinstall and reinstall WinDVD 2.3.
Huey ;-]
Huey is offline
Closed Thread Home Theater Computers
