Home video DVD conversion question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-21-2010, 06:37 PM - Thread Starter
usctrojan98's Avatar
I have about 10 home video miniDVD's shot on Sony Handycam DVD camcorder. I have all the VIDEO_TS folders and would like to export/convert these into clips which represent "chapters" in each DVD so that I can a) provide a proper timestamp and b) add them to my media collection for better browsing of various clips.
I have two questions in this regard:
1. How do I make sure I keep as much quality in video and audio from the original. After all, these are all cherished memories like both my kids' births, their first birthdays, etc. I mean in terms of format (m4v, mp4, wmv, mpeg, etc.) as well as settings (frame rates, etc.)
2. Any recommendation of tools for Windows use?
Thanks in advance!
ps: This may not be the best forum to ask this, but I could not find a better place to ask, so please redirect me if needed.
usctrojan98 is offline
post #2 of 5 Old 08-21-2010, 08:26 PM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 108
I would suggest asking this in the camcorders forum located towards the bottom of the list of forums.
-Suntan
Suntan is offline
post #3 of 5 Old 08-21-2010, 10:24 PM
steven975's Avatar
I bet if you take the individual VOB files and put them in a video_ts folder on a full-size DVD it will treat them as chapters. It'll require you to rename some of the VOBs, IFO, BUPs and whatever else is on a DVD.
That'll also not modify the video in any way.
I know there's basic software like Sonic and a few others that will probably do this in a "point and click" way. I bet even the Live Essentials Movie maker may even be able to do it.
steven975 is offline
post #4 of 5 Old 08-21-2010, 10:59 PM - Thread Starter
-Suntan
Ok, will do. Thanks!
post #5 of 5 Old 08-21-2010, 11:01 PM - Thread Starter
Windows Live Movie Maker is able to see the VOB files but it is unable to show me the chapters. Since the date and time for each clip/chapter is different, I would like to be able to see each clip separately so I can then assign correct date and time to each clip.
Similar problem will occur if I just put the VOB file someplace.
What I am looking for is to be able to generate clips out of the VOB files, each of which can be edited seprately.
Reply Home Theater Computers
