Run Windows 7 from USB Flash Drive - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2010, 02:06 PM - Thread Starter
gunbunnysoulja's Avatar
I was just wondering if anyone here has been successful running (not creating a bootable installer) Windows 7 from a usb flash drive.
Any information would be appreciated!!
gunbunnysoulja is offline
Old 09-03-2010, 02:31 PM
ogormask's Avatar
Not sure that most people would have a big enough one and I am sure they arent really fast enough. It may work.
ogormask is offline
Old 09-03-2010, 04:48 PM - Thread Starter
How big would it need to be?
I know VM's can be installed on <8GB Flash Drives...
It's more of a project I have been trying to accomplish, but there are limited resources available discussing on "How To".
I'm sure someone out there has done it... I read about having the .vdi file for a VM and then running a usb boot fix, but I also came across others saying it can be done outside of the VM environment (even though the vm way still doesn't require a host OS).
Hmmm... anyone?
Old 09-03-2010, 06:29 PM
lovemyram4x4's Avatar
It should fit on a 16gb, both of my win 7 install are >8gb<16gb, IIRC windows stated system requirements are 20gb for OS.
lovemyram4x4 is offline
Old 09-03-2010, 07:04 PM
gazebo's Avatar
Quoted: 14 Post(s)
IIRC, I don't think you can run Windows off a USB drive. It's done for security reasons starting with Windows NT.
gazebo is offline
Old 09-03-2010, 11:23 PM
kegobeer's Avatar
No one's been able to get it to work, as far as I know.
kegobeer is offline
Old 09-04-2010, 06:50 AM - Thread Starter
Really? I'm assuming running from a flash drive is different from running on a USB HDD then? I know many have got it working on a USB HDD so I guess I assumed it would be the same.
Old 09-04-2010, 06:55 AM - Thread Starter
I know you can't do it natively, but others over @ www.boot-land.net have been successful. I guess I'll have to give one of their guides a shot.
Old 09-04-2010, 07:13 AM
gazebo's Avatar
Quoted: 14 Post(s)
Interesting.
I also found this. It makes a reference to the official Microsoft party line for non-support and gives details on the extensive hacks needed to get it working.
The success rate appears to be hardware dependent.
If I were to do this (i.e. boot off an external drive) I may want to pick a system with eSATA support and boot off a SATA drive. In theory that should be fully supported by Windows.
gazebo is offline
Old 09-04-2010, 07:16 AM - Thread Starter
Interesting.
Oh I know eSATA is a non-issue and would be idea for speed, but the issue is the portability aspect of the concept, as many systems don't have eSATA.
Thanks for the link, it looks like a good read!
The project is more of a hobby than being practical, as it's just something I wanted to get working!
Old 09-04-2010, 06:42 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
You can definitely boot Windows XP from a flash drive but I'm not sure if it's been done with Win 7. There are tutorials on how to install Windows 7 from a flash drive but I don't believe that's what the OP is looking for.
IIRC, flash drives can only be formatted as FAT or FAT32. Windows 7 requires an NTFS file system and therefore could not be installed on a flash drive using FAT32.
captain_video is online now
Old 02-12-2014, 03:55 PM
fearacious's Avatar
BAHAHAHA! OMG! Yes, you can run it off a USB drive. And there are many different ways to do it, all pretty much get the same result. God I hope this thread has been updated since 2010.
fearacious is offline
Old 02-13-2014, 05:47 AM
Quoted: 510 Post(s)
Liked: 336
BTW, links are always helpful to back up any claims you make.
