Nvidia GeForce 240 - resolution at boot? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-15-2010, 12:10 AM - Thread Starter
khelvan's Avatar
Hello, I am using an Nvidia GeForce 240 on a Windows Vista Home Premium 64-bit machine. I've downloaded the latest GeForce drivers, and used the Nvidia interface to correct my overscan problem.
However, I always seem to lose resolution at boot time, when I am connected via HDMI to my AVR. Is there a way that I can ensure that it boots to (near) 1920x1080 each time?
I apologize if this has been asked before, the search function seems to be down at the moment.
khelvan is offline
post #2 of 13 Old 09-15-2010, 06:29 AM
buzzqw's Avatar
my plasma (panasonig p46g10) with the gt240 (asus gt240 1gb dd3) report a 1080i as resolution
when windows/linux load i got the full 1080p
BHH
HDConvertToX, AutoMKV, AutoMen, AutoX264 developer, Panasonic P46G10, Htpc, Chromebox with openelec, PS3, Yahama 663, dune smart h1, nuc sandybridge, rpb1, rpb2, odroid-x....
buzzqw is offline
post #3 of 13 Old 09-15-2010, 07:57 AM
walford's Avatar
The Info button on your TV's remote reports the resolution that the TV is receiving over the interface you are using.
When you boot your Graphics card uses a resolution that your AVR states that it will support.
Newer TVs have the ability to disable overscan over their component or DVI/HDMI interfaces do not overscan content received over their VGA interfaces.
All DVI/HDMI interface receiver chips support `1080i/60 and only newer ones may accept 1080p/60.
walford is offline
post #4 of 13 Old 09-15-2010, 08:43 AM
ES_Revenge's Avatar
Quoted: 410 Post(s)
Liked: 133
When it gets into Windows it should go back to the resolution you had it set to when you shut down/hibernated Windows. Does it not do that?
I know when I go directly to my TV my computer (ATi card) will POST/boot at 1080p but through my receiver (which is older and HDMI 1.0) I get only 480i at boot time but goes back once Windows is in, as mentioned. Slightly annoying, but only slightly. It's not like I'm using the computer like that really. If yours is staying at the low res when you get into Windows though, I can see how that's a problem...
ES_Revenge is offline
post #5 of 13 Old 09-15-2010, 08:43 PM - Thread Starter
khelvan's Avatar
No, what happens is I have it set to just under 1920x1080(i, 30 Mhz), when it boots I can see that resolution at the login screen, but then the screen flickers and the resolution drops down to about 800x600.
I am running the output through a Pioneer VSX-1019AH.
khelvan is offline
post #6 of 13 Old 09-16-2010, 07:46 AM
walford's Avatar
Does it work properly is you bypass the receiver?
walford is offline
post #7 of 13 Old 09-18-2010, 03:13 AM - Thread Starter
khelvan's Avatar
I have not yet tried bypassing the receiver, as I would need to reconfigure my HDMI connections (no easy task with the way I have the system set up), and could not get sound output that way as my HDTV has no attached speakers.
khelvan is offline
post #8 of 13 Old 09-18-2010, 07:16 AM
walford's Avatar
According to the following specifications your TV does have built it speakers.
http://reviews.cnet.com/flat-panel-t...-33497900.html
walford is offline
post #9 of 13 Old 09-27-2010, 03:27 AM - Thread Starter
khelvan's Avatar
I ordered the non-consumer version which has no speakers and no HDMI input directly from Visual Apex - I added the HDMI input as an add-on card.
TH-42PHD8UK: http://reviews.cnet.com/Panasonic_TH...-31512167.html
So no, I have no speakers. I would hope I knew enough about my TV to inform you correctly about this.
khelvan is offline
post #10 of 13 Old 10-12-2010, 03:31 AM - Thread Starter
khelvan's Avatar
Hello, does anyone have any suggestions? After I see the login screen pop up in the correct resolution, after a second it shifts to 800x600 and no longer shows the login prompt. After trial and error I have discovered that I can still log in, and then switch resolutions, but I would love to avoid this step.
khelvan is offline
post #11 of 13 Old 11-24-2010, 02:35 PM - Thread Starter
khelvan's Avatar
Still hoping for help
khelvan is offline
post #12 of 13 Old 11-25-2010, 07:12 AM
walford's Avatar
Are you sure your TV does not have the ability to disable overscanning so that you don't have so you don't have to use the Nvidia interface to underscan your PC output? If not are you not able to create a Custom resolution in the Nvidia drivers that you can then select.
walford is offline
post #13 of 13 Old 12-01-2010, 12:13 AM - Thread Starter
khelvan's Avatar
I have found no way to adjust that on the TV, but I am not 100% sure it doesn't support it. The TV is about 5-6 years old now.
I did create a custom resolution - the problem is that it doesn't "stick." As soon as I reboot (and occasionally after the computer is idle for a while) the computer "loses" the resolution and I have to go back in and change it.
khelvan is offline
Reply Home Theater Computers
