Asus Blu Ray drive didn't come with software... now what? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 09-18-2010, 07:02 PM - Thread Starter
krillbee's Avatar
Hello,
I recently purchased an Asus Blu Ray drive but I didn't realize that it didn't come with software until now. Returning this drive is not an option that I want to explore. I would rather pay the extra for my mistake and buy software seperately as it would save the headache of having to do a return.
I didn't realize that Blu Ray playback software was so expensive. I found out that the retail version of the drive I bought would have come with Cyberlink software. On Cyberlink's site, their cheapest Power DVD software that supports Blu Ray is $100, over double the price I paid for this drive.
I found Intervideo WinDVD Pro software for $40 online that will support Blu Ray, but I've heard bad things about WinDVD online.
I've searched ebay, but it's hard to find the "pro" or "ultra" versions that support Blu Ray.
Does anyone have advice on what software I should get if I want to spend the least amount of money possible?
krillbee is offline
post #2 of 21 Old 09-18-2010, 09:44 PM
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
I would say "spend nothing" and get the software from Asus. If it was supposed to be packaged with the drive, then you need to contact the manufacturer and have them send it to you. No reason at all to spend a penny extra.
Welcome to Rivendell, Mister Anderson.
Jedi2016 is offline
post #3 of 21 Old 09-18-2010, 10:02 PM - Thread Starter
krillbee's Avatar
You don't understand. I don't think it was supposed to come with anything. All I got was the metal drive and an antistatic bag around it. It came in a cardboard shipping box.
krillbee is offline
post #4 of 21 Old 09-18-2010, 10:43 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Wouldn't it be cheaper to return it and get a drive that has the software you need?
ack_bk is offline
post #5 of 21 Old 09-18-2010, 11:15 PM - Thread Starter
krillbee's Avatar
The nearest post office is 40 minutes away.
Cheaper? Perhaps. Worth it? Not necessarily.
krillbee is offline
post #6 of 21 Old 09-19-2010, 12:02 AM
Craigslue's Avatar
Sounds like you need to check the HTPC forum.
Craigslue is offline
post #7 of 21 Old 09-19-2010, 02:51 AM
Stevie76's Avatar
Try out the trial version of Total Media Theatre 3:
http://www.arcsoft.com/estore/softwa...ductCode=TMT3P
Works brilliantly with every disc. I had Cyberlink PowerDVD before that, but some discs just wouldn´t play on that software.
Stevie76 is offline
post #8 of 21 Old 09-19-2010, 07:31 AM
msgohan's Avatar
Assuming you know that your post was moved, I would also recommend TMT3. Haven't tried WinDVD but I much prefer it to PowerDVD.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #9 of 21 Old 09-19-2010, 07:56 AM
Jermmd's Avatar
Here's a link for TMT for $49.
Joe
Joe M.
Jermmd is offline
post #10 of 21 Old 09-19-2010, 09:07 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Before buying anything, I would make sure the drive will properly read and playback BDs. Try MPC-HC since it is free and can playback BDs.
http://mpc-hc.sourceforge.net/
audit13 is offline
post #11 of 21 Old 09-19-2010, 09:11 AM
ogormask's Avatar
Not sure why no one mentioned this but what you most likely purchased was an OEM drive meaning its barebones or just comes with the drive. What you may want to have purchased was a retail version which normally comes with software in this case. You might want to check where you purchased it and see if they have the retail version and explain them your mistake and see if they will swap you. Usually retail isnt that much more and in this case would save you some money. I know liteon drives usually come with software.
ogormask is offline
post #12 of 21 Old 09-19-2010, 09:22 AM
mcantu1's Avatar
how do i make sure that hardware acceleration is turned on when using mpc-hc for bd's?
mcantu1 is offline
post #13 of 21 Old 09-19-2010, 12:34 PM
Bob7145's Avatar
Liked: 36
The "free" software that sometimes shipped with drives is usually 2 channel stereo so you end up having to buy it anyway to get surround.
Bob7145 is offline
post #14 of 21 Old 09-20-2010, 02:51 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
MPC-HC will NOT play BD from disk, only ripped from the hard drive.
jdcrox is offline
post #15 of 21 Old 09-20-2010, 07:27 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I didn't know that. Thanks for the information.
Personally, I'm using the Asus version of TMT3 that came with my HDAV 1.3.
audit13 is offline
post #16 of 21 Old 09-20-2010, 07:48 PM
Davinleeds's Avatar
Try the trial of TMT (no Dolby) to see if everything (no Dolby) (just switch everything to pcm in audio settings) works. Then decide,the player you'd like, which should be determined on your AVRs capability and if you own AnyDvdHD.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #17 of 21 Old 09-20-2010, 11:56 PM
Guitar1969's Avatar
I bought an OEM version of the ASUS drive and it came with a CD. It had a old version of pdvd - I ended up upgrading anyways
Guitar1969 is offline
post #18 of 21 Old 09-21-2010, 09:40 AM
davdev's Avatar
I don't have any Blu-Ray playback software and I can watch Blu-Rays just fine. How? I rip to MKV.
Don't worry about TMT or PDVD, they all stink anyway. Just rip to MKV and you are good to go. You will need to get ANYDVD, but that is a virtual requirement for any HTPC anyway.
As others have said, the software the comes with the retail version of your drive is crippleware anyway so you don't really gain anything by getting the retail version, unless you are OK with stereo only sound. However, I bet if you were, you wouldn't be here in the first place.
davdev is offline
post #19 of 21 Old 09-21-2010, 11:19 AM
SugarBowl's Avatar
You should be able to find PowerDVD 9 Ultra for cheap.
SugarBowl is offline
post #20 of 21 Old 09-21-2010, 11:20 AM
lovemyram4x4's Avatar
If you're using passthrough/bitstreaming this doesn't matter, I used my PDVD 7 that came w/ my BD/ HD DVD rom until I switched to TMT 3 and it didn't matter that it was only 2 channel version because I ran it in pass through mode.
lovemyram4x4 is online now
post #21 of 21 Old 09-21-2010, 07:31 PM
rdunnill's Avatar
Mine had nothing bundled with it.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
Reply Home Theater Computers
