how to get dts-hd output on laptop - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-13-2010, 07:44 AM - Thread Starter
infamo's Avatar
I have a dell studio 1667 with a ati video card that has HDMI output.....everything works fine but I can't send dts-hd or dolby-hd over hdmi cuase my video card doesn't support that....is there another way, can i buy something to do this?
also, i've read that i can do uncompressed "LCM?" but how does that differ from dts-hd or dolby-hd??
infamo is offline
post #2 of 7 Old 10-13-2010, 07:56 AM
gimpgutter's Avatar
As far as I'm aware of, there are no commercially available external soundcards for a laptop that can process and bitstream HD audio codecs.
Going back to your question on LPCM, you can still get DTS-HD and TrueHD that way. The difference is where the signal is decoded. If you choose LPCM, the laptop decodes the audio signal and will send the uncompressed digital stream to the receiver.
Bitstream is often compared to a zip file. It is a compressed version of the digital signal sent out and the receiver will decode the audio signal instead of the computer.
Overall, the information IS identical whether you let the computer or receiver do the work. The difference between the two is related to how the receiver handles the signal. Some do not have the ability to apply bass management and room correction to LPCM, but can to Bitstream or vice versa.
From what I read on www.notebookcheck.net , only the AMD Radeon 5600 series or higher can bitstream in a laptop, but I couldn't find any confirmation where someone actually did this.
If your laptop can support 7.1 channel LPCM via HDMI, then you should be just fine.
gimpgutter is offline
post #3 of 7 Old 10-15-2010, 09:56 AM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Is it possible that your Ati video card does not support bitstreaming?
I know that the desktop 4xxx series do not support bitstreaming while the 5xxx series can bitstream with the right software.
audit13 is offline
post #4 of 7 Old 10-15-2010, 03:26 PM
hirent's Avatar
Originally Posted by infamo View Post
I have a dell studio 1667 with a ati video card that has HDMI output.......is there another way, can i buy something to do this?
Which card do you have?
Well, I have the 5450 in my tablet and the HD Codecs show up in audio properties but I haven't tried BD playback on here; don't know if it works.
hirent is offline
post #5 of 7 Old 10-17-2010, 10:25 AM
Sporac's Avatar
I have the Dell Inspiron 14R with i5 with ati 5470. It bitstream to my Onkyo 608 no problem.
Sporac is offline
post #6 of 7 Old 10-17-2010, 11:14 AM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
That's good to know. I could also get an MSI i3 laptop with Intel HD graphics to bitstream as well.
audit13 is offline
post #7 of 7 Old 10-17-2010, 12:51 PM
zicoz's Avatar
According to AMD.com it's 5400 and up.
http://www.amd.com/us/products/noteb...y-hd-5400.aspx
zicoz is offline
Reply Home Theater Computers
