Is it possible to get HD audio full bitrate, over analog 5.1, EVEN if downsampled? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 202 Old 10-18-2010, 02:04 PM
vladd's Avatar
Liked: 39
Doesn't look like my local retailers have that one. I'll have to order it.
vladd is offline
post #62 of 202 Old 10-18-2010, 02:11 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
As for media subtype, here are a couple of screenshots.
ffdshow *core* DTS decoding inside MPC HomeCinema:
ffdshow DTS-HD MA bitstreaming inside MPC HomeCinema:
CyberLink Audio Decoder DTS-HD MA(?) decoding inside MPC HomeCinema:
So all three are identical.
PowerDVD 9 DTS-HD MA decoding (a commercial BD player)
Cyberlink Demuxer 2.0. Audio is downsampled to 48kHz, 16bit (perhaps because of the lack of PAP)
I see {6A644687-5756-4D0D-8AA3-178ACF48DEC9}.
Originally Posted by vladd View Post
The Cyberlink Audio Decoder will only decode full DTS-HD when the subtype is reported as "{6A644687-5756-4D0D-8AA3-178ACF48DEC9}"
Yes, "{6A644687-5756-4D0D-8AA3-178ACF48DEC9}" is reported if full DTS-HD is decoded in PowerDVD/CyberLink Demuxer. But this does not necessarily mean that "{6A644687-5756-4D0D-8AA3-178ACF48DEC9}" must be reported if full DTS-HD is decoded with any player/splitter (?)
renethx is offline
post #63 of 202 Old 10-18-2010, 02:14 PM
vladd's Avatar
Liked: 39
Originally Posted by GrandeBoma View Post
power dvd version ( i use 10.0.1516.51)
This could be the key. I was testing with a newer version. I'll try it later.
vladd is offline
post #64 of 202 Old 10-18-2010, 02:17 PM
vladd's Avatar
Liked: 39
Originally Posted by renethx View Post
Yes, "{6A644687-5756-4D0D-8AA3-178ACF48DEC9}" is reported if full DTS-HD is decoded in PowerDVD. But this does not necessarily mean that "{6A644687-5756-4D0D-8AA3-178ACF48DEC9}" must be reported if full DTS-HD is decoded at any player??
All depends on how they coded it so I can only speculate. If they coded it like ffdshow does where it ignores the media type and actually checks the stream (as seen in your screenshots) then the media type won't matter.
vladd is offline
post #65 of 202 Old 10-18-2010, 02:29 PM
ricabullah's Avatar
The critical filter in DTS HD streaming is demuxer, not decoer itself.
For instance:
The source file:
And you will see MPC Mpeg Source (Gabest) detects it as 48, Cyberlink Audio decoder reads it as 48 but ReClock shows it as 96???
And ReClock shows the true info; where do i know?
I know since i see 96k on my AVR's display.
And; no conclusion.
I can't explain that.
Chronical Tester
ricabullah is offline
post #66 of 202 Old 10-18-2010, 02:35 PM
GrandeBoma's Avatar
Quoted: 17 Post(s)
baraka dts track decoded by mpc splitter ffdshow audio decoder figure 1
baraka dts hd ma decoded by mpc splitter cyberlink audio decoder figure 2
baraka dts core is NOT 96 khz, it's 48 khz, but you were right, dts core CAN theoretically be 96 khz, just this one isn't
GrandeBoma is offline
post #67 of 202 Old 10-18-2010, 02:54 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Have you heard of Super HiVi CAST? The disc includes 7.1 surround sound tests in both TrueHD and DTS-HD MA (a P51 Mustang is circulating around the speakers). I played the DTS-HD MA version with MPC-HC + CyberLink Audio Decoder and got correct 7.1 discrete sounds, exactly identical with sounds from commercial BD players. This would be impossible if only core DTS were decoded (even if Dolby PLIIx were working).
Dolby TrueHD
- Surround_TrueHD_7.1.mkv
- Surround_TrueHD_7.1.m2ts
- Surround_TrueHD_7.1.ISO
DTS-HD Master Audio
- Surround_DTS-HD_MA_7.1.mkv
- Surround_DTS-HD_MA_7.1.m2ts
- Surround_DTS-HD_MA_7.1.ISO
LPCM
- Channel_Test_LPCM_7.1.mkv
- Channel_Test_LPCM_7.1.m2ts
Dolby Digital Plus (E-AC-3)
- Channel_Test_E-AC-3_7.1.m2ts
- It seems that I can't create a MKV file with an E-AC-3 track from the above file by using eac3to or MakeMKV.
DTS-HD High Resolution Audio
- Channel_Test_DTS-HD_HRA_7.1.mkv
- Channel_Test_DTS-HD_HRA_7.1.m2ts
renethx is offline
post #68 of 202 Old 10-18-2010, 02:58 PM
GrandeBoma's Avatar
Quoted: 17 Post(s)
I think ricabullah has a point, there is something odd about the reports of mpc-hc, I too read it is a dts 48 khz 1.5 mb track on the properties of source filter, but this makes no sense because reclock is reporting 96 khz... I don't think there can be upsampling
post #69 of 202 Old 10-18-2010, 03:11 PM
ricabullah's Avatar
It's impossible since it directly passhhrough to AVR without dropping to mixer;
otherwise i couldn't see 96 k on my AVR's display. (WasApi Exclusive)
What is missing in my case there is a downmixing not downsampling. (so it's not bitperfect-lets say as is.)
I'm trying to find a hack to PDVD10 decoder but no luck.
Chronical Tester
post #70 of 202 Old 10-18-2010, 03:15 PM
vladd's Avatar
Liked: 39
I would agree with that. So it looks like GrandeBoma is correct (no offence, I just like confirmation). Unfortunately, I still cannot get any PDVD audio decoder version to connect to any renderer. Granted, I am using trial versions.
Try using BDInfo to check the stream.
vladd is offline
post #71 of 202 Old 10-18-2010, 03:20 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
PowerDVD 9 Build 2320 and PowerDVD 9 Build 2528 (the last build) are guaranteed to work with the latest SVN of MPC HomeCineam and ReClock under Windows 7 (32-bit). (Actually the audio decoder in Build 2320 has issues, but first I have to install it before updating.)
renethx is offline
post #72 of 202 Old 10-18-2010, 03:22 PM
GrandeBoma's Avatar
Quoted: 17 Post(s)
then we must come to the conclusion that mpc splitter is lying about what is being passed to the decoder and the decoder is lying about what is being passed to reclock. Then reclock and the avr tell the truth
vladd I have retail of both pdvd 9 and 10. I don't think this is the reason you can't connect it. Are you using the same mpc and pdvd version as me and rene?
ricabullah you need to get pdvd 9 audio decoder if you want to make the changes in channel count that will apply to pdvd 10 audio decoder
post #73 of 202 Old 10-18-2010, 03:29 PM
vladd's Avatar
Liked: 39
My retail PDVD 9 decoders work fine, it's just the version 10 trial audio decoders I can't get working. I don't use MPC, my tests were in GraphStudio (same effect).
vladd is offline
post #74 of 202 Old 10-18-2010, 03:37 PM
ricabullah's Avatar
SVN 2667 standalone Gabest is working on my graph. (see SCaps.)
All my caps are GraphStudio shots. (except MPC-HC SC)
Chronical Tester
post #75 of 202 Old 10-18-2010, 03:41 PM
GrandeBoma's Avatar
Quoted: 17 Post(s)
well my experience is that pdvd 9 will connect to the splitter but it will not play any sound... I too could build the graph but couldn't hear a damn thing
post #76 of 202 Old 10-18-2010, 04:05 PM
ricabullah's Avatar
Guys after i loaded PDVD9, i can not get any sound with PDVD10 Audio Decoder as well?
Chronical Tester
post #77 of 202 Old 10-18-2010, 04:09 PM
vladd's Avatar
Liked: 39
That's the issue I have pretty much every time I try to use reclock. I have to use normal renderers.
vladd is offline
post #78 of 202 Old 10-18-2010, 04:16 PM
ricabullah's Avatar
OK guys it was a temporary unagreement between AVR and PC.
I get audio but it's still 2 channels.
How do i fix it?
Chronical Tester
post #79 of 202 Old 10-18-2010, 04:27 PM
vladd's Avatar
Liked: 39
Ok, this is a case of doing so much testing, I can't remember things. The Cyberlink audio decoders have decoded DTS-HD/TrueHD since PDVD 9 build 2528. rene, we even discussed it.
@Rica: see the registry instructions on the next page of the following thread.
Originally Posted by slimm View Post
New PowerDVD Ultra 9 patch 2528 available.
Updates:
Adds DTS-HD, Dolby TrueHD file playback support
Adds TrueTheater HD with ATI Stream support
Adds TrueTheater with CUDA for video file playback
Adds support for Realtek ACL669/670/892 HD audio codec
Solved issues:
- GP issue with installed COMODO Firewall
- Region Code issue (BD) with installed Bitdefender SW
- Playback issues with AV Software installed
vladd is offline
post #80 of 202 Old 10-18-2010, 04:37 PM
ricabullah's Avatar
Ok but the question is how do i configure it so as not to downmix?
(i can't see the next page of what thread?)
Chronical Tester
post #81 of 202 Old 10-18-2010, 04:44 PM
vladd's Avatar
Liked: 39
Configure PowerDVD the way you want the decoder to work in other directshow apps and then use the method outlined in http://www.avsforum.com/avs-vb/showp...postcount=2553
vladd is offline
post #82 of 202 Old 10-18-2010, 04:56 PM
ricabullah's Avatar
Thanks vladd.
As you pointed we forget what we've done before: test, test, test
I'll take some notes anymore
Chronical Tester
post #83 of 202 Old 10-18-2010, 05:09 PM
GrandeBoma's Avatar
Quoted: 17 Post(s)
pdvd 9 audio decoder, unlike the cousin pdvd 10 audio decoder does not keep the 96/24 not even with reclock wasapi, instead it will do 48/16
is this correct in your experience?!?
post #84 of 202 Old 10-18-2010, 05:28 PM
ricabullah's Avatar
Yes, i've never seen any 96/24 with PDVD9.
But i have to point out something:
ReClock, even it's set to WASAPI Exclusive, just gets decoded audio and passes it to your AVR without dropping to MS mixer.
If your decoder downsamples or downmixes the audio, ReClock has nothing to do.
In this case it's gonna be WASAPI Exclusive as well but not bitperfect.
Bitperfect means:
Decoder has to be able to decode the audio as is; without downsampling, without downmixing, without post-processing.
BTW don't adjust your sound blaster's SW for any post processing, just leave its sound processor for converting Digital to Analog. (DAC)
This unmolested audio should be carried to your AVR without dropping to MS mixer for post processing. (via ReClock Renderer- set to WASAPI EXclusive)
After this stage your AVR shouldn't touch your unmolested audio.
AVR's DSP should be bypassed via Direct and Pure Audio selection.
Direct means no post-processing, pure means no ADC before, no DAC later; analog audio bypasses ADC/DAC and directly goes to pre amplifier.
If you are streaming PCM audio over analog, the best way is to use an AMP instead of an AVR for sure.
I stated WASAPI Exclusive differences over ReClock on:
http://forum.doom9.org/showpost.php?...34&postcount=1
ReClock config for streaming PCM or FLAC:
Over WASAPI Exclusive: (Non-bitexact streaming or bitexact streaming with ReClock)
Offline Config:
Inline Config:
Non-bitexact streaming:
Leave ReClock properties as is and in this case molested PCM/Flac streaming by ReClock will be trasmitted to your AVR without 7/Vista mixer's interfaring.
This is a WASAPI Exclusive mode for sure but it is not bitexact. (ReClock icon is green)
Bitexact streaming:
Config inline properties of ReClock and "select original speed", "locked" and "slave reference to audio".
In this case, ReClock transmits unmolasted decoded pcm/flac stream to your AVR. And this is gonna WASAPI exclusive-bitexact(bitperfect) mode. (ReClock icon is yellow)
Chronical Tester
post #85 of 202 Old 10-18-2010, 07:22 PM
ricabullah's Avatar
Would you explain this more detailled?
Step by step guide
Export to where and how to edit?
Import to where and how?
Chronical Tester
post #86 of 202 Old 10-18-2010, 07:32 PM
vladd's Avatar
Liked: 39
I have a list of the exact registry values somewhere. I'll try to find them.
vladd is offline
post #87 of 202 Old 10-18-2010, 07:38 PM
ricabullah's Avatar
Thanks in advance.
Chronical Tester
post #88 of 202 Old 10-18-2010, 08:58 PM
vladd's Avatar
Liked: 39
I'll have to double check these later but here they are:
Once you load the Cyberlink Audio decoder in the directshow player you want, it will create a registry key under the following where [ExeName] is the name of the executable:
Code:
HKEY_CURRENT_USER\\Software\\Cyberlink\\Common\\CLAud\\[ExeName]
For example, the registry key for GraphStudio would be:
Code:
HKEY_CURRENT_USER\\Software\\Cyberlink\\Common\\CLAud\\GraphStudio
Adjust the following values as needed:
4 channel:
  • "AuDsInterface"=dword:00000010
  • "AuDsDnmx"=dword:00000040
6 channel:
  • "AuDsInterface"=dword:00000020
  • "AuDsDnmx"=dword:00000080
7 channel:
  • "AuDsInterface"=dword:00000040
  • "AuDsDnmx"=dword:00000800
8 channel:
  • "AuDsInterface"=dword:00000080
  • "AuDsDnmx"=dword:00001000
SPDIF output:
  • "AuDsInterface"=dword:00000004
  • "AuDsDnmx"=dword:00000002
vladd is offline
post #89 of 202 Old 10-18-2010, 11:48 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
NO, that's perfectly wrong, depending on the build of PowereDVD 9. All my results were obtained with PowerDVD 9.0.2528.51 (the last build). CyberLink Audio Decoder of this build works as it should be (except for the fixed channel count). The following screenshot was taken with CyberLink Audio Decoder of PowerDVD 9 Build 2528:
PowerDVD 9 Build 2320 constantly reports 48/16. Saying PowerDVD 9 in general is able or unable to do something is very confusing. I would like to ask everybody to mention the build somewhere. The same applies to PowerDVD 10. Please include the build number!
renethx is offline
post #90 of 202 Old 10-19-2010, 12:27 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
IMO attempting to use the audio decoder of PowerDVD 10 outside it is pretty useless for two reasons.
1. Nobody has ever succeeded in using CyberLink Audio Decoder of PowerDVD 10 (any build) in a DirectShow player, except for GrandeBoma with Build 1516 under XP (or in the XP mode under 7; who would want to play videos in XP mode just for this purpose?).
2. Even if the audio decoder of a certain build worked, who would want to stay with that build forever? Perhaps many people want to stay current. (Or is it possible to extract necessary components from that build, store them somewhere else, and use the audio decoder there successfully?)
renethx is offline
Reply Home Theater Computers
