playing BD disc with MPC - Home Cinema with bit-perfect HD audio over an analog sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 168 Old 10-21-2010, 02:14 PM - Thread Starter
greggplummer's Avatar
I haven't been able to play my BD disc with my recently purchased Arcsoft TotalMedia Theatre v3. TMT3 doesn't recognize all of the features of my soundcard, which uses an Echo Audio 'AudioFire 8' FireWire interface. When I originally downloaded TMT3 (v3.0.1.180) I was able to play a BD disc, but it only gave me the option of either headphones or '2 channel stereo'. Windows 7 recognizes the AudioFire 8 as an 8-channel 24-bit, 96KHz audio device and it works fine with all other A/V software applications like W7MC, WMP12, JRMC15, foobar2000, VLC and MPC HomeCinema. I updated TMT3 to v3.0.1.185 and now it only offers S/PDIF output.
I asked for advice in the Arcsoft thread and haven't been able to get the problem resolved (I have left a message on Arcsoft's forums and have a support ticket with their support). However, renethx mentioned an alternative solution in this post:
http://www.avsforum.com/avs-vb/showt...9#post19369109
He wrote: "You can play a BD disc directly (with AnyDVD HD or DVDFab Passkey running in the background). MPC HomeCinema plays the main title immediately (with good probability )."
He also provided an attachment for a utility (the modified version of MPC Mpeg Source splitter (MpegSplitter.ax)) that works with Arcsofts Audio Decoder HD.
I don't want to hijack the Arcsoft thread with more questions about this, so I decided to ask for more details here.
So, how can you play a BD disc directly with MPC HomeCinema?
I have the Spark007 codec pack installed and it is set as per the recommendations in the Windows 7 Media Center: Setup Guide, Knowledge Base & Support thread.
Do I need any other codecs or changes to my Shark007 settings?
How do I utilize MpegSplitter.ax?
Thanks in advance for any help...
Gregg Plummer
Amplizone - a blog about the development of Amplio Audio's soundcard/amps
The Short History of Audio/Video Technology
greggplummer is offline
post #2 of 168 Old 10-21-2010, 02:26 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I think the thread title is not good. Playing BD with MPC-HC is actually easy: insert a disc with AnyDVD HD or DVDFab Passkey running, select File menu > Open DVD and point to the optical drive; then the main title is automatically played back (but the success rate is not 100%; sometimes a wrong title may be selected). The difficult part is how to get bit-perfect HD audio with an *analog sound card*. So a proper title would be "Playing BD disc with MPC HomeCinema with bit-perfect HD audio over an analog sound card".
renethx is offline
post #3 of 168 Old 10-21-2010, 03:14 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Updated on April 13, 2011
Table of Contents
1. Registering LAV Splitter 32-bit for BD movies, M2TS and MKV.
- Download LAV Filter 32-bit and unzip it to a folder.
- Register LAV Splitter by right clicking install_splitter.bat in the folder, then clicking "Run as administrator".
- Set LAV Splitter to the Windows default source/splitter filter for BD movies, M2TS and MKV by merge the following in the registry:
For Windows 32-bit:
Code:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\\Media Type\\Extensions\\.mpls]
"Source Filter"="{B98D13E7-55DB-4385-A33D-09FD1BA26338}"
[HKEY_CLASSES_ROOT\\Media Type\\Extensions\\.m2ts]
[HKEY_CLASSES_ROOT\\Media Type\\Extensions\\.mkv]
For Windows 64-bit:
Code:
[HKEY_CLASSES_ROOT\\Wow6432Node\\Media Type\\Extensions\\.mpls]
[HKEY_CLASSES_ROOT\\Wow6432Node\\Media Type\\Extensions\\.m2ts]
[HKEY_CLASSES_ROOT\\Wow6432Node\\Media Type\\Extensions\\.mkv]
{B98D13E7-55DB-4385-A33D-09FD1BA26338} is GUID of LAV Splitter. This assures LAV Splitter is always used to play back MKV files in any DirectShow player (unless the player specifies another source/splitter filter).
2. Registering ArcSoft Audio Decoder HD of TMT3 Build 185.
- Place the custom version of checkactivate.dll in C:\\Program Files\\ArcSoft\\TotalMedia Theatre 3\\Codec for Windows 32-bit, or C:\\Program Files (x86)\\ArcSoft\\TotalMedia Theatre 3\\Codec for Windows 64-bit.
- Open the file win.ini located in C:\\Windows with Notepad. Add the following lines at the end and save it (you may have to save it in another location, then copy it).
Code:
[HKEY_LOCAL_MACHINE\\SOFTWARE\\ArcSoft\\MPEG Codec\\Decoder Setting\\]
AudioOutputMode=17
AudioDynamicRange=1
This is for normal DynamicRange and 7.1 speakers. Other choices are
Code:
AudioDynamicRange:
0: Light
1: Normal
2: Threaded
AudioOutputMode:
0,1,2,5: Stereo
6,13: 5.1 Channels
17: 7.1 Channels
16: S/PDIF
- Register ASAudioHD.ax (and whatever filters you want to use, e.g. ASVid.ax, ArcSoft Video Decoder [for H.264, VC-1, MPEG-2]). (How to register a DirectShow filter.)
Remarks
  • TMT3 185 is the only build of TMT3 that supports bit-perfect decode outside TMT3, and none of TMT5 build support bit-perfect decode. Here is a link to Trial (enough if your purpose is use decoders outside TMT):
    ArcSoft TotalMedia Theatre 3 Platinum 3.0.1.185 Trial
  • Read the post below Minimum ArcSoft DLLs if you don't want to keep the entire TMT.
  • So called "wrapper" (ASAudioHD+.ax) won't work with TMT3 185. Forget about that and use only win.ini.
3. Using ReClock.
You have to use WASAPI exclusive mode via ReClock to avoid Windows Audio Engine resampling audio streams without your permission. )
- Install ReCock (the latest version is found in the SlySoft forum).
- Open Configuration. Audio Interfaces to use for PCM: WASAPI Exclusive. PCM Output Format: 24 bit int padded to 32 (this depends on the audio device).
4. Playing back BD movie/M2TS/MKV with MPC HomeCinema.
MPC HomeCinema is the easiest media player to configure. All what you need are:
- Options > Internal Filters > Source Filters: uncheck "Matroska" and "MPEG PS/TS/PVA", so that LAV Splitter is used for MKV, M2TS and MPLS.
- Options > External Filters: add ArcSoft Audio Decoder HD and set it to "Prefer".
Of course you can add any video decoder in External Filters as well and set it to Prefer if you want to use it. To play a BD disc, File > Open DVD and point to the drive.
5. Playing back BD movie/M2TS/MKV with Zoom Player Home MAX v8.00 (Free and Professional do not support BD movie playback).
In Smart Play, add LAV Splitter for Blu-ray Play List, MPEG-2 Stream and MKV, and ArcSoft Audio Decoder HD for AC3 and DTS. To decode DTS-HD properly, add the following media subtype
Code:
{00002001-0000-0010-8000-00AA00389B71}
in ArcSoft Audio Decoder HD for both AC3 and DTS. Similarly, to decode TrueHD, add
Code:
{4288B843-610B-4E15-A53B-43007FCFF614}
for AC3. This is because Smart Play of Zoom Player supports only media subtypes stored in the configuration and you have to add these uncommon media types used to connect to ArcSoft Audio Decoder HD manually.
6. Playing back MKV with WMC.
Playback with WMC internal player is practically restricted to MKV. M2TS works by disabling Media Foundation, but you can't select video decoder. BD movie is not supported. Moreover you can't use ReClock so that audio stream is subject to resampling by Windows Audio Engine. Keep these in mind.
First you have to raise the merit value of ArcSoft Audio Decoder HD higher than ffdshow Audio Decoder (0xFF800001). Setting it to 0xFF80000 is enough. Next append ffdshow Audio Decoder (why) by enabling Codecs > Uncompressed: all supported, then select Output > Connect to: DirectSound (untick "Apply only to S/PDIF"). To avoid audio processing by ffdshow, disable all processors and make sure to check all of "16-bit integer" to "32-bit floating point".
7. Checking the filters used.
Use GraphStudio (with proppage.dll and DirectShowSpy.dll). This gives complete information on the filter graph.
8. Checking the output audio stream to the audio device.
- Install MediaInfo. Go to E(the drive letter of the optical drive):\\BDMV\\STREAM and select the largest M2TS file (usually the main title). Right click it and select MediaInfo. You will see the information of the video/audio/subtitle streams.
- Click the ReClock icon in the system tray. ReClock Porperties is opened. Check Audio Stream.
- If sample rate, bit depth, and channel count are the same as those seen in MediaInfo, then perhaps you succeeded in decoding the HD audio track bit-perfect.
The screenshot below is taken when Surround_DTS-HD_MA_7.1.mkv (96kHz 24-bit 7.1 DTS-HD MA audio track) is played back with WMC internal player.
renethx is offline
post #4 of 168 Old 10-22-2010, 09:44 AM - Thread Starter
renethx- thanks for all the info. I haven't had a chance to try everything out, but will as soon as I can free up some time.
Earlier this week, I got a promotional email from Nero for their Nero Multimedia Suite 10 Platinum HD. I use Nero8 as a burning application, but I never install their other stuff because it all seems to be crapware. Has anyone ever tried their program for Blu-ray playback? Does it have the same limitations as TMT3 and PowerDVD?
Gregg Plummer
post #5 of 168 Old 10-22-2010, 10:00 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
In general every AACS-compliant BD player must downsample HD audio to 48/16 if a non-PAP sound device (like yours) is used. It's an AACS requirement and there must not be an exception.
But I have no idea how Nero 10 is.
renethx is offline
post #6 of 168 Old 10-22-2010, 10:47 AM
kegobeer's Avatar
Based on previous experience with the Nero suite, I'd stay away from it. When it comes to playback, PDVD and TMT are the best options.
kegobeer is offline
post #7 of 168 Old 10-22-2010, 11:03 AM
N3W813's Avatar
Quoted: 22 Post(s)
Liked: 70
Renethx, thanks for the detailed post. Couple of questions.
1. In MPC-HC, should I uncheck all the filters under the "Internal Filters" section? To make sure MPC uses only the filters selected in the External Filters section?
2. For MKVs with HD audio, just use the hacked MatroskaSplitter.ax instead? And merge the following into registry?
Code:
"Source Filter"="{0A68C3B5-9164-4A54-AFAF-995B2FF0E0D4}"
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #8 of 168 Old 10-22-2010, 11:19 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Code:
1. No, there is no need to untick all the internal filters. The priority is given in this order:
1. Filter in a higher position in the "External Filters" list that is set to "Prefer".
2. Internal filter of MPC-HC that is enabled.
3. Filter registered and specified in HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\DirectShow\\Preferr ed (can be configured with Win7DSFilterTweaker)
4. Filter registered with a higher merit value.
The "preferred" filter in External Filters (the one in the highest position if there are multiple competing "preferred" filters) is always used as long as its pins are connected successfully even if the competing internal filter is enabled.
2. You don't have to hack the MPC Matroska Source filter (internal/external) to use ArcSoft Audio Decoder HD for DTS-HD decoding. I experimented and confirmed that.
If you use MPC HomeCinema, just make sure that "Matroska" is ticked in Options > Internal Filters > Source Filters. If you use the standalone MPC Matroska Source filter in another DirectShow player (e.g. the 7MC internal player), you may need to merge that value to the registry, or you may be able to specify the source filter for MKV inside the player for some players like Zoom Player.
renethx is offline
post #9 of 168 Old 10-22-2010, 11:56 AM - Thread Starter
A little off topic... but, you'd think they'd accept soundcard->analog out as good as a protected path. The only way to copy the digital signal would be to tap the I2S lines and that would be pretty difficult for 99.9% of the users. Otherwise, you'd have to record the analog signal, which is impossible to stop. Oh well. As for tapping the I2S lines, it would be just as easy to do so with an AVR as it is with a soundcard.
Gregg Plummer
post #10 of 168 Old 10-22-2010, 12:13 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
AACS LA considers PC as an open system. They ask every user-accessible bus, including PCI bus (many sound cards use this bus to get audio streams from the system memory), PCI Express bus, HD Audio bus, to be protected to transmit HD audio streams, otherwise HD audio must be downsampled. This sounds ridiculous, but is a fact.
Moreover not every AACS-compliant BD player supports every PAP sound device. For example, ASUS Xonar HDAV 1.3 supports PAP, but is supported only by TMT.
renethx is offline
post #11 of 168 Old 10-22-2010, 02:25 PM
Nighthog's Avatar
renethx this guide is better than the older one.
I'll add that if you don't want to have TMT3 installed in your system but still have DTS-HD audio decoded you can create a folder anywhere you want and then copy these files into it from the TMT3 installation folder.
ASAudioHD.ax
DtsDec.dll
dtsdecoder.dll
MagCore.dll
MagPCMac.dll
MagUIEngine.dll
MagUIInter.dll
and also the custom version checkactivate.dll
This way can uninstall TMT3 and still have DTS-HD decoded.
Thanks for all the help and awesome guide and "tweaking" skills!
Nighthog is offline
post #12 of 168 Old 10-23-2010, 06:47 PM
N3W813's Avatar
Quoted: 22 Post(s)
Liked: 70
Renethx,
Maybe you can help me. I'm getting a "Audio format not support by this hardware/driver" 48000Hz, 6 channels, 24bit when I'm trying to decode DTS-MA (m2ts and mkv) video files. I've verified that the every step above is done correctly; Arcsoft HD audio codec is from .185, Reclock is 1.8.7.1, and MPC-HC is loading all the correct filters.
Reclock is set to Wasapi exclusive and audio device is set to Nvidia HD Audio. I have installed the lastest Nvidia HD Audio driver (1.1.9.0) from Nvidia's website. I'm using a Nvidia GT240 video card.
My receiver is a HK 254 and definitely can accept up to 24/192 multichannel pcm sources via hdmi.
Any ideas?
Edit
Nevermind, I messed up this step "PCM Output Format: 24 bit int padded to 32 (this depends on the audio device)." :P working now
N3W813 is offline
post #13 of 168 Old 10-29-2010, 05:26 PM - Thread Starter
I finally have a chance to start working on this, but before I try anything I have a few questions. I'm still at the stage where I'm downloading all the necessary files.
The instructions (above in the 3rd post) for Part 1, provide a link for MpegSource.ax. This is actually a link to MpegSplitter.zip and when you extract the files from this you get 'MpegSplitter.ax modified'. Is this what we should use? Or, is this the wrong link? If it is correct, should it be renamed 'MpegSplitter.ax' or 'MpegSource.ax'?
The instructions for registering the '.ax' files include the attachment 'GraphStudio.zip'. This zip file includes 'FilterGraphSpy.dll'. However, it also says to download the latest version of 'FilterGraphSpy.dll' and provides a link that takes you to 'DirectShowSpy.dll'. Are 'FilterGraphSpy.dll' and DirectShowSpy.dll' the same thing (maybe the author renamed it to something more descriptive)?
That's as far as I've gone. I'm not ready to go any further until I know these answers.
Gregg Plummer
post #14 of 168 Old 10-29-2010, 11:24 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Just rename 'MpegSplitter.ax modified' to 'MpegSplitter.ax' and use it.
Use DirectShowSpy.dll instead of FilterGraphSpy.dll.
renethx is offline
post #15 of 168 Old 10-30-2010, 12:02 AM
vladd's Avatar
Liked: 39
Correct, it's just been renamed.
vladd is offline
post #16 of 168 Old 11-01-2010, 10:37 AM - Thread Starter
ASAudioHD.ax
DtsDec.dll
dtsdecoder.dll
MagCore.dll
MagPCMac.dll
MagUIEngine.dll
MagUIInter.dll
My TMT3 installation must be a little different than yours. First, I have already installed TMT3 and the program's installer was an "exe" file (as was the update to v185). How do you find the installation folder?
I can't find many of the files listed above in the ArcSoft codec folder.
These files don't exist in my TMT3 installation and they don't come up after performing a Windows search:
MagCore.dll
MagPCMac.dll
MagUIEngine.dll
MagUIInter.dll
And, 'dtsdecoder.dll' was actually named 'dtsdecoderdll.dll' on my system.
What version of TMT3 were you using? I originally purchased v180, which is the current version you get after choosing the BUY button. Then when you run TMT3, you are prompted to upgrade. The upgrade takes you to v185.
Thanks for your help!
Gregg Plummer
post #17 of 168 Old 11-01-2010, 11:04 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The installation folder Nighthog means is
All Mag...dll files are located in this folder.
You first install TMT3, update it to 185, copy the necessary files in another location, then uninstall TMT3. But if you are going to use TMT3, you don't have to do this.
renethx is offline
post #18 of 168 Old 11-01-2010, 11:36 AM - Thread Starter
I'm not having much luck. I'm not sure if this is critical in this situation, but when I try to register 'DirectShowSpy.dll' (using InstallFilter.exe as described in the linked post) I get an error that says it couldn't load the file. However, the older 'FilterGraphSpy.dll' does register. I was also able to register 'MpegSplitter.ax'.
I'm not sure what you mean by "Merge the following in the registry:" I ran regedit and navigated to 'Computer\\HKEY_CLASSES_ROOT\\Media Type\\Extensions\\.m2ts' and saw that "Source Filter"="{1365BE7A-C86A-473C-9A41-C0A6E82C9FA3}" is there. I confirmed with GraphStudio that the CLSID listed for 'MPC - Mpeg Source (Gabest)' was the same. BTW, I'm running W7 64-bit, if that makes any difference, so I actually ran 'graphstudio64.exe'.
I also edited my 'win.ini' file. However, the choices for AudioOutputMode shows "6,13: 5.1 Channels". Does this mean you can enter AudioOutputMode=6 or AudioOutoputMode=13 or do you just use AudioOutputMode=6,13?
I registered both ASAudioHD.ax and ASVid.ax, but when I try setting the external filter for MPC HomeCinema to 'ArcSoft Audio Decoder HD', I can't find 'ArcSoft Audio Decoder HD' or any other ArcSoft filter in the list.
Thanks again for your help, I really appreciate it.
Gregg Plummer
post #19 of 168 Old 11-01-2010, 12:29 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Here is a new list of the minimum DLLs to use ArcSoft Audio Decoder HD (and ArcSoft Video Decoder) of TMT3.
If you don't want to keep the entire TMT3, you can copy only minimum DLLs from the folder C:\\Program Files\\ArcSoft\\TotalMedia Theatre 3\\Codec as in the following:
1. Install TMT3.
2. Update it to 185 (this is important to assure 24-bit audio output).
Here is a link to
ArcSoft TotalMedia Theatre 3 Platinum 3.0.1.185 Trial in case you can't find it (Trial is enough of course).
3. Create a new folder, say, C:\\ProgramData\\ArcSoft Codec. Copy
- ASAudioHD.ax (if you want to use ArcSoft Audio Decoder HD)
- ASVid.ax (if you want to use ArcSoft Video Decoder)
- checkactivate.dll (the critical file to use ArcSoft codecs outside TMT3)
to the new folder. Register ASAudioHD.ax and ASVid.ax.
4. This is an important step to get ArcSoft Audio Decoder HD to output LPCM audio streams with correct channel count, sample rate and bit depth. Open the file win.ini located in C:\\Windows with Notepad. Add the following lines at the end and save it (you may have to save it in another location, then copy and paste it).
Code:
AudioOutputMode=17
AudioDynamicRange=1
Code:
AudioDynamicRange:
0: Light
1: Normal
2: Threaded
AudioOutputMode:
0,1,2,5: Stereo
6,13: 5.1 Channels
17: 7.1 Channels
16: S/PDIF
5. ASAudioHD.ax and ASVid.ax are not enough to decode various codecs. Copy the following DLLs to the folder C:\\ProgramData\\ArcSoft Codec:
- Ac3HDDecoderDll.dll for AC3/TrueHD
- DdpDec71.dll for Dolby Digital Plus
- dtsdecoderdll.dll for DTS/DTS-HD
- ASH264Vid.dll for H.264
- ASVC1Vid.dll for VC-1
- ASMPEGVid.dll for MPEG-2
The total folder size is only 5.3MB.
6. Uninstall TMT3.
Alternatively just download:
ArcSoft Codec.zip that includes all 9 files (checkactivate.dll, ASVid.ax, ASAudioHD.ax and all six ArcSoft dlls), unzip it place it in an appropriate place (I prefer C:\\ProgramData), the register ASVid.ax and ASAudioHD.ax and you are done.
renethx is offline
post #20 of 168 Old 11-01-2010, 12:44 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
@greggplummer
Apparently something is fundamentally wrong. Let me check with 64-bit OS...
renethx is offline
post #21 of 168 Old 11-01-2010, 01:36 PM
vladd's Avatar
Liked: 39
@greggplummer: The ArcSoft decoders are 32 bit only so they will not show up in 64 bit apps. You would need to use 32 bit for GraphStudio, MPC-HC, DirectShowSpy, etc.
vladd is offline
post #22 of 168 Old 11-01-2010, 04:23 PM - Thread Starter
Thanks vladd, that helped a lot. After following these instructions, but making sure I used the 32-bit versions, I was able to see the ArcSoft filters listed as external filters for MPC HomeCinema.
I continued with the instructions and installed ffdshow and ReClock.
Gregg Plummer
post #23 of 168 Old 11-01-2010, 04:42 PM - Thread Starter
I've played several BD discs. I have AnyDVD HD installed and I'm using the 32-bit version of MPC HomeCinema. Here are the results:
Harry Potter and the Half Blood Prince - no menus, no sound, video good
Filters -
Analog out 1-8 (AudioFire 8)
Enhanced Video Renderer (custom presenter)
ffdshow Audio Decoder: Audio - English, Dolby TrueHD, 48.0kHz, 6 chn, 640.0 kbits/s (1100,fd,00) - TrueHD, 5.1, 48000 Hz (libavcodec)
MPC Video Decoder
Planet Earth - no menus, sound good, video good
Filters -
ffdshow Audio Decoder: Audio - English, Dolby Digital, 48.0 kHz, 6 chn, 448.0 kbits/s (1100,fd,00) - AC3, 5.1, 48000, 448 kbps (liba52)
MPC Video Decoder
Shine A Light (Martin Scorsese's Rolling Stones film) - no menus, sound good, video good
Filters -
MPC Video Decoder
I've also generated a filter graph of the Harry Potter BD using GraphStudio and attached the screen capture to this post.
As you can see these results are pretty promising. I'll be very happy once I get this working with TrueHD. I'd also really like to be able to navigate these disc with the menus and possibly play some of the special features, etc.
Gregg Plummer
post #24 of 168 Old 11-01-2010, 11:13 PM
vladd's Avatar
Liked: 39
Not going to happen (for a long time) unless you use a commercial player like TMT/PDVD/WinDVD
vladd is offline
post #25 of 168 Old 11-02-2010, 12:43 PM - Thread Starter
Filters -
MPC Video Decoder
Does anyone know why I can't hear any audio when playing a Blu-ray with the Dolby TrueHD track?
Gregg Plummer
post #26 of 168 Old 11-02-2010, 12:44 PM - Thread Starter
Maybe the Slyplayer???
Gregg Plummer
post #27 of 168 Old 11-03-2010, 12:50 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Are you sure ffdshow is connected? (Right-click the screen, then click Filters.) If the title includes several audio tracks with the primary audio track DTS/AC3/LPCM (then ArcSoft Audio Decoder HD is connected) and the secondary audio track TrueHD, then you will hear no sound when you select the TrueHD track because ArcSoft Audio Decoder HD + MPC Mpeg splitter does not support TrueHD. You have to use LAVFSplitter. LAVFSplitter + ArcSoft Audio Decoder HD supports AC3, TrueHD, DTS, DTS-HD fine. To use it, register it, set it as the default M2TS (and MKV) source filter by merging:
Code:
[HKEY_CLASSES_ROOT\\Wow6432Node\\Media Type\\Extensions]
(Wow6432Node is specific to 32-bit applications in Windows x64; {55DA30FC-F16B-49fc-BAA5-AE59FC65F82D} is GUID of lavf dshow source filter) and untick MPC-HC's internal MPEG source filter. You lose "Open DVD" in MPC-HC, however.
Another option is SageTV Media Center V7. The internal Mpeg splitter supports ArcSoft Audio Decoder HD as well as ffdshow audio decoder. You can even navigate through titles in a BD folder/BD ISO/BD in an optical drive ("BD Tilte Select"; but perhaps you have no idea which title is which without menu).
renethx is offline
post #28 of 168 Old 11-03-2010, 10:08 AM - Thread Starter
Well, I finally got it to work with Dolby TrueHD. I think it had something to do with ReClock. When I installed ReClock v1.8.7.1, I used the recommended settings in post #3. However, my audio device driver doesn't support WASAPI Exclusive, so I set it to DirectSound instead.
At first, I got audio and video, but it played very slowly, so the sound was very distorted and the video choppy. Then something changed and I was able to get smooth video playback with no sound.
I messed around with ReClock and was back to slow, choppy video and audio. I tried numerous combination of settings and it didn't make any difference. I couldn't even get it back to smooth video with no audio.
I tried uninstalling and re-installing ReClock, but still no luck. Finally, I checked the Advanced tab and tried checking 'Force ReClock to be loaded instead of default renderers'. I am almost positive this was set prior to uninstalling. Anyhow, this did the trick. I can now play BD discs with Dolby TrueHD, DTS-HD, DD and hopefully any other audio codec.
Thanks for all your help. Since I own a license to SageTV v6.5, I may try upgrading and give it a try to get some navigation capabilities. I have a BD disc (Sherlock Holmes) that doesn't have the feature film as the main title. Instead , you get a special feature with the Director and there's no way to navigate to the feature. With 'Another EAC3to GUI' you can preview and choose the correct title before ripping, so I'm able to play the feature only if I rip this BD.
Gregg Plummer
post #29 of 168 Old 11-03-2010, 02:55 PM - Thread Starter
Now I need to figure out how to play a BD disc within W7 Media Center.
Gregg Plummer
post #30 of 168 Old 11-03-2010, 03:27 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
7MC internal player does not support the BD structure. You have to select a M2TS file manually in the folder U (or whatever):\\BDMV\\STREAM. Moreover, 7MC internal player in Windows 7 x64 is a 64-bit player, so you can't use ArcSoft Audio Decoder HD (a 32-bit filter) to decode DTS-HD.
renethx is offline
Reply Home Theater Computers
