AMD Radeon HD 6900, 6800, 6600 etc. Series Thread: Supporting HDMI 1.4a and BR 3D! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 255 Old 12-22-2010, 01:59 AM
micksh's Avatar
In Windows Sound Playback devices, AMD HDMI device, Configure, Speaker setup nothing worked except 7.1 setup. Test sound didn't work, I didn't go further.
This was before I reinstalled the drivers. Now this is irrelevant, every speaker setup can work now. Reinstalling the drivers fixed everything.
micksh is offline
post #92 of 255 Old 12-22-2010, 02:18 AM
Andy o's Avatar
You'll still have the MC sounds problem though, it's a bug. Unless they've fixed this with 10.12, which I don't think they've done.
Andy o is offline
post #93 of 255 Old 12-22-2010, 02:22 AM
micksh's Avatar
What MC sound problem? What did I miss?
micksh is offline
post #94 of 255 Old 12-22-2010, 02:56 AM
Andy o's Avatar
This issue:
Originally Posted by micksh View Post
Today I tried to watch live TV in Media Center and it didn't work.
I get error: Files needed to display video are not installed or not working correctly.
TV starts to show for few seconds, audio gets cycled, and then this error is displayed.
It's fixable by disabling MC menu sounds, or setting the mixer to stereo. Or using the Realtek driver. Although I don't know how that works with the 6000 series, I suspect it works the same as with the 5000 cards.
Andy o is offline
post #95 of 255 Old 12-22-2010, 03:16 AM
jhoff80's Avatar
Quoted: 379 Post(s)
Liked: 334
Originally Posted by Andy o View Post
This issue:
Yes, it works the same way with the 6850.
XBL/Steam: JHoff80
jhoff80 is online now
post #96 of 255 Old 12-22-2010, 03:34 AM
Andy o's Avatar
You mean the Realtek driver?
Andy o is offline
post #97 of 255 Old 12-22-2010, 03:44 AM
micksh's Avatar
But I like MC menu sounds and I don't like setting MC sound to stereo. Digital TV broadcasts in 5.1 and I like to hear it in that way.
It's all working now and I still don't understand what I'm missing. I did have the problem that I reported but reinstalling drivers fixed it in my case. There was no need in Realtek. Everything seems to work now.
micksh is offline
post #98 of 255 Old 12-22-2010, 03:56 AM
Andy o's Avatar
So, you have the Windows mixer set to 7.1, MC menu sounds on, and aren't getting an error when using the 10.12 HDMI AMD driver? Are you bitstreaming Dolby Digital to your receiver when you watch Live or Recorded TV in MC?
Andy o is offline
post #99 of 255 Old 12-22-2010, 04:03 AM
micksh's Avatar
Yes, everything is correct, except that I'm using 10.10e driver. 10.12a would also work in most cases except some blu-ray playback so I reverted to 10.10e.
micksh is offline
post #100 of 255 Old 12-22-2010, 04:14 AM
micksh's Avatar
If that sounds surprising - one thing that could be relevant: I have almost clean Windows 7 installation. Just upgraded from Vista few weeks ago with clean install. Installed Shark007 codecs, TMT3 and very few other programs. x86. 60Hz TV if that's relevant.
micksh is offline
post #101 of 255 Old 12-28-2010, 09:03 AM
imfletcher's Avatar
Hello all
I just picked up a 6850, replacing a 5750 for my HTPC. I have two separate issues, but the one i'm most interested in is this:
My receiver only does HDMI 1.3a, so i can't do full 3D passthrough to my TV (panny P65VT25). The newer 3D bluray players are solving this by having 2 HDMI outputs: 1 for HDMI 1.4 video to the TV, 1 for 1.3 audio to the receiver for TrueHD. This works quite well (i have the samsung C7900 doing just this).
I'm trying to accomplish the same with this card using a DisplayPort->HDMI converter. Ideally i'd be able to do the same as the converter preserves the protected path, etc. It seems i should be able to hook up the TV to one and the receiver to another, and get both video and sound. I can't, however, figure out how to do this. It seems that when i have the TV on the Displayport (via converter), the card will not send audio over HDMI. When i have the TV on the standard HDMI, there is no way to send audio over DisplayPort (despite saying so in the Specs).
Any ideas? I wish the drivers provided more control over the outputs.
On a separate note, using PowerDVD 10 Ultra Mark II, I can't get highdef sound (TrueHD, DTS Master). This worked perfectly on my 5750, but on my 6850 using 10.12, PowerDVD won't even give me the option for nonencoded highdef bitstream. Could be an issue with PDVD, but checking to see if others have this problem.
imfletcher is offline
post #102 of 255 Old 12-31-2010, 12:00 AM
e55
e55's Avatar
Originally Posted by imfletcher View Post
Hello all
Hi, all
I also tried split audio(HDMI1.3) and video(HDMI1.4) of blu-ray3D with HD6870 and succeeded in another way. HDMI1.4 display is JVC DLA-X7 and HDMI1.3 receiver is Integra DHC-80.1. http://monolith-theater.net/hal/?p=11099 (sorry in Japanese but summary and some figures in English)
Because Radeon has only one internal HDMI device under the present situation, split output is not capable,I think.
If the HDMI device, which is recognized in device manager was used for AMD HD3D (1080p 24Hz frame packing 3D video from HDMI connector), other onboard sound device or sound card was needed for audio pass through. So, I reluctantly used HDMI device of VGA(HD5870) as HDMI sound device. I think that HDMI1.4 receiver is better in AMD HD3D for full spec playback.
Moreover, HD5870 on catalyst10.12 cannot pass through HD audio with PowerDVD as you showed. There is no third option ,but second option works fine. It may be the issue due to current catalyst.
e55 is offline
post #103 of 255 Old 12-31-2010, 07:09 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I think it is time to replace my X3870
Mfusick is offline
post #104 of 255 Old 12-31-2010, 09:23 AM
imfletcher's Avatar
It actually is sorta possible, but you have to do things a certain way
First, you have to uninstall the ATI HDMI Audio drivers, and install the audio drivers directly from realtek.com. This will allow PowerDVD to see it and passthrough TrueHD, etc.
Second, you have to hook up one at a time. I did DisplayPort to Receiver (via DP->HDMI adapter), got the audio working and made sure everything was fine. Then, i plugged the TV directly into the HDMI and put the desktops on Clone (it thinks it has 2 monitors, the receiver and the tv). The audio remained on DisplayPort while the Video went to both, so you can choose to use the one through the receiver or direct through TV. I can't confirm the last bit though, because despite their claims, PowerDVD won't do 3D on the ATI 6800 series, although they claim a patch is on the way.
post #105 of 255 Old 12-31-2010, 07:49 PM
micksh's Avatar
Why don't you use 10.10e driver? It is known that 10.12 broke PowerDVD HD audio, just check Catalyst 10.12 thread.
Maybe it broke 3D too, I don't know as I don't have 3D TV. 10.10e works fine for me, though. No need in Realtek. It seems to be more stable than 10.12a.
micksh is offline
post #106 of 255 Old 01-01-2011, 02:57 PM
imfletcher's Avatar
I tried to go back, but it seems 10.12 is the first version to support the 6800 series of video cards (i have a 6850)
post #107 of 255 Old 01-01-2011, 03:08 PM
jhoff80's Avatar
Quoted: 379 Post(s)
Liked: 334
The 10.10 hotfixes (aka 10.10e, 10.10d, etc.) support the 6800 series. They do not support the 6900 series.
However, the 10.12 drivers fix DXVA acceleration for SD content as well, so you might not want to go back to 10.10.
XBL/Steam: JHoff80
post #108 of 255 Old 01-01-2011, 07:53 PM
Bob7145's Avatar
Liked: 36
Maybe 10.12a works? It shows in device manager as 10.11
http://support.amd.com/us/kbarticles...12ahotfix.aspx
Driver Packaging Version 8.79.6.2-101215a-110532E
Catalyst Version 10.11
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1094
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0001
Direct3D Version 8.14.10.0795
OpenGL Version 6.14.10.10315
Catalyst Control Center Version 2010.1215.2136.38682
Bob7145 is offline
post #109 of 255 Old 01-02-2011, 09:23 AM
SAVholic's Avatar
My WEI got down to 6.6 from 7.8 since the 10.12 on my 6850...I know the rating is meaningless but I'm curious if anybody is experiencing this, re-installing the ccc does not "fix" this.
"My English is not very good looking" - Celia Cruz
SAVholic is offline
post #110 of 255 Old 01-02-2011, 06:36 PM
nijel8's Avatar
Disable MorphoLogical AntiAliasing.
nijel8 is offline
post #111 of 255 Old 01-02-2011, 07:11 PM
SAVholic's Avatar
Thanks! Just did that and my WEI went back up to 7.8... and my avg. FPS in L4D2 went from ~80 to ~120+
SAVholic is offline
post #112 of 255 Old 01-03-2011, 06:13 AM
mariner888's Avatar
DXVA playback of 1920x2160/60p and 3840x1080/60p video
Greetings everyone.
I'm thinking of upgrading from the 5670 to something that will provide smooth DXVA playback of 1920x2160/60p and 3840x1080/60p H264 video. These are 3D top/bottom and side-by-side encode of Panasonic x700 camcorder 1920x1080/60p clips. Would appreciate if you could kindly provide screen cap and decoder used in testing.
The 5670 could not handle the raw L4.2 Panasonic clip smoothly. It would be interesting to see if the new UVD 3.0 could do better.
No 3D TV is required for testing, a single normal display is sufficient. For those with dual display hooked up, you could use the Eyefinity feature to create 1920x2160 or 3840x1080 desktop spanned across two displays.
Description: 3840x1080/60p 2Dto3D Side by Side L4.1
http://www.sendspace.com/file/9ty5jh
Description: 3840x1080/60p 2Dto3D Side by Side L4.2
http://fs04u.sendspace.com/processupload.html
Description: 1920x2160/60p 2Dto3D Top/bottom L4.2
http://www.sendspace.com/file/owupa4
Description: 1920x1080/60p 2Dto3D Top/bottom L5.1
http://www.sendspace.com/file/hnw7q9
Description: 3840x1080/60p 3D Side by Side L5.1
http://www.sendspace.com/file/e7h9yu
File name: 20100314_141414.m2ts
File description: Ginza Cat, raw Panasonic x700 1920x1080/60p mts L4.2
File size: 158.2 MB
http://www.megaupload.com/?d=3EBAWEWN
Many thanks for testing.
2Dto3D_h.txt 2.6689453125k . file
mariner888 is offline
post #113 of 255 Old 01-03-2011, 11:12 PM
micksh's Avatar
Are 68xx even supposed to have DXVA for H.264 level 5.1? I don't think so. I think only NVidia enabled DXVA for high profile level 5.1 recently.
Anyway, DXVA didn't work. Tried in MPC-HC (all internal filters) and PowerDVD 10. Video works but CPU usage is too high. TMT 3 gave blue screen (I never watch MKV in it actually). Sapphire 6850, 10.10e drivers, Single 2D HDTV.
micksh is offline
post #114 of 255 Old 01-04-2011, 05:38 AM
mariner888's Avatar
Greetings micksh. Many thanks for testing.
The UVD2 in 5670 could not playback the raw 1920x1080/60p L4.2 Panasonic clip smoothly in DXVA. Did the new UVD3 in 6x cards resolve this issue?
I've also posted a new L4.2 encode of the 1920x2160 top/bottom clip for your kind testing. Best regards.
post #115 of 255 Old 01-04-2011, 02:10 PM
Bob7145's Avatar
Liked: 36
Read thru the entire thread and noticed no one mentions you CAN play 3DBD with a 5xxx card. I bought a 6970 when purchasing a 120Hz 3D projector but tested it 1st with the 5870 before installing the 6970. Worked just fine in PDPD10 3D with hdmi 1.3 cable. The limiting factor seams to be the HDTVs. BR may be fine @ 24-30Hz but certainly not for gaming in 3D on an HDTV. Anyway, I bought a 6970 and turned out I did not need it. Gaming in 3D is awesome!
Bob7145 is offline
post #116 of 255 Old 01-05-2011, 01:14 AM
micksh's Avatar
OK. That level 4.2 file worked with DXVA.
DXVA didn't work in MPC-HC and PowerDVD 10 but it worked fine in ffdshow and TMT3.
On HTPC with HD6850 I have Core 2 Duo 3GHz (E8400). CPU usage was
60% - MPC-HC (internal video filters)
100% - PDVD 10
15% - WMP (ffdshow DXVA)
5% - TMT 3
For the previous 2 files (I tried only 2 first) I got the same CPU usage in MPC-HC and PDVD 10 but TMT3 and ffdshow didn't work at all. UPDATE: ffdshow actually worked. It appeared that I need to load some good file to WMP first, then it would play your files. Without DXVA though, 100% CPU usage. If I load your file first, WPM crashes.
I also have Geforce GTS 240 with latest drivers on desktop and I tried these. I don't have any blu-ray player installed but I can tell that none of these files worked in ffdshow and MPC-HC. Just black screen in MPC-HC. The only way I could play these was through VLC Player, with high CPU usage.
PS. Maybe I was wrong about level 5.1 DXVA. It looks like AMD video cards should support AVC profile 5.1. There is probably some limitation on frame size - your files have double frame size.
PS2. On both PCs I have DXVA working fine in every program for every level 4.1 1080p video. Latest stable ffdshow build from December.
micksh is offline
post #117 of 255 Old 01-05-2011, 06:00 AM
mariner888's Avatar
Final piece of the puzzle
Below is the L4.2 encode of 3840x1080/60p side-by-side 3D video for your testing.
Here is a summary of your test results so far:
1. UVD3 does not support DXVA playback of 3840x1080/60p and 1920x2160/60p L5.1 H264 video 700_v_2D3D.mkv and 700_h18.mkv.
2. UVD3 supports smooth DXVA playback of 1920x2160/60p L4.2 H264 video 700_vL42_2D3D.mkv.
3. UVD3 supports smooth DXVA playback of raw Panasonic 1920x1080/60 28mbps L4.2 video 20100314_141414.m2ts.
4. 3840x1080/60p L4.2 video 700_hL42_2D3D.mkv?
Let me know if this is correct. Kindly post screen cap and indicate player/decoder used.
Many thanks and best regards.
http://www.sendspace.com/file/1d3ivb
post #118 of 255 Old 01-05-2011, 07:14 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
This is a well-known (kind of) fact: Confirmed fix for ATI 5000 series 120hz page flipped 3d output. HD 6xxx is still necessary for HDMI 1.4a 3D video formats (this is not your case of course).
renethx is offline
post #119 of 255 Old 01-05-2011, 11:34 AM
Bob7145's Avatar
Liked: 36
Thanks, well that would have saved a little experimentation had I read that thread! Don't normally search HTPC threads for 3D gaming ha ha. Not unhappy though. Moved the 5870 to rescue a 4870 CF rig that 1 card died in. Only problem so far is running an 3 x 1 60Hz Eyefinity group and a 120Hz projector at the same time. If I let it run long enough it will Blue Screen.
Bob7145 is offline
post #120 of 255 Old 01-05-2011, 11:51 AM
micksh's Avatar
That's correct. Decoder is ffdshow, beta 7 from December, ffmpeg-mt, used in Windows Media Player. Also whatever TMT3 is using internally. I will post a screenshot.
#3 - Standard resolution L4.2 worked on both PCs in every program with DXVA.
#2 - It's interesting that it looks like AMD HD6800 has an advantage over NVidia here. I believe GT 240 has the most recent NVidia engine - VP4, yet it could not show 1920x2160/60p L4.2 video with DXVA (neither could 5670, I understand) but 6850 could. At least in ffdshow; later I will install TMT3 on desktop and test.
#4 - you posted wrong link - processupload.html
micksh is offline
Reply Home Theater Computers
