AMD Radeon HD 6900, 6800, 6600 etc. Series Thread: Supporting HDMI 1.4a and BR 3D! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 255 Old 04-21-2011, 02:41 AM
Ender17's Avatar
Originally Posted by renethx View Post
Yes, you can save ~5W at idle/video playback by going from 5570 to 6670.
do you consider it an upgrade for 2D?
Ender17 is offline
post #182 of 255 Old 04-21-2011, 02:31 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
HD 5570 ➝ HD 6570 is an upgrade in every respect.
renethx is offline
post #183 of 255 Old 04-24-2011, 01:10 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #184 of 255 Old 05-09-2011, 02:11 PM
cybrsage's Avatar
Liked: 154
Since the price of a DDR5 6570 is nearly the same as a 6670, the 6670 seems the obvious choice. But I wonder if the DDR3 6570 can do everything it needs.
I know the 54xx had a load of troubles due to it being too weak. Will we run into the same issue with the DDR3 version of the 6570? I cannot find HTPC friendly reviews of the DDR3 version...only DDR5.
cybrsage is offline
post #185 of 255 Old 05-14-2011, 08:39 AM
kkrull's Avatar
Originally Posted by jakmal View Post
I wish there was a fanless 6570 out there.. None on Newegg as far as I could see..
I bought the HIS Silence 6570 at Newegg. Silent obviously. Puts off much less heat - my case fans spin much lower. Unfortunately the back side heatsink was so big I had to trim a millimeter off to clear one of the big motherboard sinks. The HIS box had stickers over the HDMI 1.4a logos, so it looks like either the 3D or the audio return channel are not yet functional. I hope it is the former. Or that a firmware update gets the card to 1.4a.
I am not sure how the DDR3 affects the performance. My windows experience graphics index is 6.8 and my previous bluray stuttering issues are gone. Also no currupt mouse cursors as of yet (http://hardforum.com/showthread.php?t=1561381) I am starting to think the currupt cursor issues are thermal.
To use this card I gave up a displayport that I would have liked to have kept, but there are no fanless 6570 full height cards yet. Also I plan to mod the card for the HDMI-CEC support (http://valkyriemt.wordpress.com/2010...o-extra-wires/). Interestingly this card does not have solder holes for the hdmi pins so it will tax my skills to put a wire on the back of the connector before it reaches the daughterboard.
kkrull is offline
post #186 of 255 Old 05-15-2011, 04:09 AM
Eiffel's Avatar
Quoted: 13 Post(s)
For what it's worth, I recently replaced a passively cooled Nvidia GeForce 8600 GT by a Sapphire 6670 and must say that the new card is very quiet (and runs much cooler).
The noise level from the new video card at idle is lower than what comes out of my power supply (Seasoninc S12-II bronze 430w).
Now, if I could get this card to work with MPC-HC 64 on HD materials this would be perfect (Since I did the upgrade, MPC-HC refuses to go past opening some of this files and uses up 50% of my CPU!)
Eiffel is offline
post #187 of 255 Old 05-16-2011, 08:12 AM
mick1's Avatar
Can anybody teach me how to bitstream DTS HD and true HD out of ati6850? I was trying to use PotplayerX64 with (dts-hd MKV.) and Powerdvd 11 (Full RIP) but still the best I can do is DTS only. I don't think it's not AVR problem because in the potplayer,it show DTS logo only. BTW I set passthrough DTS-HD and True HD in potplayr already.
Do I need 1.4a HDMI cable?
mick1 is offline
post #188 of 255 Old 05-16-2011, 08:14 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Here is how to do with MPC HC and FFDShow (at some point i will update for LAV)
http://www.mediasmartserver.net/2010...7-htpc-part-i/
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #189 of 255 Old 05-16-2011, 02:46 PM
kkrull's Avatar
What driver version are you using?
kkrull is offline
post #190 of 255 Old 05-16-2011, 05:19 PM
Eiffel's Avatar
Quoted: 13 Post(s)
I'm using the latest catalysts (11.5).
I'm not sure what causes the issues I'm experiencing... With MadVR, ffdshow, reclock and MPC-HC 32 bits, I get decent results (some .ts files do cause problem, and my E3400 CPU needs a bit of help), but with the default MPC-HC settings things were much worse.
Eiffel is offline
post #191 of 255 Old 05-17-2011, 11:36 AM
jakmal's Avatar
Not sure if this is the right place to ask, but does CCC have a place where I can create refresh rates with custom timing parameters ? ( the ones in this post: http://www.avsforum.com/avs-vb/showt...7#post16058257 ).
Ganesh T S
Sr. Editor, AnandTech Inc.
jakmal is offline
post #192 of 255 Old 05-17-2011, 01:54 PM
Ricanmeng's Avatar
Eiffel,
I had the same issues with Catalyst 11.5 and my 6870 with MPC-HC on mkv files. Try toggling the transform filter for mkv on and off, or disable it via the unchecking the box and install haali media splitter and disable the auto use of windows media player in its configurations. It was driving me nuts.
Ricanmeng is offline
post #193 of 255 Old 05-24-2011, 01:36 AM
jakmal's Avatar
Has anyone using a 6xxx ATI card successfully got an interlaced VC-1 clip to play back with EVR renderer? I am specifically looking for a setup where the decoder uses DXVA2.
If you have any graph fitting this criteria, please let me know! Thanks!
Ganesh T S
jakmal is offline
post #194 of 255 Old 05-24-2011, 02:15 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Which video container? For MKV, LAV Souce Splitter is the only splitter that guarantees smooth playback of interlaced VC-1. ArcSoft Video Decoder (how to use it outside TMT) and CyberLink Video Decoder are the only video decoders that supports DXVA2 + interlaced VC-1.
renethx is offline
post #195 of 255 Old 05-24-2011, 02:28 AM
jakmal's Avatar
renethx, Thanks for the reply. Andrew (babgvant) sent over some graphs using the ArcSoft codec, but that was on a Sandy Bridge system.
I am trying to get DXVA Checker to show any decoder with EVR (DXVA2) as supported for an interlaced VC-1 stream in M2TS container. (Can shift to MKV if necessary, but that didn't seem to help). As you saw on the other thread, this has to be on one of the recent AMD or NVIDIA cards.
Edit: LAV CUVID in MPC-HC reports itself as using DXVA in MPC-HC, but DXVA Checker shows the decoder as unsupported (not surprising).
Ganesh T S
jakmal is offline
post #196 of 255 Old 05-24-2011, 03:26 PM
Eiffel's Avatar
Quoted: 13 Post(s)
Originally Posted by Ricanmeng View Post
Eiffel,
Build 1.5.2.3145 of MPC-HC (32bits) did resolve my problems and I can now play everything I want with good success on my e3400/Sapphire 6670 system/LAV/ffdshow/MadVR.
This includes DVDs (PAL and NTSC), US and UK HDTV (1080i and 720p) as well as blu rays.
My system struggles when I add reclock as my CPU lacks a bit of horsepower, but everything else works fine (including audio decoding and analog playback).
Eiffel is offline
post #197 of 255 Old 05-28-2011, 03:33 PM
Desert Pilot's Avatar
Quoted: 54 Post(s)
Liked: 36
Hi all,
Built my current HTPC in 2009. I am looking to upgrade and eliminate my soundcard. Right now, I can bitstream DTS Master and Dolby True HD Audio to my receiver. I want to also bitstream music (hi rez multi channel WMA Lossless, WAV or FLAC) to my receiver and let the receiver do the decoding (DAC).
Current System: Core i7 system. Using SAPPHIRE VAPOR-X Radeon HD 4890 video card -- hdmi to -- ASUS Xonar HDAV1.3 Slim -- hdmi to my receiver. Arcsoft Total Media Theater Ver 5 playing Blu Ray .iso files.
It appears to me that by upgrading to the current line of video cards, I can eliminate the audio card and bitstream BD audio codecs directly to my receiver from the video card. Correct?
How about music files? I currently use either Windows Media Player or Foobar. Can I bitstream these files to my receiver?
Marcus
Desert Pilot is offline
post #198 of 255 Old 05-28-2011, 10:16 PM
vladd's Avatar
Liked: 39
WMA Lossless: If your receiver supports it, you should already be able to do this. It should show up as a supported format in the PC's audio device.
WAV: PCM data so technically you are already bitstreaming them.
FLAC: AFAIK, no reciever supports decoding of FLAC except through DLNA streaming or plugging in a USB storage device. You cannot bitstream FLAC via any inputs (HDMI, S/PDIF).
vladd is offline
post #199 of 255 Old 05-29-2011, 12:10 PM
SleepWalker2's Avatar
Hi,
Did you try MPC-HC? I have a 6850 and I did yesterday. Very nice to use Ctrl-J to see the perfect 23.976fps in action
However I have one big problem with it: I've set my default resolution to 720p at 59hz since this is what is optimal to watch TV from my Colossus card. So, after installing MPC-HC I've set it to automatically play full screen and to auto switch to 1080p at 23hz. I went on a mkv file and right-clicked on it to open with MPC-HC. The movie started playing as a 1280x720 "box" on the upper left corner of a 1920x1080 screen ???
It drive me nuts, having the right hardware to play perfect 24fps is one thing but to make it easy to use is another. I also tried AutoFrequency but with this one the frequency doesn't get back to 59hz if lauched from a resolution under 1080p.
I'm a bit desperate to find a way to play MKV files with auto freq switching. Same for BD ISO files that I want to play with TMT5 but again with some kind of auto frequency switching.
SleepWalker2 is offline
post #200 of 255 Old 05-30-2011, 05:02 AM
Eiffel's Avatar
Quoted: 13 Post(s)
Has anyone noticed tearing when using these cards with displays in clone mode?
Watching any kind of video with WMC7 or MPC-HC+LAV+ffdshow+MadVR+Reclock, I do get some very annoying tearing on my projector (but no issue on the LCD monitor) when in clone mode.
This seems to be independant of the refresh rate of the displays, or of the renderer, so I suspect this is an issue with the card or its drivers (I'm using Catalyst 11.5, without hydravision, if this matters).
I should also mention that I never experienced such a thing with my old video card (Geforce 8600 GT)
-- BTW, the improvement in PQ from using MPC over WMC7 is well worth the effort when watching SD TV... going back to WMC7, everthing seems so flat/soft!
Eiffel is offline
post #201 of 255 Old 06-14-2011, 02:25 PM
mikek753's Avatar
hi all,
I use 6870 in my htpc and prev nvidia gt240 wake up from sleep mode S3 just fine
when I replaced with hd 6870 I got blank / black screen only after S3
for now I forced to use S4 - hibernate, but this uses 8 GB hdd / sdd for hiberfil and takes far more time to wake up from S4 vs S3
I already reinstalled Win7 64 and use ati 11.5 drivers
nothing helped so far
any one have S3 with 6870 / 50 ?
thanks.
mikek753 is offline
post #202 of 255 Old 06-14-2011, 06:37 PM
Quoted: 54 Post(s)
Liked: 36
VLADD,
Thanks for the encouragement. I deleted my sound card, reinstalled CCC 11.4 to include the HDMI driver, hooked the video card directly to my receiver and - whoaa - perfect! Multi mchannel hi-rez audio. What an improvement in SQ over going through the sound card.
Tried a BD disk and no go on the hi-def codecs (as I suspected). Guess I will have to upgrade to a 6000 series card to get the BD hi-rez codecs to play again.
Thank you
Marcus
post #203 of 255 Old 06-14-2011, 07:32 PM
vladd's Avatar
Liked: 39
Np.
vladd is offline
post #204 of 255 Old 06-21-2011, 01:07 PM
rgladiator's Avatar
Originally Posted by mikek753 View Post
hi all,
thanks.
It's a "known issue" with AMD cards. I have a 4670 that does the same thing. Lots of people have brought it up but I don't think AMD has officially acknowledged it. Open a support issue with AMD to add pressure. My understanding is it may be hardware specific. I didn't have the problem until I upgraded my motherboard. My last one didn't have the problem. I haven't tried the new 11.6 drivers yet. Also, the workaround for this is when you get the blank screen, put your system back to sleep and wake it up again. This has always worked for me.
In college I learned the two answers to any question my boss ever asks. "It depends..." and "Given enough time and money..."
rgladiator is offline
post #205 of 255 Old 06-28-2011, 07:52 AM
bargervais's Avatar
Quoted: 1555 Post(s)
Liked: 923
just to let you know i just got a radeon hd 6850 to get hd audio put it in my computer still no hd audio i thought i had a 1.4 hdmi cable so i replaced it with one i knew was 1.4 with return audio and there it is true hd. so after months with cyberlink unistalling driver getting latest driver realtek ati hdmi drive everything looked right it was the hdmi cable all along i think i spent 300 dollars upgrading my video card upgrading my cpu and all it was was that hdmi cable
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-NR 747 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
post #206 of 255 Old 06-28-2011, 09:32 AM
IsgiInet123's Avatar
have a big problem, need help :
I cant play 3D BLuray in FULL HD MODE from my HTPC its only 1776x1000 and I have Radeon 6450 and hdmi1.4a cable.. pls help thx
IsgiInet123 is offline
post #207 of 255 Old 06-28-2011, 11:25 AM
When you are in windows desktop, what resolution are you using, can you set 1920x1080? When you do, does your desktop fill your screen perfectly?
What BD player are you using?
post #208 of 255 Old 06-29-2011, 10:20 AM
bargervais's Avatar
Liked: 923
do you have the lastest update for catalyst and the ati realtek hdmi driver
i thought i had the right hdmi cable then i bought this one Mediabridge Ultra Series - High Speed HDMI Cable with Ethernet - Category 2 Certified - Supports 3D & Audio Return Channel [Latest HDMI Version Available] - (10 Feet)
and life was good again
post #209 of 255 Old 07-06-2011, 08:19 AM
Quoted: 54 Post(s)
Liked: 36
Just asking...
Hi. All I want to know is what my system is doing with my music files? Sorry for the dumb question.
I just purchased a Sapphire Tech Vapor-X 6870 Video Card (to replace my 4890 card). This should give me HiDef audio (DTS MA or DD True hd) bitstreaming of my ripped Blu-Ray discs. Blue light goes on in my pre-pro and all is good.
I have a lot of multi channel (5.1) music ripped as well. Many are in WMA 9.2 Lossless format (96K, 24bit, 5.1 channels) and the rest are PCM-WAV format (96K, 24bit, 5.1 channels). I will be using ATI CCC 11.6 with Windows 7, 64 bit. The video card HDMI device is displayed as my windows playback device. It is configured for 5.1 and tests good. Properties are set for up to 192K and 24 bit and this tests good too.
Using ether Windows Media Player or foobar, my assumption is that these programs are taking the WMA or WAV file and sending it via HDMI to my Pre-Pro as PCM data. The Pre-Pro is then using its DACs to convert the PCM data to analog. Is this correct?
Marcus
post #210 of 255 Old 07-07-2011, 03:13 PM
dvh99's Avatar
since i do not get an answer in a topic i started i will ask my question here.
will i be able to use an advanced timing menu with a hd6870 and new catalyst software where i can set all porch settings like i do now with my ati hd4890 and powerstrip?
do the new nvidia cards like gtx460 or 470 provide this option?
thanks,
dennis
dvh99 is offline
Reply Home Theater Computers
