TotalMedia Theatre 5 - Page 123 - AVS Forum
post #3661 of 3674 Old 02-20-2014, 10:10 AM
dbailey75's Avatar
Liked: 33
I'm using a GT430 with TMT 5, and unless I check play all 3d in 3d, it stays at 59.9xx, using the MCE Plug in that is, but if I check the 3d, it will play every BD at 23.9XXX, no matter if it's 3d or 2d, so keep it set to for 59.9XX, and make changes only when watching 3d, as I will get random frame jumps when play 2d BD at 23.9XX, not to bad, but 59.9XX is much smoother.
PSN: CAPTDANMAN
dbailey75 is offline
post #3662 of 3674 Old 02-20-2014, 12:27 PM
Roussi's Avatar
That's enlighening to me, thanks. Now only if you know why with Hardware Acceleration checked, I get no video from MVC (BR3D) sources; only the 3d menus and non-3d videos work. Works fine without HA, but then why did I pay big bucks at the time to have MVC HA'd/decoded?
Roussi is offline
post #3663 of 3674 Old 02-20-2014, 01:02 PM
dbailey75's Avatar
Liked: 33
Make sure you set up the 3d vision in the nVidia control panel.
PSN: CAPTDANMAN
post #3664 of 3674 Old 03-21-2014, 12:59 PM
magicj1's Avatar
Can anyone help me out here. I have just installed an AMD Radeon R7 260X GPU in my PC. Now when I try playing 3D movies through TMT 5 the colour is all wrong.
photo1.JPG 35k .JPG file photo2.JPG 35k .JPG file
The first Pic show's just before I press play, as soon as I press play the colours change.
Any ideas?
magicj1 is offline
post #3665 of 3674 Old 03-21-2014, 01:36 PM
thekingbeyonds's Avatar
You could try this, open the catalyst control centre , under video> colour. basic colour, select use video player settings and then hit apply. Hope it helps
Also check if you have anaglyph selected in tmt 5, if it is you should try left/right, your picture does look like the anaglyph setting.
Any ideas?
thekingbeyonds is online now
post #3666 of 3674 Old 03-21-2014, 10:34 PM
magicj1's Avatar
Thanks king. Unfortunately this has not worked. It is fine with 2D, but as soon as I run 3D the picture looks purple and green.
magicj1 is offline
post #3667 of 3674 Old 03-22-2014, 02:30 AM
magicj1's Avatar
Tried TMT6, same problem. Tried Power DVD and everything is OK. Looks like I may have to switch over to the dark side.
magicj1 is offline
post #3668 of 3674 Old 03-22-2014, 09:34 AM
shepP's Avatar
I can't seem to get dts-hd working with my new R7 260X. Anyone else having problems with this card and TMT 5?
Looks like TMT 6 was/is having the same issue. A updated ASSoundDetect.dll appears to be the solution. As I don't want to upgrade to TMT 6 I will try and download a trial version and see if I can use that .dll
Yep worked perfectly. This should work then for anyone else upgrading to a new video card.
shepP is online now
post #3669 of 3674 Old 04-08-2014, 06:08 PM
Maligx's Avatar
Are there any launch options for the MCE to start in 2D or 3D? like "uMCEPlayer5.exe" -2D or -3D ?
Maligx is offline
post #3670 of 3674 Old 04-08-2014, 08:31 PM
mr b's Avatar
Any ideas?
I had this exact same problem (Radeon HD7750) and was able to fix by going into 3d pull down menu and selecting "3D Ready DLP HDTVs"
It was previously set to "AMD HD3D Technology"
Hope this helps.
mr b is online now
post #3671 of 3674 Old 04-09-2014, 05:44 AM
dbailey75's Avatar
Liked: 33
they are in the settings of TMT MCE player. if I select to play all 3d in 3d, it end's up playing all blu rays as if they are 3d, or at 24fps which is part of the BD 3D standard, that's not really the issue, the issue is that you need 3d to play at 24FPS to pass proper 3d through to your TV so that everything works automatically, but in many cased 24FPS, doesn't play as smooth for non 3d blue rays, 60FPS, is preferred in my setup, just makes it all easier. so I keep that play all 3d in 3d unchecked, and since we don't watch 3d as often, I'll check the box as needed, your mileage may vary,
there are plenty of discussion on the 24FPS, etc. and maybe there are better fixes now, but 60FPS looks fine to me, and it was frankly a pain getting it all setup just right a few years ago
PSN: CAPTDANMAN
post #3672 of 3674 Old 04-09-2014, 09:27 AM
Maligx's Avatar
Well what I meant was sometimes I like playing 3D movies in 2D but once you launch MCE there is no way to turn off 3D without exiting again so I needed a way to launch it as 2D or 3D before MCE loaded. I did manage to figure out a way to do it. I used an autoit executable that replaces the INI file with the settings that tell it to launch in 2D mode or 3D mode. So every time I play a movie it will replace the file with 2D or 3D settings file.
Maligx is offline
post #3673 of 3674 Old 04-09-2014, 10:41 AM
dbailey75's Avatar
Liked: 33
you can't turn off 3d playback on your TV from your remote?
PSN: CAPTDANMAN
post #3674 of 3674 Old 04-09-2014, 12:34 PM
Maligx's Avatar
I think I had issues in the past simply turning off 3D like that, either way I have it setup the way I like and it works.
Maligx is offline
Reply Home Theater Computers
User Tag List
